Old 06-19-2016, 12:56 PM   #1
1977 28' Argosy 28
dexter , New York
Argosy 28 MoHo
Does anyone know what this is ?
jonesy 1 is offline   Reply With Quote
Old 06-19-2016, 01:01 PM   #2
1977 28' Argosy 28
dexter , New York
Can't get pic to 2 springs from ball joint to a bracket on lower control arm
Old 06-19-2016, 06:43 PM   #3
1977 28' Argosy 28
dexter , New York
Ft.end
Old 06-20-2016, 06:57 AM   #4
I wonder if that is a Steer Safe device?
Old 06-20-2016, 07:53 AM   #5
1977 28' Argosy 28
dexter , New York
That's what it is thank you .
Old 06-20-2016, 08:01 AM   #6
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Do you not have the factory hydraulic steering damper, from the idler arm to the front cross-member?
martin300662 is offline   Reply With Quote
Old 06-20-2016, 08:11 AM   #7
Steer Safes don't serve the same function as a steering damper. I'd like to install the Steer Safes on my Argosy but I'm having a hard time justifying the price. They are a bit pricey.
Old 06-20-2016, 08:18 AM   #8
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I will research a little more Brad, even the vendor website list them as alternates to hydraulic steering dampers. The difference to me seems to be a damper simply adds resistance to change in steering direction, and the steer safe ties to keep the steering wheels straight, or pull back to straight if there is no input. So one tries to resist change and the other tries to keep straight????
Old 06-20-2016, 08:26 AM   #9
Actually you're right about serving similar purposes. My train of thought was the Steer Safe's tend to force your wheels back to a centered position which the damper doesn't do.
Knock on wood but every flat I've ever had has been on the rear of a vehicle or motorcycle, I dread the day I have a blow out on a front at speed
Old 06-22-2016, 09:16 PM   #10
1977 28' Argosy 28
dexter , New York
Yes I do have shocks on the steering damper to the frame
Old 07-10-2016, 08:29 PM   #11
1977 28' Argosy 28
dexter , New York
Hers my next question,I installed a good battery the motor turned over good the next day the battery was dead. I seem to remember something about gm alternator kill a battery over night ,bad diode ?
Old 07-10-2016, 09:44 PM   #12
1977 28' Argosy 28
dexter , New York
The propane compartment door had no key ,so I picked the lock took it apart and dropped the tumblers out put it back together now anything will open it is this ok for propane no locked ? I thought of maybe glue in a blank key . I don't see a non lock t handle and it stuck out to much .your thumb nail will open it now..
Old 07-11-2016, 07:49 AM   #13
Keen amature
1975 20' Argosy 20
Chestfield , Kent
It is actually illegal for the propane compartment to be locked!
Old 07-21-2016, 02:06 PM   #14
1977 28' Argosy 28
dexter , New York
Does any one have an automatic transfer switch on the generator?
Argosy 20' Moho silverhawk Argosy Motorhomes 100 09-06-2008 03:00 PM
Argosy 24' MOHO Smog? doorgunner Argosy Motorhomes 1 07-06-2007 08:55 AM
chibreed - 74 Argosy Moho Chibreed Member Introductions 4 06-11-2007 12:05 PM
Value of Argosy MoHo? Blu_Hwy_Lady Trailer Values 11 03-06-2007 07:58 PM
Hello - Argosy MOHO bobchevy89 Member Introductions 4 05-07-2006 09:06 PM
