12-17-2018, 06:31 PM
#101
Richmond
, Kentucky
Yuki, the light listed in the Ebay auction is a genuine NOS GM replacement light. Order it if you can.
1975 24' Argosy Motor Home
12-17-2018, 09:42 PM
#102
1977 20' Argosy 20
Matsubushi
, Saitama
I like the word "NOS", those are probabuly rare parts!
Definitely I would have bought it, if I didn't get the reproduction parts yet..
However, in actual fact many seller do not ship goods to Japan.
I've bought NOS parts before which is for Yamaha motorcycle with ebay. They couldn't send it to Japan, so I decided to send to uncle place.
He lives in Texas, usually comes back to Japan in every summer. So if I do same deal, I can get it next summer!
Anyway, I'll go with the Mexican ones.
If it did not fit on Argosy, I'll change the plan.
Thank you for the information again.
I appreciate it.
12-24-2018, 07:06 AM
#103
1977 20' Argosy 20
Matsubushi
, Saitama
Today's accomplishment is very big event.
I removed an engine from Argosy.
I've never thought I’d remove a V8 engine by myself.
Fortunately I have an engine crane and stand.
But those are for my little Datsun, it has a small 4 cylinders engine.
The V8 is leaking engine oil so I have to repair that.
So I decided what I did.
I guess the oil leaks from a rear main seal or oil pan but I'm not sure.. anyway, I'll check it soon.
My engine crane is too high for the Argosy..
I used some concrete blocks under the tires and rigid racks.
The crane has a hook, but the engine bay is very tight, it doesn't have enough height so I use a shackle instead of the hook.
Many bolts obstructed to lift the engine.
I cut it off!!
That worked well.
This is an obstacle sub-frame.
I removed its rivets and took off the frame.
Umm... it's too tight.
I tilted the engine then pulled and lifted it.
I did it!
My dirty engine has pulled out!
I'm very surprised the engine was removed easily
I'm going to clean and paint it, and replace some gaskets and seals.
To be continued..
12-24-2018, 07:39 AM
#104
1984 27' Airstream 270
Scotia
, New York
Do everything you can on the cooling system, while it is out, you save a lot of grief later.
Do not take life too seriously.
You will never get out of it alive.
12-24-2018, 10:16 AM
#105
2006 28' Safari
1948 22' Liner
1989 34.5' Airstream 345
Jamul
Nice job Yuki!
12-24-2018, 11:48 AM
#106
1982 31' Airstream 310
champaign
Originally Posted by wayneg
do everything you can on the cooling system, while it is out, you save a lot of grief later.
yes, yes, double yes, and yes!
12-24-2018, 03:47 PM
#107
1977 20' Argosy 20
Matsubushi
, Saitama
Yes! I'm going to replace water hoses, pump, thermostat and re-core the original radiator!
Moreover, I add engine and trans oil coolers.
I'll go gambling that use an electrical fan instead of the mechanical one.
#108
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by Lychgate
Nice job Yuki!
Thank you!!
12-24-2018, 03:51 PM
#109
1977 20' Argosy 20
Matsubushi
, Saitama
Yes! Yes! Yes, I agree and do that!
12-24-2018, 05:37 PM
#110
Henniker
, New Hampshire
Nice work!
1982 310 motorhome 502
Henniker New Hampshire
12-24-2018, 08:43 PM
#111
2024 Atlas
Jeffersonville
, Alabama
Nice work Yuki!
12-25-2018, 05:04 AM
#112
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by chiefair
Nice work!
Thank you!
12-25-2018, 05:05 AM
#113
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by chevy2man
Nice work Yuki!
Thank you!
01-02-2019, 06:25 AM
#114
1977 20' Argosy 20
Matsubushi
, Saitama
My Datsun got a big motor!
Because I didn't have engine stand bolts..
So I've put the engine temporary on the tray.
The engine stand bolts have arrived, I put the engine on the stand.
But.... the engine stand is very weak, because I bought it for my little 1500cc Datsun engine.
It tilted when the engine crane left.
And it couldn't turn over the engine.
Maybe it'd be able to hold the engine, but I decided to use the crane for supporting. Because I'm a coward.
Anyway, I had to clean and paint the engine. It's very dirty!
Removed old paint and dirt, then detached an intake manifold.
Ready to painting!
I sprayed primer and orange.
It looks good.
I like an orange color engine.
Next, I installed an intake manifold.
Many how-to videos recommended to use RTV with gaskets. So I did that.
I trial fitted many parts that go with the engine.
I can't wait to install it to the Argosy!
01-02-2019, 06:37 AM
#115
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Originally Posted by GREEN ARGOSY
Attachment 330866
Attachment 330868
Attachment 330867
Attachment 330869
Attachment 330870
Ready to painting!
Attachment 330871
Attachment 330872
Attachment 330873
It looks good.
Attachment 330874
Attachment 330875
Excellent work!
01-02-2019, 07:57 AM
#116
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by martin300662
Excellent work!
Thank you!
01-02-2019, 08:18 AM
#117
1977 20' Argosy 20
Matsubushi
, Saitama
Replaced a rear main seal.
The engine was wet by oil where is the part of rear end.
So I'm doubting to leak from a rear main seal.
So I checked that.
There's dry, the seal would be OK.
Maybe the oil leaked from an oil pan gasket.
However, I replaced the seal. It means "preventive measure"
The first, I removed an oil pump.
Yeah, the oil pump shaft sleeve was broken.
But it's OK. I've bought a new one already.
Then removed a rear main cap.
I could see an oil seal.
I hit the seal with a pin punch.
It's turning and came out.
I installed the new one with plastic tool.
The tool protects the edge of seal.
I've finished the part of upper side.
The lower side, I removed a seal from a rear main cap.
Then I installed a new one.
I offset its parting line about 3/8" from the cap/block parting line.
The last thing, I pray it wouldn't leak the oil from there.
01-02-2019, 08:28 AM
#118
2024 Atlas
Jeffersonville
, Alabama
Nice Job Yuki! I like the Chevy Orange for the engine. That 454 engine is all that engine stand wanted. [emoji23]
01-02-2019, 05:28 PM
#119
1977 20' Argosy 20
Matsubushi
, Saitama
Thank you!
I like chevy orange and mopar orange too.
But I don't know what's the different from each other.
01-07-2019, 07:01 AM
#120
1977 20' Argosy 20
Matsubushi
, Saitama
Install a harmonic damper with an installer tool.
I hold the tool and tighten the nut, then the harmonic damper was installed little by little.
I had to tighten up the nut strongly. However, I've done to install it.
But my engine stand has broken.. when I tighten the nut with power!
I'm going to repair that, because my little Datsun engine is staying on a wood pallet now.
I marked the point of 15 degrees BTDC on the harmonic damper.
I'm going to control ignition timings with Atomic EFI, it needs to be matched the distributor on 15 degrees.
Next, installed a distributor.
I don't need centrifugal timing advance, so remove weights and springs then lock it out.
The Atomic EFI manages ignition timings.
MSD said "it needs an adjustable rotor and set for retard 15 degrees", of course I followed them.
The engine is ready to go!
I have to paint the frame soon.
