Old 02-14-2006, 09:14 AM   #1
1979 28' Airstream Excella 28
malden , Massachusetts
A generator on an Argosy
I have a 1978 argosy and the generator has not worked or a while..... It works sometimes and I've heard that the gas level in the tank matters and should I look to the gas filters ????..Thanks for any help Rod
roderickm3 is offline   Reply With Quote
Old 02-14-2006, 09:59 AM   #2
1989 37' Airstream 370
Hastings , Minnesota
Generator Argosy
Your problem could be many. Yes the amount of fuel in the tank is very important. The gen set has its own fuel line going to the fuel tank. The fuel pick up in the tank is higher off the tank bottem than the engine fuel pick up is.
This is so that if you are out in the boondocks with your
generator running you will always have enough fuel to get to town and fuel up.
The gen set has its own electric fuel pump but not a fuel filter unless one has been added aftermarket.
Your trouble also could be a clogged carburator if the generator has not been used in a long time.
I hope this will help you,
Pat370 Hastings, Mn.
Pat370 is offline   Reply With Quote
Old 02-14-2006, 10:09 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Could be the gas line
Originally Posted by roderickm3
I have a 1978 argosy and the generator has not worked or a while..... It works sometimes and I've heard that the gas level in the tank matters and should I look to the gas filters ????...
On the Onan installed on the '87 the filter is SUPPOSED to be inside the external electric fuel pump (the electric fuel pump for the genny is mounted on the generator). The internal filter itself is no longer available as a replacement part, so if you have one installed in the fuel pump you may consider installing an aftermarket inline filter.
One of the problems on the 345 genny was the cracking of the generator gas (suction) line. On the 345 the line is about 15' long - air is able to get into the line through the cracks when the genny electric fuel pump comes on line. Evidently this had been going on for a while 'cause the seats and needles of both the primary and secondary jets were extremly worn away - I suspect there was quite a bit of air/liquid impaction going on to wear away the brass jets to the extent the metal had disappeared.
Since your lines are 10 years or so older than the '87 345, I would recommend a through inspection of the suction line from the gas tank to the generator.
How many hours on your generator? With almost 800 hours on the Onan in the 345 I have given up trying to "fix" it and have decided to install a new generator....it's only time and money.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-14-2006, 10:11 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Yes, and you may want to look at the solenoid valve (if it has one).
This might come in handy?
http://www.bdub.net/manuals/onanmanual.pdf
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
