Old 05-17-2009, 01:30 PM   #1
Don Landis's Avatar
1978 28' Argosy 28
Monterey , California
'78 Argosy 28' MH Repair and Cost List
Well, after several weeks I finally got my comprehensive repair and cost list. Wow. I'm going to have to put some money into it to get it going. I expected this, but it looks like it will take me longer to get the money up and the repairs done. And I'll have to do a lot of the repairs myself to save on labor costs - like the refrig, air conditioner, heater, etc. Plus I think I can find a lot of the parts cheaper on the internet.
But the basic mechanics of the engine, suspension, transmission, brakes, and exhaust aren't something I can do myself - I'm unfortunately an office jockey with no training in mechanics and without all the right tools. So I think I'll need to spend the initial money (the little I have) on a mechanic to get these parts going. Then I'll start fixing the interior myself - with everyone's help and suggestions of course.
So, what do you think of the list? Comprehensive? Is it missing anything? What would you change or suggest or add?
Don Landis is offline   Reply With Quote
Old 05-17-2009, 03:04 PM   #2
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
The best thing in the world for you to tackle would be a lot of the mechanical things you have listed. Unless you plan on your moho being yard art, a basic knowledge of simple mechanics and how it's all laid out could save you from a seriously expensive problem in the middle of a vacation. Buy yourself a good service manual for your engine and start working on the small things first. A basic tool set is all you'll really need for simple jobs. Don't be afraid of it. Things like replacing a transmission filter, fluid and pan can be done in an afternoon. Motor mounts are a really simple fix. Even brakes are a lot easier than most people realize. The biggest thing is to get over your fear of the unknown. There's also the satisfaction and sense of accomplishment when you make those small repairs on your own.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 05-17-2009, 03:34 PM   #3
fozzies's Avatar
1974 Argosy 24
1974 24' Argosy 24
Manningtree , essex
Send a message via Skype™ to fozzies
It seems to us that you are facing the same kind of job that we are currently into (we are rebuilding a 1974 Argosy moho), I realise you are not a pro mechanic but there are lots of suppliers out there where you can get a much better price on parts than you have been quoted for. Ok I know mechanics like to take a cut on the parts prices but most reasonable guys will fit your own parts for you if you ask nicely. Look on websites like Rockauto for stock parts, Jegs or Summit for the stuff like headers and electronic ignition. We are in the UK and can get most of our parts at a really good price if we shop around. If you are reasonably practical you can do a lot of the work yourself, we are always willing to help with advice on mechanical work, and even if you have to spend some money on tools (don't ever buy cheap tools!) it will save you money on future repairs too. I have taught many people basic mechanics and there aren't many people out there with no ability whatsoever. The main thing you need is observation and persistence, take a photo before you start anything like brake shoes or stuff that looks complicated where you might forget which way up things go. Just have a go, you might even enjoy it!
fozzies is offline   Reply With Quote
Old 05-19-2009, 12:18 PM   #4
It appears to be a good comprehensive list but I do have some suggetions and comments.
I would be real surprised if you have to replace the cam, lifters & timing chain. These motorhomes generally do not have enough miles on them to justify these sort of repairs. To get you on the road sooner I would ignore any of his suggestions for internal work on the engine and concentrate on getting rid of engine leaks, engine cooling issues and vacuum issues. Once the engine is running smoothly then you can worry about whether the lifters, cam and timing chain needs replacing. Even if they do you can most likely go a lot of miles before you HAVE to do something about them. You'll probably find that the rough idle is caused by vacuum leaks from all the dry rotted hoses.
Adding headers is definitely worth doing and if you need to replace the rest of your exhaust system then do the headers at the same time.
I would not do the HEI and rev limiter. Wait until you drive it some to see how it does. The stock ignition system is surprisingly robust. If something breaks on the stock ignition system while you're traveling parts are easy to come by. Just try and find parts for an aftermarket ignition system while you're stuck on the side of the road in the middle of no where.
I agree with rebuilding the complete front end. The only thing I would add would be to install front air bags in side the front springs when putting the springs on. I found it very difficult to replace the air bags with the springs on the vehicle. The air bags do improve the ride considerably.
I also question the need to replace the electric fuel pump. Ensure that its actually not working before spending money to replace it. Just because it looks rusty doesn't mean its bad.
Do all of the brake work he suggests. Brakes are all there is between you and disaster!
Replacing the fridge isn't all that difficult and I bet you could do it yourself. We did ours and it was relatively easy.
Also I think he oversized your furnace. Our 31' 310 motorhome had a 30k unit installed. I think 45k would probably roast you out of your motorhome!
When we got our 310 motorhome a few years ago we concentrated on the mechanical safety issues first. We wanted a safe ride. Cosmetics, etc came in second. As a matter of fact we're still working on the cosmetics!
Think of it this way, safety first and then creature comforts!
Old 05-19-2009, 02:26 PM   #5
1977 20' Argosy 20
san diego , California
Definitely a good list. I completely agree with Brad. There's much to be said for a "keep it simple" approach to these vehicles. I suspect those of us that travel substantial distances in our motorhomes have similarly prioritized our mechanical issues.
One item I might add is an aftermarket transmission cooler.
One item I might dream about is a Gear Vendor.
argy is offline   Reply With Quote
Old 05-19-2009, 03:54 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I am with Brad on this one too. He is doing an Argy now too.
I also gotta worry about the difference between Rod Out RAD Core (removing the tanks and physically running rods through the core to remove obstructions) and "Rot Out or Replace RAD Core." (Whatever Rot Out means, it doesn't sound good)
Leaks, all hoses, brakes, and suspension are high priority. Then you can enjoy it while you do the rest.
Vaughan
Old 05-19-2009, 04:09 PM   #7
Don Landis's Avatar
1978 28' Argosy 28
I hear you and I really appreciate everyone's advice. I wonder about the cam, lifters, and timing chain. The mechanic, though, thought he heard or felt a slipping timing chain, and while he was in there.....
I'm also interested in the ignition issue you discussed. I thought I read hear that having electronic ignition was the way to go and my prior experience with a 70 Chrysler Newport taught me the same. I really want to improve the gas mileage as much as possible (everyone can stop laughing now), and make the engine run smoother, start up easier, and run cleaner. Isn't it worth putting on an electronic ignition system now?
Finally, having talked with a few of you privately and what I've read here in the forum, I really think I'm just going to go with heavier springs up front instead of front air bags. I know this is quite controversial, but I think it's the way to go in the long run for less maintenance.
I really want to concentrate on the engine, suspension, transmission, and exhaust with the initial money I have, and then spend years and years fixing the rest interiorwise. I also think I can replace the fridge and other items. Although I'm a little concerned with the heater and anything relating to propane to ensure I don't miss an obvious trick of the trade that results in my little kids' poisoning.
don
Old 05-19-2009, 08:45 PM   #8
That's just it, I wouldn't want him "inside" the engine if there is no real reason to be in there. I'm not saying he is trying to drum up business but my thoughts are until you know just how well the engine runs or doesn't run after fixing things like vacuum lines, ignition, etc then I'd leave well enough alone.
The timing chain either works or it doesn't. It won't slip, however if it is loose enough it could skip a tooth. If it did do that the running performance would probably be pretty bad and quite noticeable. What it can do is stretch over time (and miles) which causes a little less precision in ignition performance. However I'm still of the mind that these motorhomes don't get enough miles on them for the timing chains to be a real problem.
That's just it. The original ignition on these motorhomes is an electronic ignition. I don't know if its considered an HEI system but it doesn't use points and as long as you carry a few inexpensive spare parts with you you'll never have to worry about getting to where you want to be. If you install an aftermarket ignition then you'll need to buy some pretty expensive spare parts and I'll guarantee you you won't be able to find them at your local auto parts store.
Case in point, several years ago Susan's race car failed to start after getting tech inspected prior to the start of the race weekend. I ended up replacing the aftermarket HEI distributor, HEI ignition module and high performance coil with a stock distributor and coil. That was the only way I could get the car to run again. That ignition system failure almost cost us $600 in fees that were prepaid for the race weekend.
I'm now in the process of switching Susan's race car ignition from HEI back to a Mallory dual point distributor just for the ability to make easy repairs at the track if need be. When an electronic or HEI ignition fails trouble shooting is nothing more than swapping parts until it works again. Easy to do with a stock Chevy ignition, but not so easy with an aftermarket ignition.
The KISS principle is an important one to remember .
The worst you'll have with heavier front springs is a stiffer ride up front. That's not necessarily bad, I just like the smoother ride you get with air bags with less banging around.
I really want to concentrate on the engine, suspension, transmission, and exhaust with the initial money I have, and then spend years and years fixing the rest interior wise. I also think I can replace the fridge and other items. Although I'm a little concerned with the heater and anything relating to propane to ensure I don't miss an obvious trick of the trade that results in my little kids' poisoning.
It sounds like you're getting a reasonable game plan together.
Working on the propane system is no big deal. Just make sure the tank shutoff valve is closed before you open any lines. Also once you've got all of the lines reinstalled you just pressurize the system and check for leaks with soapy water. Not hard to do at all. You can also get a propane gas sensor to monitor for leaks if you're concerned about it. Right now our motorhome has enough air leaks I'm not to concerned about it .
Old 06-26-2009, 01:54 AM   #9
Don Landis's Avatar
1978 28' Argosy 28
Ok. I got a second opinion and a second quote. Still quite shocking, but comprehensive. So what do you think? Is this repair shop more comprehensive, more realistic, and/or more reasonable about the true costs?
Old 06-26-2009, 02:38 AM   #10
Don Landis's Avatar
1978 28' Argosy 28
What do I repair first - engine, brakes, transmission, exhaust, suspension?
Old 06-27-2009, 10:32 AM   #11
Don Landis's Avatar
1978 28' Argosy 28
Here's the must do list by the Mechanic. Are they?
don
Old 06-29-2009, 01:35 PM   #12
1983 34' Excella
1967 24' Tradewind
Images: 32
You are going to need a motorhome person to check in on this, but I am curious about the details for some of the procedures. For example, what do $457 of trans service and $206 of diff service get you exactly?
The total I get adding these estimates up is $7,468.75, and there are still question marks by some of the items.
Vaughan
Old 06-29-2009, 07:38 PM   #13
Don Landis's Avatar
1978 28' Argosy 28
The Fox bid to panels up has the detail of the parts and labor costs of each service. Thanks for responding. But Fox Bid and Fox2 Report together and you'll see what I'm talking about.
don
Old 06-30-2009, 07:02 AM   #14
Don,
I would run away from this Fox Auto Service as fast as I could. To me his prices are way off in left field. $97.50 (plus the cost of thermostat) to replace the thermostat is rediculous. $3418.50 to repair your dash A/C is also another example of price gouging. $292.50 to replace the valve cover gaskets is amazing.
If I had the time I'd say bring the motorhome to me and I'll do the work for those prices . Unfortunatelly I don't have the time.
As far as what to repair or replace first, I would do the brakes, suspension, exhaust (including headers), transmission, and then the engine in that order. I'm still not convinced you have any real internal engine problems that you need to worry about.
I would also question the need to replace both front brake rotors. I just had the two front rotors on our 74 Argosy motorhome checked and while I thought they looked horrible and felt they probably needed to be replaced. The shop I took them to took one look and said that'll be $17.50 to turn both of them. Once they were done he said they could be turned at least one or two more times. So take your rotors to a "good" brake shop and see what they say. I think you'll be surprised.
I still stand by my comments in my first my first reply to this thread.
Should I Repair or Replace? rkuhns956 Repairing/Replacing Floor &/or Frame 15 01-31-2012 06:09 PM
New Refer vs. Repair moosetags Refrigerators 7 12-10-2011 10:16 AM
Cost of painting 28' Argosy..? Rick F General Motorhome Topics 12 09-11-2011 11:51 AM
Black Tank Dump Valve Repair Cost bbherb Waste Systems, Tanks & Totes 12 06-23-2011 03:54 PM
Cost to repair 02 Bambi & approx. value as is au_ee Ribs, Skins & Rivets 0 03-21-2011 05:02 PM
