Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 11-18-2018, 05:36 PM   #21
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I've been looking for an hour, but no luck on that specific faucet. It is OLD, I think it is the original.
This is as close as I can find.
Alan
Old 11-19-2018, 06:48 AM   #22
1977 24' Argosy 24
North Port , Florida
Images: 8
You guys ROCK - thank you for your time and help! I am the computer person and now have to get T.O.M. to try out your suggestions - AFTER he gets done with the new brake system. Trying to find parts that work is difficult for any system!
Elisa is offline   Reply With Quote
Old 11-19-2018, 08:16 AM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Originally Posted by elisa View Post
you guys rock - thank you for your time and help! I am the computer person and now have to get t.o.m. To try out your suggestions - after he gets done with the new brake system. Trying to find parts that work is difficult for any system!
t.o.m. ???????????
Old 11-19-2018, 08:58 AM   #24
1977 24' Argosy 24
Images: 8
The Old Man, or maybe I should say The Old Mechanic? We will tackle the sink AFTER the brakes are right! And of course, there are always other things...
Old 11-23-2018, 10:14 PM   #25
1977 20' Argosy 20
Arlington , Texas
Most of the 77 Argosys came from the factory with Streamway faucets. That brand has now become Phoenix Faucets owned by Valterra.
Repair parts like new valve stems are readily available for the Phoenix/Streamway faucets.
For detailed information go to Phoenixfaucets.com.
If repair is possible, it will be easier than complete faucet replacement.
Good luck!
Gregg
GWallace is offline   Reply With Quote
Old 11-25-2018, 10:58 AM   #26
1977 24' Argosy 24
Images: 8
https://phoenixfaucets.com/store/category/faucets/recreational
Phoenix Faucets appears to have our faucet! Perhaps they can advise us on how to take it apart before we damage anything. Thank ou for your time and help!
Old 11-25-2018, 12:32 PM   #27
A W Warn's Avatar
2000 25' Safari
Phoenix Faucets gives a lifetime warranty. Call and ask for replacement parts.
http://www.phoenixfaucets.com/resour...fs/I-2HLAV.pdf
Alan
Old 11-28-2018, 07:23 PM   #28
1975 27' Overlander
Galena , Illinois
Just replace the black O rings. That should stop the leak if the faucet works ok for you. Be sure to smear Vaseline all over the valve/O rings when reinstalling.
75Bob is offline   Reply With Quote
Old 11-28-2018, 08:58 PM   #29
2007 22' International CCD
Bathroom Faucet Fix or Replace?
Not Vaseline. I’d use plumbers silicon grease instead. A light coating. Vaseline is petroleum based, and may cause swelling of the o-ring material.
Replace bathroom faucet DJW Sinks, Showers & Toilets 5 03-23-2016 09:24 AM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Replace shower faucet in Sylvia/Larry? david b jone Sinks, Showers & Toilets 3 04-24-2007 07:14 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
HELP!--replace faucet freeshell Fresh Water Systems 5 10-20-2004 07:29 PM
