01-07-2019, 07:17 AM
#121
Richmond
, Kentucky
Lookin good
1975 24' Argosy Motor Home
01-07-2019, 07:42 AM
#122
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by bkahler
Lookin good
Thank you!
I'm excited when I see the engine every time!
01-07-2019, 09:26 AM
#123
2024 Atlas
Jeffersonville
, Alabama
Looks great!
01-07-2019, 03:41 PM
#124
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by chevy2man
Looks great!
Thank you!
01-15-2019, 07:57 AM
#125
Churubusco
, Indiana
Dang, this is coming along awesome!
You're already past it, but it's a good thing you did your research with the gasket/rtv for the intake
A good but not perfect intake manifold gasket is what caused the failure of my motorhomes first engine. A previous owner changed the intake manifold, and the gasket wasn't lined up perfectly, and after a few thousand miles it failed and let coolant into the intake.
Anyway, you're doing awesome with this, excited to see how it turns out!
01-15-2019, 11:40 PM
#126
1977 20' Argosy 20
Matsubushi
, Saitama
Thank you!
I've researched many services for the Argosy.
It means I had to get the two things, the first one is the mechanism, the other is English.
I can learn both when repair the Argosy!
Anyway, I'm afraid of leaking coolant into the block.
And I don't like leaking oil, so I use rtv everywhere!
01-16-2019, 07:20 AM
#127
1977 20' Argosy 20
Matsubushi
, Saitama
A little update.
I'm preparing to install the engine.
Remove rust and grime, then I'll paint the frame, stays and brackets.
I removed headlight brackets.
I'm going to replace headlights because those are very dark sealed beam lamps.
Moreover, I should use headlights which for left-hand traffic.
And I need to replace adjust springs and screws.
I need to repair this dent someday..
I found rust between steering gearbox bracket and frame.
Whoa... it's terrible
I decided to remove a crossmember when I saw that.
Driver side was rusted more than passenger side.
Some bolts didn't have edges, so I couldn't turn it with wrench.
Reluctantly, I broke the nuts.
I've done to remove the crossmember.
I'm going to remove a brake booster, steering gearbox and brackets.
My hobby is dismantle a car.
My argosy has strong undercoating on the frame and underneath floor.
It's hard to remove..
Anyway, I have a lot of to do things yet.
01-17-2019, 07:30 AM
#128
2024 Atlas
Jeffersonville
, Alabama
Looking good!
01-17-2019, 12:16 PM
#129
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
With the engine out, this is an excellent time to repair/replace brake lines and refresh the break fluid. Much easier to bleed brakes, due to easy access to master cylinder.
01-17-2019, 05:15 PM
#130
1977 20' Argosy 20
Matsubushi
, Saitama
Looking good!
Thank you!
I'll fight with rust on the weekend.
01-17-2019, 05:28 PM
#131
1977 20' Argosy 20
Matsubushi
, Saitama
Yes, that's true!
However, I've replaced a master cylinder, calipers, front brake lines/hoses and rear wheel cylinders already.
I'm going to replace the old proportioning valve and rear brake line on this occasion.
01-17-2019, 07:58 PM
#132
2021 27' Globetrotter
Gulfport
, Mississippi
Excellent work!! We had a ‘75 Argosy 20’ MH that we restored. It was also green when I purchased it!
I sold it over a year ago, it was a fun project. Here’s the thread:
http://www.airforums.com/forums/f463...-mh-42788.html
Good luck!!
01-17-2019, 09:19 PM
#133
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by Overlander & Sea
Thank you for the message!
Of course I've seen your thread already.
Your work is amazing! I want to make clean exterior and interior for my Argosy like yours.
Anyway, your Argosy was more green than mine!
01-22-2019, 06:46 AM
#134
Dazed and Confused
Hillsburgh
, Ontario
Dang, this is coming along awesome.
Rob, keep in mind that Yuki is Japanese, with limited English; using a Google translator.
Not quite sure how "Dang, this is coming along awesome" translates into Japanese.[emoji16]
Cheers Sidekick
Tony
01-22-2019, 07:36 AM
#135
1977 20' Argosy 20
Matsubushi
, Saitama
Cheers Sidekick
Tony
I often use some dictionaries which have slang or whatever.
Actually, "dang" is the new word to me.
I think it's a negative word, but I know some negative words stand for positive meanings sometimes.
So I understood it was good meanings!
Because I'm an optimist.
01-22-2019, 08:12 AM
#136
Richmond
, Kentucky
So maybe the challenge here is to throw slang words at Yuki and see how long it takes him to figure them out!
Dang can be used for being upset, being surprised or even being frustrated. It has many different uses. In Rob's case I believe he was possibly surprised.
01-22-2019, 03:42 PM
#137
1977 20' Argosy 20
Matsubushi
, Saitama
Thank you for explaining, Brad!
Slang words are difficult.., however I'll try do my best.
English words have some different meanings so it's useful but confusing.
01-22-2019, 03:58 PM
#138
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
yeah, Brad, Yuki is doing some bad ass stuff over yonder
AIR #13
01-23-2019, 05:39 AM
#139
Richmond
, Kentucky
Ok Yuki, you're up......
More slang for you to decipher
01-23-2019, 07:39 AM
#140
1977 20' Argosy 20
Matsubushi
, Saitama
My work is progressing slowly.
I remove old paint and rust.
That's a little boring work..
I'm going to do the boring work at the driver side as well.
So I removed a brake booster and a steering gearbox.
It's easy to remove the gearbox, because I've removed and rebuilt that in the past.
Removed the brake booster.
I need to remove a lock nut, but I don't want to buy a "pricey" special tool..
Maybe I look for square pipes or make square shape with angle bars, then making a special tool myself.
I get a homework that is how to remove the lock nut.
Next, removed a steering gearbox bracket. It's very rusty..
Just empty
The argosy seems like a junk
