06-28-2003, 07:30 AM
#61
Just a member
1978 28' Argosy 28
Lutz
I would love to have OD, but I hear the OD trannys are nothing but trouble. High failure rates and such in this application. If the transmission needs a complete do over to stop eating governers then I will cross that bridge. For now the consensus is a bad bushing on the tail shaft or a gear with some rust on it. We will see what is is once he gets the engine and tranny out.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
06-28-2003, 08:04 PM
#62
1966 26' Overlander
Woodstock
, Georgia
well Brett I was hoping when all is as it should be, you might be coming through North Atlanta and visit so we could see this rig for ourselves before our next rally wh Classic motorhome rally which won't be at Mystic I guess....., then again you are probably taking I 10 and won't be anywhere near us...
hope it all comes together, the photo of the Argosy looked great ..
sorry for the run on sentence, but we do wish you guys luck with the project(s)
06-28-2003, 09:06 PM
#63
Brett and Edie
Know it was not your plan to be an inspiration to all of us working to debug our units but you both sure are!
Good luck and the pic looked great...jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
06-29-2003, 10:55 AM
#64
1982 34' Limited
Tidewater
, Virginia
It's good to see you go with a GM crate/Goodwrench motor. Warranty is excellent and the product is too.
The TH400 transmission and the 4L80 are the same design with the 4L80 having OD. In other words the 4L80 is a TH400 w/OD. As stated previously a control module will be needed; total cost over $2K. Not sure the total weight of the MH might not be too much to utilize the OD feature very much.
Option B is to purchase a B&M or other reliable, nationwide warrantied TH400 for less that $1000. I'm not going to list sources as others seem to have better sources, however, the major speed catalogs list several TH400 built with towing in mind.
Unless you are comfortable with the actual rebuilding process it's going to cost more than $150 to do the job. Fact of life, not pleasant, but a fact none the less.
Hope this is of some value.
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
06-29-2003, 11:32 AM
#65
4L80E
I'm a big fan of the 454/4L80E combo. Pulls great in the Suburban towing horses/racecars and pulls great in the '92 Airstream 300LE @14,000 lbs. Runs in OD always unless climbing. 2000 RPM @ 65 MPH. Airstream gets 10.1 MPG. FWIW. Can't comment on heavier rigs.
07-02-2003, 03:09 PM
#66
Just a member
1978 28' Argosy 28
Lutz
Update time!
The old motor and tranny are out! parts installation and accessories swap has begun. Still no word on the tranny, but we still have time.
New accessories include new waterpump, 100 AMP Alternator, and AC Compressor ( the old ones main shaft seal is leaking).
Shooting for the 10th to have it all done, we hope to make that date, or else it has to slide to the 17th.
Brett G
07-02-2003, 04:01 PM
#67
Yorkshire
, England
Oh dear...
Edie & Brett...
For what it's worth, good luck 2u both, an GREETINS from ENGLAND...both Mark n myself r saddened by your dose of bad luck...but I guess U still smilin through it...Yr a brave couple, a great team...an we toast our cup of tea to you both...CHEERS...
Hope U soon get sorted an home safe n sound, real soon...till then ...
Well done...Chris n Mark...
It's NICE 2B Important...but it's more Important 2B NICE...Chris.....
07-08-2003, 05:37 PM
#68
Just a member
1978 28' Argosy 28
Lutz
Update time again!
The motor is ready to go back in with all the new accessories, I am hopeful that the reinstall will be done by noon tommrow. Then the transmission has to go back in. The govenor issue was that the gear shaft that drives the govenor had gotten rusty and the rust ate the nylon gear up. This was able to be cleaned off and the transmission should be fine. According to the "expert" on site this is a common occurance if a unit has sat for a while. Somehow the top half of the shaft gets exposed and can rust.
Once the motor is in then the cooling system goes back in and AC gets redone. We hope to pick it up either Thursday or Friday this week.
Brett G
07-08-2003, 07:00 PM
#69
1959 22' Caravanner
Atlanta
, Georgia
Good to hear!
Take it easy on the ride home. No steady speeds for extended time. Breaking in a new engine the first 500 miles the speed should be varied some.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
07-08-2003, 07:06 PM
#70
Just a member
1978 28' Argosy 28
Lutz
I have sworn off the cruise control for the ride home. That is 1200 miles, plenty of highway, but I will be on some backroads too.
Brett G
