Old 08-27-2008, 07:11 PM   #1
Anyone ever removed the Frigerator?
Need to replace my Bad Dometic 4.5 cu ft. Dissembled and removed the left side wall took all the screws out on left side and two bolts on the rear. Also removed the series of screws on the other side inside closet. Still won't budge. Thanks
911rs is offline   Reply With Quote
Old 08-27-2008, 07:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are screws on the under side of the counter, and a screw or two at the top of the fridge, against the inside of the body. These are a real pain to get to.
Old 08-27-2008, 08:06 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
See http://www.airforums.com/forums/f425...air-23857.html
I've talked with John and he said there was an extremely tight fit between the sidewalls and the fridge. He used lots of WD40 or LPS-1 for lube -- I forget which.
5 meter Langford Nahanni
Old 08-28-2008, 09:09 AM   #4
Thanks for the comments amd advise. Looking at it again it looks like it is also secured on the right side and may have to remove interior wall also. What a pain. BTW this on a 1975 Argosy 20ft MH.
Old 08-28-2008, 03:36 PM   #5
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
It sure is a Beauty! Welcome to the forums and good luck with the fridge.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 08-28-2008, 05:42 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
On our '64, there were also bolts through the floor and some brackets attached to the bottom of the fridge. PITA all right!
Shari
Old 08-29-2008, 03:37 PM   #7
Have you ever been frustrated working on something and come back the next day and it works out great? Being patient and removing only the small storage area above it and it finally came out. Now I can clean up the area seal and paint the floor it was under and the stand the frig sat on. Currently waiting for it's Dometic replacement to come. Thanks everyone. Booyah!
Old 08-29-2008, 07:29 PM   #8
1973 31' Excella 500
Morristown , Tennessee
fridge removal
I recently removed the fridge from my 1973 Excello. The fridge is just reaward from the salon with a thin bulkhead wall seperating the two. This wall was removed giving easy access to the box. The shelving unit above was screwed to it with some backer boards. The screws were easily found by simply opening the cabinets. The was a corner metal brace on the right side of the box that was screwed into the floor and the right side on the box. There was one final metal strap toward the to of the box securing it to the rear wall. There were all held with the small shet metal screws that are used in many of the applications in these units. Good luck and let me know if that helps.
Joe
Alumin8 is offline   Reply With Quote
Old 09-03-2008, 08:46 AM   #9
Defelice, This was the very same way it was secured. Multiple screws on the side plus two rivets on top of refrigerator to drill out. The only disappointment was the shelf just above the frig is orange Formica. It was rotted on the back closest to the vent. Will replace. I learned it's probably a good this to seal off the exterior service door with louvers to keep the moisture/humidity out when not in use. Thanks for the experiences.
Old 09-11-2008, 10:54 PM   #10
1966 30' Sovereign
1963 22' Safari
orlando , Florida
don't forget it is also bolted to the frame.
richie rich is offline   Reply With Quote
Old 09-12-2008, 06:47 AM   #11
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
If one needed to get inside the vent, rather than work on the fridge itself, would there be a possibility of cleaning out, say, a wasp nest in the vent without removing the whole darn fridge?
I'm guessing not, since I see no way of removing the vent cover from the outside.
bredlo is offline   Reply With Quote
Removed the carpet! Santart Land Yacht/Legacy Motorhomes 12 09-13-2009 05:53 PM
Removed the door... gotohatteras 2006 Safari 7 06-30-2007 06:10 PM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 11:12 AM
Removed Vinyl from Door! tin can luv General Interior Topics 37 07-14-2004 08:09 AM
Frigerator repair davidlaxson Refrigerators 0 12-16-2003 06:22 PM
