Old 01-13-2015, 11:11 AM   #1
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Airspeed Indicator
Inland Andy,
we're rehabbing our Argosy motorhome dashboard + gauges + instruments.
one of your longstanding suggestions is for having an Airspeed Indicator in a coach. that seem like a really good idea, and we're thinking this one might be suitable - UMA NON TSO 2-1/4 INCH AIRSPEED INDICATORS from Aircraft Spruce
any suggestions as to a recommended pitot tube to use, and a pitot tube location? we don't think we need a heated tube, but are uncertain about keeping the tube safe, and unclogged?
thanks in advance for your ideas!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 01-13-2015, 11:23 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I'm sure you can find a used one much cheaper on eBay or in TradeAPlane. I'm a pilot so have experience with AS indicators and pitot tubes.
It should should work on a MH, the pitot tube needs unrestriced air flow straight into it. I'd mount the pitot tube anywhere that will give you that. Heaters in them are for when you are flying in clouds, don't think you will be doing much of that. You will need a static vent on the side of the coach for the system to work as that is the "reference pressure". It is called the "pitot-static system". As far as keeping it unclogged,buy a cover for it. Ever notice airplanes on the ramp at the local airport? All will have a red cover with a streamer attached to it on the pitot tube to keep bugs and mud dabbers out. The steamer is to make sure the pilot removes the cover during pre flight as taking off with no AS indicatior is NOT the way to live a long and healthy life.
Wiki has a pretty good write up on the system
Pitot-static system - Wikipedia, the free encyclopedia
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-13-2015, 11:46 AM   #3
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I am planning on doing the same thing to mine. I already have several air speed indicators. I think they also have altitude built in. I used to work for a company that manufactured them and we had a box of old parts that I went through. They were going to scrap them so I took them home. I would be happy to sell you one providing I can still find them.
mprokop87 is offline   Reply With Quote
"Power On" indicator davidz71 Electrical - Systems, Generators, Batteries & Solar 23 09-15-2005 09:52 AM
Level Indicator Alex Jacks, Stabilizers, Lifting and Leveling 3 12-03-2003 08:27 AM
Tank level indicator panel mcostanzo 2003 Safari 7 11-07-2003 09:27 AM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
Electric indicator Panel Joan D'Andrea Electrical - Systems, Generators, Batteries & Solar 1 11-01-2002 12:03 AM
