Old 11-18-2018, 11:18 AM   #15
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by Elisa View Post
As you can see, no hex.
Use an adjustable wrench to turn the nut with the flat spots.
Take the old one with so you can match it when you to get a replacement. You can get these at the big box building supply, a plumbing supply, or a good hardware. The new assembly will most likely have a hex nut in place of the two flat spots.
Or, as someone mentioned earlier the whole assembly may be rebuilt (new washers and packing)
Pay attention to the way the knob turns. If the knobs turn in opposite directions then there is a different part number for both left (hot) and right (cold)
Alan
Old 11-18-2018, 12:17 PM   #16
1977 24' Argosy 24
SW Florida , Florida
Images: 8
Bathroom Faucet - "Flat Spots"
The "flat spots" are not raised; that whole assembly is down inside the surrounding round piece, below the rim of the surrounding round piece. No wrench is fitting in there.
I am ready to cut the whole sink out and put a new one in, if I can't get this out without damaging the existing sink. Overkill, I know. Grrrr...
Elisa is offline   Reply With Quote
Old 11-18-2018, 12:45 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Take a combination wrench in which the open end fits the flat spots.
Stand the wrech on its end with the open end stratling the flats.
Use a screw driver in the box end of the wrench as a lever to turn the wrench.
Old 11-18-2018, 12:56 PM   #18
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Look close, that round piece may be just a trim ring that threads over the stem, channel locks with slight pressure may work.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 11-18-2018, 01:40 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think AlinCal may be right.
The ring probably unscrews.
Old 11-18-2018, 05:50 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
They may just pop out like the C and H buttons.
Old 11-18-2018, 06:36 PM   #21
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've been looking for an hour, but no luck on that specific faucet. It is OLD, I think it is the original.
This is as close as I can find.
Alan
Old 11-19-2018, 07:48 AM   #22
1977 24' Argosy 24
Images: 8
You guys ROCK - thank you for your time and help! I am the computer person and now have to get T.O.M. to try out your suggestions - AFTER he gets done with the new brake system. Trying to find parts that work is difficult for any system!
Old 11-19-2018, 09:16 AM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Originally Posted by elisa View Post
you guys rock - thank you for your time and help! I am the computer person and now have to get t.o.m. To try out your suggestions - after he gets done with the new brake system. Trying to find parts that work is difficult for any system!
t.o.m. ???????????
Old 11-19-2018, 09:58 AM   #24
1977 24' Argosy 24
Images: 8
The Old Man, or maybe I should say The Old Mechanic? We will tackle the sink AFTER the brakes are right! And of course, there are always other things...
Old 11-23-2018, 11:14 PM   #25
1977 20' Argosy 20
Arlington , Texas
Most of the 77 Argosys came from the factory with Streamway faucets. That brand has now become Phoenix Faucets owned by Valterra.
Repair parts like new valve stems are readily available for the Phoenix/Streamway faucets.
For detailed information go to Phoenixfaucets.com.
If repair is possible, it will be easier than complete faucet replacement.
Good luck!
Gregg
GWallace is offline   Reply With Quote
Old 11-25-2018, 11:58 AM   #26
1977 24' Argosy 24
Images: 8
http://phoenixfaucets.com/store/category/faucets/recreational
Phoenix Faucets appears to have our faucet! Perhaps they can advise us on how to take it apart before we damage anything. Thank ou for your time and help!
Old 11-25-2018, 01:32 PM   #27
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Phoenix Faucets gives a lifetime warranty. Call and ask for replacement parts.
http://www.phoenixfaucets.com/resour...fs/I-2HLAV.pdf
Alan
Old 11-28-2018, 08:23 PM   #28
1975 27' Overlander
gurnee , Illinois
Just replace the black O rings. That should stop the leak if the faucet works ok for you. Be sure to smear Vaseline all over the valve/O rings when reinstalling.
75Bob is offline   Reply With Quote
Replace bathroom faucet DJW Sinks, Showers & Toilets 5 03-23-2016 10:24 AM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 09:38 PM
Replace shower faucet in Sylvia/Larry? david b jone Sinks, Showers & Toilets 3 04-24-2007 08:14 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 08:50 AM
HELP!--replace faucet freeshell Fresh Water Systems 5 10-20-2004 08:29 PM
