02-08-2019, 08:16 PM
#181
Yuki,
I bought my unit over a year ago.
John
02-08-2019, 08:25 PM
#182
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by GCinSC2
Green Argosy,
Sorry I don’t have better info and I had no idea you are in Japan that might make things a bit more complicated.
If you can get in communication with the company that built the product and detail your question pictures help a lot and circumstances I bet they will try to provide tech assistance. But as far as returns etc “follow the money” you basically are stuck working with the company you purchased from.
Regards
Gary
Gary,
Actually it's complicated that I get some parts from foreign countries.
They said "please return the item" but it's not easy for me.
If I returned it, I need to find the other product. That's not easy as well.
Yes, I sent some pictures to them.
Some pictures help to explain it instead of my poor English.
Anyway, I have to keep on trying hard!
Thank you,
Yuki
02-08-2019, 09:43 PM
#183
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by JEE
Yuki,
Just an FYI (for your information).
The OEM parts catalog lists 465387 as the part number for the 1977 P30 Hydro-boost unit for JB8 brakes.
Rockauto website shows A-1 CARDONE 529393 services Alternate/OEM Part Number(s): 4031352, 4086467, 465387, 470197.
Aftermarket parts rebuilder servicing many factory part numbers with one part.
John
John,
Thank you for the more information!
I got the new number of "465387"
Hmm.... OK, my suspicion was incorrect.
PRIOR has never shown the alternate/OEM Part Number(s)
They are unkind..
02-09-2019, 03:45 AM
#184
1977 20' Argosy 20
Matsubushi
, Saitama
I got new knowledge of the Hydro-Boost.
Bendix made two types of hydraulic power brake booster which have different back-up pressure source in an accumulator.
Their name is "Hydro-Boost" and "Hydro-Boost II"
"Hydro-Boost" is a spring loaded design which was used from 1974 - 1978.
It has a large spring which to make pressure in an accumulator.
The other is "Hydro-Boost II", it was introduced in 1981.
That have nitrogen gas charged to make pressure instead of the large spring.
This made the assembly more compact and lighter.
"Hydro-Boost II" has blue and yellow(gold) color of the accumulators.
Those have different pressure for brake components (disc/disc or disc/drum).
Anyway, I think my old one is "Hydro-Boost" and the new one is "Hydro-Boost II".
Those have different way to make pressure but function is similar.
Probably I'd be able to use "Hydro-Boost II" for my Argosy, if its dimensions are same.
FOURWHEELER NETWORK said "The hydroboost has a nitrogen-charged accumulator that acts as a back-up pressuresource. The early accumulators used a massive spring to make pressure, but eventually it was discovered that a nitrogen-charged chamber with a floating piston similar to that used in a shock would be sufficient."
<Websites reference> Thanks a lot!
"Dave's Place Hydro-Boost Brake Systems"
http://dave78chieftain.com/hydroboost_brakes.html
"1986 CHEVROLET 1 TON STEERING REBUILD HYDROBOOST BRAKES REBUILT - HYDRAULIC PRESSURE STEERING PUMP"
http://www.fourwheeler.com/how-to/tr...photo-12.html#
02-09-2019, 06:18 AM
#185
2007 30' Classic S/O
Somewhere
, South Carolina
Yuki,
I think we are all learning from your trials getting this figured out.
Gary
02-09-2019, 06:46 AM
#186
Richmond
, Kentucky
Yuki, that is incorrect. Yours should be the Hydro-Boost II. The original Hydro-Boost using the spring type accumulator looks like this.
Here's a picture of mine showing that the nitrogen-charged accumulator is not part of the hydroboost unit.
1975 24' Argosy Motor Home
02-09-2019, 07:16 AM
#187
1977 20' Argosy 20
Matsubushi
, Saitama
Yuki,
Gary
Gary,
Thank you for the message.
Nah, I'm just doing trials...
Maybe I give wrong informations sometimes..
So do not trust me..
02-09-2019, 07:54 AM
#188
1977 20' Argosy 20
Matsubushi
, Saitama
Attachment 333195Attachment 333197
Attachment 333196
Brad,
Thank you for the correction and information!
I've heard hydro boost has remote accumulator type.
But I've never seen that before!
That has a bigger accumulator than the combined unit.
At least I got more knowledge of Hydro-Boost. Thanks again!
Hmm... the Hydro-Boost is a little bit complex...
I saw these pictures recently, I've thought that the right accumulator is the spring loaded model, the middle and left ones are nitrogen-charged model.
Someone said "the blue one is for disc/disc brakes charged to 450 psi, and the yellow (gold) one for disc/drum at 350 psi."
By the way, the manufacturer (PRIOR Automotive) gave me answer about the schreder valve.
They said "The Schrader valve that is on the booster is installed by us to be able to charge the accumulator"
02-10-2019, 05:44 AM
#189
1977 20' Argosy 20
Matsubushi
, Saitama
I removed some old paint with scraper.
It's not fun, but Bahco scraper works great.
I discovered green paint when removed the black paint.
Because it's a GREEN ARGOSY
I need to do more work...
I'm going to continue it tomorrow.
I worn goggles and mask but my face is very dirty!
I should have worn a full face mask.
02-10-2019, 06:56 AM
#190
Dazed and Confused
Hillsburgh
, Ontario
Out of curiosity........how old are you Yuki?
Cheers
Sidekick Tony
02-10-2019, 05:29 PM
#191
1977 20' Argosy 20
Matsubushi
, Saitama
Cheers
Sidekick Tony
Tony,
I was born in 1987, I'm 31.
In other word, I'm 10 years younger than the Argosy.
02-10-2019, 06:09 PM
#192
Somewhere
, South Carolina
Gary,
I’d rather trust the guy trying with the dirty hands and busted knuckles over an armchair quarterback.
02-10-2019, 07:44 PM
#193
Dazed and Confused
Hillsburgh
, Ontario
Tony,
For a young buck with boundless energy, hellava head on your shoulders, lots of money, (although your wallet might be a lot lighter than before), you have an old soul Yuki, and a Samurai spirit.
Cheers
Sidekick Tony
02-10-2019, 08:50 PM
#194
1977 20' Argosy 20
Matsubushi
, Saitama
Gary,
I got the new word "armchair quarterback"
02-10-2019, 09:20 PM
#195
1977 20' Argosy 20
Matsubushi
, Saitama
Cheers
Sidekick Tony
Tony,
I believe I have a samurai spirit in my mind.
However, I'm not a rich man, I spent the all of money which I get for the restoration work! So I’m nearly broke..
But It's OK, because I really like argosies and airstreams!
02-11-2019, 07:54 AM
#196
Somewhere
, South Carolina
Gary,
Yuki,
It might not translate well but it can mean someone that second guesses your decision or action or claims usually without having done knowing a better way to do something.
Also used to describe the legions of feverish football fans talking about what usually loosing quarterback should have done to get a touchdown.
Keep getting dirty, real knowledge on these tasks is a big part of the reward.
Gary
02-11-2019, 06:12 PM
#197
1977 20' Argosy 20
Matsubushi
, Saitama
Yuki,
Hi Gary,
Thank you for the explanation!
Probably I got it, and I don't want to be that.
Yes! I'll keep on doing some work and trials.
My favourite place is under the Argosy!
Yuki
02-11-2019, 07:07 PM
#198
1982 28' Airstream 280
Port Angeles
Hi Yuki,
Here is another one for you to look up, "Young whippersnapper." I as well as many others can say that about you because we are old.
Keep up the good work.
Cheers, Dan
~ Margaret Thatcher ~
02-11-2019, 09:00 PM
#199
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by Smartstream
Hi Yuki,
Hi Dan,
Oh! That's a new word too.
Definitely I am a "Whippersnapper"
Thank you!
Yuki
02-11-2019, 09:06 PM
#200
Port Angeles
You need to add "young" Yuki. It's "young whippersnapper" for the best effect.
Cheers, Dan
