Old 01-10-2007, 05:34 PM   #85
anytown , California
Hello all,
Well my 2nd post is a reply to myself! I asked some folks "in the know" about this little 20 footer and they say that is a seroius project that WILL cost a good chunk of change to complete.
I'll pass on this one.
REFLEXX is offline   Reply With Quote
Old 01-10-2007, 07:17 PM   #86
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by REFLEXX
Hello all,
Used by a logging camp, Hmmm Don't imagine it is tooooo good a shape
2 Blown motors to boot.
It would tow, but it is not likely set up for towing. (mine is not but would with a little work)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-13-2007, 08:56 PM   #87
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
wheres Shorty? any prgross on the little guy [girl]?
Doug
bibbs is offline   Reply With Quote
Old 01-13-2007, 09:13 PM   #88
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
What a great thread. I too would love to know how shorty is doing. The outside for the most part looked great!
Old 01-14-2007, 12:54 AM   #89
2004 16' International CCD
1997 25' Safari
hamilton , Montana
yes,, please post progress on Shorty,,, feels like an adoption of a sad puppy dog from the animal rescue,, am very grateful for your efforts,, donna
dieterdog is offline   Reply With Quote
Old 01-15-2007, 10:55 AM   #90
1982 28' Airstream 280
Norfolk , Virginia
We Want Shorty, We want shorty!
Steve
Geophilist is offline   Reply With Quote
Old 02-04-2007, 12:15 AM   #91
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Figure out how to get the engine out? I've been wondering how hard it would be to buy a cheap bread van and just swap the whole enchilada out?
Marc
Old 02-04-2007, 07:02 AM   #92
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
Send a message via Yahoo to silverhawk
Shorty update
I wish there was actually something to tell ya. The truth is that there is'nt. Shorty and I are pretty much just hibernating for the time being. I went inside him the other day and found all the cleaning supplies I had left in there frozen, solid. This morning it is 0 degrees outside. I would rather have a foot of snow.
I have been able to wangle some funds for the project but not nearly enough to move forward yet. There is still alot of engine and mechanical deconstruction to do. This will not start until warm weather. Spring will be here early though, so says Punxy Phil. I ca'nt wait.
Bob,
silverhawk is offline   Reply With Quote
Old 02-04-2007, 11:34 AM   #93
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Bob,
I bought an engine that had been in a fire and the carb was toasted (old Rochesters can be a problem if not maintained) that was in a 73 GMC truck (a 454 low mileage with carb fire). Given I couldn't work on it for a while I pulled the spark plugs and shot in a bunch of transmission fluid, then loosely put the plugs back in. I also pulled the carb off and shop vac'd as much of the crap that I could get out of the intake (before I did the cylinders with oil) and then also shot a bunch of trans fluid down there as well. Then put a bag duct taped over the intake hole and let it sit till several months later when I had the oppty to work on it. I had been told that the engine would not turn over when I got it and forgot to checkwhen I got it home (at that time a few beers/memory impairment were always involved), but when I did try it at the later date it turned over fine. I pulled the plugs and spun it over a lot to clean things out, changed the plugs/oil/distributor and plug wires and Alternator wiring and fired it up. I used an Edelbrock carb and the engine fired right up and I ended up using it as it was for years in my beater truck. If you are going to let it sit for a while you might want to consider the oil in the cylinders at least in case they got water in them when the fire was being put out. Just make sure you remember to clean it out before you try to start it.
Barry
safari57 is offline   Reply With Quote
Old 02-04-2007, 02:06 PM   #94
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
That sounds like good advice Barry. When I consider the cost of a crate moter, and the trouble of a rebuilt one, that sounds like the right first step to try. What can it hurt right? One question, why tranny fluid? Also anyone with any systems information, I could use it or info on where to get it.
Thanks... Bob,
Old 02-04-2007, 04:41 PM   #95
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Frankly, I can't remember why we use tranny fluid. This bloody stroke has caused some memory clips to disappear but I know we used it on any engine we were leaving sit for a long time. Also, when we got an engine that, from sitting the rings had stuck to the cylinder walls we used clean varsol and let it sit, and sometimes that worked to free it up, then we'd use the trans fluid for a couple of days, spinning it over every night a few times both forwards and backwards. It is critical to remember to clean it out and change the oil before you try to run it though. I'll pop an email to my buddies back in the old home town and ask why we used trans fluid. Jeepers I hate this not remembering the really important stuff like that yet I still remember my telephone number and stuff when I can easily look it up if I need to.
Just because an engine has had a fire on top doesn't mean the engine is shot. But if it got filled with water trying to put the fire out then you have to make sure it's drained out and the engine is properly re-lubricated. Rust never sleeps as the saying goes.
Good luck with it . It will be interesting to see how it turns out this spring or summer.
Barry
Old 07-24-2007, 02:34 PM   #96
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
What's up with Shorty? Any new news???
And ATF in the bores helps unstick the rings from the cylinder walls. There will be a little smoke when you start it the first time afterwards...
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 07-27-2007, 11:54 AM   #97
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
A quart of ATF in the crankcase of an old V8 won't hurt it. It was something we did back at a garage when I was working my way through school. The tranny fluid is a terrific detergent.
And yeah, I was just wondering a couple of days about what's up with Shorty??
bhayden is offline   Reply With Quote
Old 07-27-2007, 12:17 PM   #98
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Me too - those cleaning supplies have to be thawed by now...
Any new photos?
Fyrzowt is offline   Reply With Quote
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
Question regarding sleeping & eating in a 1978 28' Argosy.. Rick F Argosy Motorhomes 4 09-01-2011 11:40 PM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
