Argosy Brakes
I agree totally you have air in the lines I have thought of the power bleed ,but there is a simpler way ,open your master cylinder up check the level if down fill DONT FORGET TO PUT THE TOP BACK ON NOT TIGHT JUST ON ,go to the farthest bleeder screw it is located behind the backing plate where the brake cylinder is it is the highest point on that brake shoe crack the bleeder open untIl you see fluid coming out use a trouble light DO NOT TOUCH THE BRAKE BEDAL AT ANY TIME WHEN THIS IS OPEN Put down some cardboard so you can see when this is leeking or dripping. Go back to the master cylinder every ten minutes to see if it is going down if it is shut the bleeder screw refill the master and move on to the next farthest brake cylinder and repeat let sit for 12 hours tighten everything up refill master and start engine. Do a brake check do not at any time stab the brake peddal.AT NO TIME SHOULD THE FLUID BE ALOWED TO REACH THE BOTTOM OF THE MASTER CYLINDER OR YOU WILL HAVE TO REPEAT THE WHOLE PROCESS .Start with the farthest brake cylinder usually passenger side rear then drivers side rear then front passengers side then drivers front side.
ITS YOUR DREAM HAVE IT ANY WAY YOU WANT
