Old 06-05-2015, 12:02 PM   #1
1975 20' Argosy 20
Shipley , West Yorkshire
Argosy throttle cable
Hi, the throttle cable (accelerator) on my 20' 1974 Argosy has fallen apart beyond repair, does anyone know where I might find a replacement or someone that could make one up for me? Tried here in the UK but to no avail. Any help would be appreciated, Phil
dodgyphil is offline   Reply With Quote
Old 06-05-2015, 12:11 PM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
No need to get one made they are still easily available in the US, from Napa, Rock Auto or specialists like Mill Supply (https://www.millsupply.com/search.ph...cs=1&submit=Go).
martin300662 is offline   Reply With Quote
Old 06-05-2015, 03:23 PM   #3
1975 20' Argosy 20
That looks like a good place to start, many thanks, keep up the good work!!!
Old 06-05-2015, 03:45 PM   #4
Keen amature
1975 20' Argosy 20
Chestfield , Kent
If you are having issues getting one shipped over, let me know; we're from the UK and come back and forth every few months so can always carry small stuff back and then drop it in the post to you from that side of the Atlantic.
Old 06-06-2015, 02:52 AM   #5
1975 20' Argosy 20
Many thanks for that, I will bear it in mind, regards Phil
Old 06-08-2015, 11:50 AM   #6
dodgyphil,
There are many parts that are slightly different on the Motorhome P30 chassis compared to the standard box truck P30 chassis. I have the motorhome version of the P30 chassis parts book from GM. When I get home from work this evening I'll look through the parts book to see if the throttle cable is listed and if so what the part number might be.
Off hand I can't think of any reason the throttle cables would be different but I'd hate to see you have something shipped from the US only to find out it's the wrong one.
Old 06-08-2015, 04:39 PM   #7
Ok here's what I came up with straight out of the parts manual:
338903 = P308-P314 Motorhome except 10,000 or 11,000 lb Rear Axle
338904 = P314-P318 Motorhome with 10,000 lb Rear Axle
From notes in the parts manual I think the 338904 supercedes 338903 but I'm not 100% certain of that.
I think the best bet is to find a throttle cable with part number 338904. Unfortunately as near as I can tell from Google searches both 338903 and 338904 are discontinued, at least from GM. Hopefully one of larger parts house chains will have something that is suitable.
Not the best news but I hope this helps
Old 06-08-2015, 06:05 PM   #8
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Anyway to confirm the length and fittings?
NAPA list a 68" cable for the all the 350 and 454 engined P30 (BK 6101430) made by Balkamp
Mill Supply list a 69" cable with the same fittings (1248092)
But many other parts suppliers (Rock Auto, Summit etc list the ATP Y265 70" cable (ATP Automotive) for the all P30 from 1975-1992
Old 06-08-2015, 06:25 PM   #9
I can very easily measure my 74 20'Argosy tomorrow after work. My motor is not installed yet so I have easy access for pictures and cable length.
More tomorrow....
Old 06-09-2015, 07:54 PM   #10
......it's tomorrow
I measured the throttle cable on my 74 Argosy 20' mh and it's 82" plus/minus about an 1". I couldn't see the pedal end as it's covered up so no picture there. The carburetor end looks like this.
Name:	1974 argosy throttle cable 82 inch.jpg
Sorry for the quality of the picture. The bracket mounts to the intake manifold at the back of the carburetor.
Looks like the cables listed above are going to be to short.
Hope this helps.
Old 06-09-2015, 07:56 PM   #11
I probably should mention it's entirely possible a shorter cable could be made to work but I would think the bends might be a bit tight.
Just a thought....
Old 06-10-2015, 09:27 PM   #12
Keen amature
1975 20' Argosy 20
Chestfield , Kent
ATP do make a 82in cable for GM applications that looks to have the same fittings.
ATP Y262
Meant to be replacement for the following GM parts
GENERAL MOTORS: 364659
GENERAL MOTORS: 376193
GENERAL MOTORS: 1248088
GENERAL MOTORS: 15552817
GENERAL MOTORS: 15552818
Old 06-11-2015, 05:41 AM   #13
Martin,
The carburetor end of this cable isn't the same as the one on my 74. The one on my Argosy pops onto a stud with a spring loaded catch. The one in your reference link shown in the attached photo uses some sort of stud with a retainer to keep the cable on.
Name:	throttle cable Y-262.jpg
However I have no doubt that the one you referenced could be made to work without much effort at all. As a matter of fact I think the carburetor I'm going to be using on my 454 (Edlebrock 1406) uses the type of cable end in your reference link.
Forgot to mention Amazon has this cable for about $22, not bad.
1981 454 P30 throttle Body cable ASTailgate Mechanics Corner - Engines, Transmission & More... 1 07-02-2014 08:43 PM
Throttle cable TAE Argosy Motorhomes 4 06-24-2012 02:03 PM
Throttle Body Space Adapter knunut Tow Vehicles 9 05-08-2007 07:30 AM
Throttle tension & Cruise control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 10 07-14-2005 09:01 PM
Argosy throttle cable mcneon Mechanics Corner - Engines, Transmission & More... 7 08-24-2003 09:17 PM
