Old 09-29-2014, 07:06 PM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Argosy steel cap rust
I am starting to repair the surface rust that has collected at the windshields edge, and around the marker lights.
I have sanded the rust off and etch primed it. Pulled up the marker lights and cleaned underneath. Plan is to run a light coat of bondo over it to match the paint thickness and sand clean. I plan on painting it with roller and brush. This not an A+ resto job, just want to clean the rust and repaint.
Pretty straightforward but just wondering if anyone else has done this and has any advice/tricks? How about the paint to to use(it is Argosy beige) I'm sure it won't match.
Thanks in advance,
Chris
realpank is offline   Reply With Quote
Old 09-30-2014, 09:49 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I thought the end caps were galvanized, so maybe they need a special paint treatment?
Do be prepared for some water to have got inside. On the parts Argosy I bought, the end caps looked pretty good, but as I got the nose up on the hauler for shipping (approx a 15 degree incline) about a 1/2 pint of water flowed out from around inner cap, onto me sitting in the driver seat.
martin300662 is offline   Reply With Quote
Old 09-30-2014, 10:14 PM   #3
Windsor , Ontario
Thanks Martin,
Those are good points, they are galvanized. I'll mention that
When I go to buy paint. Rust areas stripped to raw so it will be clean.
Thanks for your input,
Chris
Removing dents from Argosy steel end cap VtTim Ribs, Skins & Rivets 7 01-28-2014 08:15 PM
Argosy - steel cap replace/repair? IndianaJeff Roof 7 04-17-2013 05:53 AM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
