Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 06-28-2008, 06:36 PM   #1
77 R GO C MH
77 R GO C MH's Avatar
Profile:
77 MOHO won't start
I can't figure this out and my knowledge is limited. Just recently, my '77 Argosy Moho won't start. No problems prior to this. When I turn on the switch I hear a faint clunck but the starter doesn't turn or engage. The fan, lights etc. come on. The battery has a full charge. I have replaced the ignition switch, had the starter tested and cleaned, and a new solenoid.
The fuses seem OK. The ignition relay seems OK using my ohmeter. Any other thoughts. It's probably simple but beyond me.
77 R GO C MH is offline   Reply With Quote
Old 06-28-2008, 06:46 PM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
This may sound basic, but...
Make sure the battery terminals are CLEAN. Don't trust a visual check, take them apart and clean them good. I have had several instances where this was my only problem.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-28-2008, 06:49 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
I had a VW years ago that had the same symptoms. The cable to the starter from the battery had corroded inside of the insulation.
Richard
Charter Member Four Corners Unit
Old 06-28-2008, 07:07 PM   #4
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
I have been told that weird things happen when the ground strap from the battery to the chassis isn't making good contact.
I bet Terry (overlander63) helps you get this sorted out in no time.
1984 310 Limited Motorhome
guy99 is online now   Reply With Quote
Old 06-28-2008, 07:11 PM   #5
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
what happens to the headlights when you turn the key.
headlights go out > check the terminal connections on the battery.
heaadlights stay on > see if you have voltage on the starter relay output.
if that fails, terry will fix it over the internet ;-)
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
Old 06-28-2008, 07:32 PM   #6
J. Lee
Profile:  Currently Looking...
Miami , Florida
Check the alternator belt. When these things "sit up" for a while the belts in general will (even new belts) freeze in position then "loosen" up out on the road. It takes no time at all to "throw" a belt and when it happens you'll think that something is wrong with the starter. Even the best mechanics sometimes fail to check the belts (or put the wrong sized ones on one) thinking, oh well I just changed those and they can't be the problem? Wrong. Take a look. I had this same problem (you are describing how my 1976 Argosy behaved to a "T") when I picked her up amd sure enough...a "thrown" belt. (Lucky me that I discovered this "before" I replaced the starter.) Good luck, J. Lee
J. Lee is offline   Reply With Quote
Old 06-28-2008, 07:37 PM   #7
77 R GO C MH
Profile:
Thanks everyone. I've got a few things to try.
Old 06-28-2008, 07:49 PM   #8
bkahler
Profile:  Jefferson , Arkansas
Yep, I'm betting its one of your battery connections. You'll likely find at least of one of them is corroded or bad.
Good luck!
"Wherever you go... there you are." - Buckaroo Banzai
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
bkahler is online now   Reply With Quote
Old 06-30-2008, 01:40 PM   #9
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Have you checked the solenoid? It's mounted directly on the starter, close to the exhaust manifold, where it gets nice and hot.
A "clunk" noise when you hit the key could very well indicate the solenoid engaging, but not transmitting power to the starter.
I'll try not to get too technical, but a GM starter solenoid works with an electromagnetic plunger that, when energized, throws the bendix (starter drive) into the ring gear of the flywheel. When it does this, the copper contact on the plunger bridges the gap between the battery lead on top and the power lead for the starter motor. If this copper contact becomes corroded or pitted, it will engage the starter drive, but the starter itself will get no voltage, and will not spin.
Change is inevitable, except from a vending machine
AIR#2611
Argosy 20 Moho silverhawk Argosy Motorhomes 100 09-06-2008 03:00 PM
Hello - new with '91 moho! Spud Member Introductions 4 05-09-2007 09:52 AM
Airstream MOHO Devoman General Motorhome Topics 0 04-10-2007 04:17 PM
Value of Argosy MoHo? Blu_Hwy_Lady Trailer Values 11 03-06-2007 07:58 PM
Hello - Argosy MOHO bobchevy89 Member Introductions 4 05-07-2006 09:06 PM
