Old 01-27-2016, 05:21 AM   #183
1978 28' Argosy 28
Pulled from the net, so it must be true.
The Chevrolet 8.1 liter engine was produced from 2001-2006 and installed in HD 2500 and larger trucks and vans, as well as motor homes, Suburbans and
Avalanches.
Post 2006 I believe they went to smaller and higher revving 6.0L. They also could have built and put in production both at the same time. Either would actually be good candidates for a moho swap if you ask me. I'd take either one if the right thing popped up. Many motorhomes used the 8.1L/4l80E combo. I think even the AS landyachts were 8.1L's. I don't have any info on the allison to be honest. However, if they were used behind HD Chevy work trucks that's good enough for me.
Something pulled from a motorhome will most likely have lower mileage than a worktruck. Just the nature of the beast.
bpg_austin is offline   Reply With Quote
Old 01-27-2016, 05:38 AM   #184
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Avalanches.
Not sure if I would consider a 6.0 as a replacement motor for our Motorhomes. I currently have G3500 van with a 6.0l and i use it to pull trailers up to 8000 pounds. It works fine with all the modern equipment, but does struggle on major hills.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-27-2016, 06:08 AM   #185
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
In searching a little more it appears around 90% of "2500/3500" supplied, came with the small block derivative 6.0L, and only around 10% had the big block 8.1L, but of those only a small subset (not even all the HD) had the 5-speed, and later 6-speed Allison 1000.
I know they made thousands between 2001-2007 (when they stopped using the Allison), but if 10% were big block, and 10% of those were the Allison, it sort off shows why there aren't many still running (plenty of engine/trans combos being parted out, or rotted out bodies whose engines need work!).
The searching continues, I am now on a 'mission!
martin300662 is offline   Reply With Quote
Old 01-27-2016, 11:24 AM   #186
Wellllll....you did need to find something to do....in your spare time...
Old 01-27-2016, 11:27 AM   #187
It almost makes the one Ben posted a good deal. Only trick would be finding all of the brackets, harnesses, computer and misc bits which might not be as difficult as finding a truck with the combination you're looking for in good condition.
Old 01-27-2016, 06:05 PM   #188
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Look what I just found and only around than 50miles from home, https://worcester.craigslist.org/cto/5395724433.html
Old 01-27-2016, 06:24 PM   #189
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
And you took time to post here before you called about it. ????
Gregsch is offline   Reply With Quote
Old 01-27-2016, 08:56 PM   #190
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I did call but had to leave a message, so will have to wait to find out if it is still for sale....and how much he wants to the computer, harness etc.
Old 01-28-2016, 05:06 AM   #191
1978 28' Argosy 28
AWESOME! Keep us posted Martin! With 330hp and 450ft/lbs of torque on hand you'd be pulling trees down with your coach. Not to mention all the real good stuff that comes along with it. (true multiport FI, serpentine belt, 6spd auto trans) Perfect.
Old 01-28-2016, 06:32 AM   #192
I'm trying VERY hard to ignore all of this chatter about upgrading to an 8.1/Allison 6-speed, etc.....my new 454 is on the test stand and just last night I started installing the new Thorley headers. I'm going to force myself to stick with the combination of 454/4L80e
ID:	256425Click image for larger version
I'm beginning to think Martin is a bad influence on me
Old 01-28-2016, 07:00 AM   #193
1978 28' Argosy 28
Thats one purty setup Brad. Not a dang thing wrong with what you'll be running. For that matter, there isn't really anything wrong with my tired 454 and th-400. Does what it needs to. But always tempting to do some updating when the opportunity arises.
Old 01-28-2016, 10:47 AM   #194
Tempting is right
But, I've got a bunch of TBI parts on the shelf now with more coming so I'll "make do" with a minor modernization to my 454 and the overdrive in the 4L80e!
Old 01-28-2016, 12:40 PM   #195
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Come on Brad 5.9 Cummings and 6spd Allison you will never look back
shepherd57 is offline   Reply With Quote
Old 01-28-2016, 01:24 PM   #196
John, that reminds of the old adage ďThere comes a time in every project when you must shoot the engineers and begin production.Ē
In my case it would be "There comes a time in every Argosy when you mush shoot the owner and let the builder finish it"
If I was starting from a blank slate that might be the way to but I need to learn to live with what I've got on hand and just finish the darn thing!
Ben and Lynn's Bambi II Re-do PA BAMBI II 1964 Bambi II 122 05-12-2017 08:11 PM
Ben's Bed :: 1994 Airstream Sovereign kmaggard Airstream Registry Discussions 0 06-20-2013 08:20 PM
