Old 06-28-2008, 06:36 PM   #1
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
'77 MOHO won't start
I can't figure this out and my knowledge is limited. Just recently, my '77 Argosy Moho won't start. No problems prior to this. When I turn on the switch I hear a faint clunck but the starter doesn't turn or engage. The fan, lights etc. come on. The battery has a full charge. I have replaced the ignition switch, had the starter tested and cleaned, and a new solenoid.
The fuses seem OK. The ignition relay seems OK using my ohmeter. Any other thoughts. It's probably simple but beyond me.
77 R GO C MH is offline   Reply With Quote
Old 06-28-2008, 06:46 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
This may sound basic, but...
Make sure the battery terminals are CLEAN. Don't trust a visual check, take them apart and clean them good. I have had several instances where this was my only problem.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-28-2008, 06:49 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had a VW years ago that had the same symptoms. The cable to the starter from the battery had corroded inside of the insulation.
Richard
Old 06-28-2008, 07:07 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have been told that weird things happen when the ground strap from the battery to the chassis isn't making good contact.
I bet Terry (overlander63) helps you get this sorted out in no time.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-28-2008, 07:11 PM   #5
richinny's Avatar
2011 34' Classic
what happens to the headlights when you turn the key.
headlights go out > check the terminal connections on the battery.
heaadlights stay on > see if you have voltage on the starter relay output.
if that fails, terry will fix it over the internet ;-)
Ricky
Old 06-28-2008, 07:32 PM   #6
1975 26' Argosy 26
Miami , Florida
Check the alternator belt. When these things "sit up" for a while the belts in general will (even new belts) freeze in position then "loosen" up out on the road. It takes no time at all to "throw" a belt and when it happens you'll think that something is wrong with the starter. Even the best mechanics sometimes fail to check the belts (or put the wrong sized ones on one) thinking, oh well I just changed those and they can't be the problem? Wrong. Take a look. I had this same problem (you are describing how my 1976 Argosy behaved to a "T") when I picked her up amd sure enough...a "thrown" belt. (Lucky me that I discovered this "before" I replaced the starter.) Good luck, J. Lee
J. Lee is offline   Reply With Quote
Old 06-28-2008, 07:37 PM   #7
1977 28' Argosy 28
Lincoln , Nebraska
Thanks everyone. I've got a few things to try.
Old 06-28-2008, 07:49 PM   #8
Yep, I'm betting its one of your battery connections. You'll likely find at least of one of them is corroded or bad.
Good luck!
Old 06-30-2008, 01:40 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you checked the solenoid? It's mounted directly on the starter, close to the exhaust manifold, where it gets nice and hot.
A "clunk" noise when you hit the key could very well indicate the solenoid engaging, but not transmitting power to the starter.
I'll try not to get too technical, but a GM starter solenoid works with an electromagnetic plunger that, when energized, throws the bendix (starter drive) into the ring gear of the flywheel. When it does this, the copper contact on the plunger bridges the gap between the battery lead on top and the power lead for the starter motor. If this copper contact becomes corroded or pitted, it will engage the starter drive, but the starter itself will get no voltage, and will not spin.
Where do I start? slo-an Full-Timing 9 01-08-2012 06:47 AM
2004 LY *Won't Start, No Power* Help RAG General Motorhome Topics 15 12-27-2011 03:41 PM
EU2000i Won't Start PaulR Generators & Solar Power 35 10-10-2011 01:43 AM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 03:01 PM
