Old 06-10-2010, 03:03 PM   #1
TAE
TAE's Avatar
1977 24' Argosy 24
Clearwater , Florida
Battery needed
Hi Everyone, I need new batteries for my motorhome Argosy 24. What would be the best?? Thanks for your time.
TAE is offline   Reply With Quote
Old 06-10-2010, 03:40 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
You didn't specify house or start battery. but house should be deep cycle and start longest warranty you can afford. I used autozones gold and they replaced no questions when it was less than a year, MH was sitting without being plugged in so it was sort of my fault too.
Old 06-10-2010, 03:43 PM   #3
345bill's Avatar
Las Vegas , Nevada
Are you looking to upgrade? If your old ones were sufficient and are bad due to age why not re-new with the same. Just my 2 cents.
345bill is offline   Reply With Quote
Old 06-10-2010, 06:27 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You have some options:
1. larger size battery, or a 2nd battery
2. AGM (no maintainance)
3. 2 6v batteries in series to give you 12
If you do a search you will find more info than you want to know.
Old 06-12-2010, 02:31 PM   #5
TAE
TAE's Avatar
1977 24' Argosy 24
Thanks, I need them both. I found the deep cell battery (the small one fits in the compartment) I need the correct start battery size.
battery / electrical help needed tinsltootsie Batteries, Univolts, Converters & Inverters 11 08-09-2007 09:54 AM
Battery needed?!??? SilverToy Electrical - Systems, Generators, Batteries & Solar 6 04-11-2006 01:05 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
New Battery Box Needed jjonesnc Batteries, Univolts, Converters & Inverters 1 03-10-2004 01:23 AM
Battery for 76 Overlander needed tin can luv General Interior Topics 2 01-19-2004 08:20 PM
