Old 02-01-2011, 08:57 AM   #1
Camp's Avatar
peachtree city , Georgia
'77 Argosy entry door replacement
I'm a newbie with a nice little basket case. Among a laundry list of issues, my entry door has suffered multiple hi-speed openings. I'll post a pic later today. It may be repairable (I've read some posts), but I thought I would inquire about a replacement. Anyone with links, contacts, ops? What other year(s), model(s) are compatible? This is a suicide door. Thx.
'77 Argosy 26
2000 Excursion 6.8L
Camp is offline   Reply With Quote
Old 02-01-2011, 11:47 AM   #2
Camp's Avatar
'77 Argosy 26
2000 Excursion 6.8L
Old 02-01-2011, 12:56 PM   #3
Camp's Avatar
The replacement will have to be used. A new one is worth more than the trailer....$1800. Plus shipping and without a window.
'77 Argosy 26
2000 Excursion 6.8L
Old 02-01-2011, 01:21 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
One possible source of a salvage door is Colaw's RV Salvage in Carthage Missouri. They are a volume dismantler and their inventory does tend to turn over on a regular basis. You can find Colaw's on the web at this link.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 02-01-2011, 02:18 PM   #5
Ottawa , ON
Since whatever you do you will have to remove the existing door, there's one more thing to consider: repair ir yourself.
This thread gives a brief description of how you do it, and if you can get your current door off, you have won half the battle, I think. I don't know, since the only door I've ever taken off my AS is the screen door.
1953 Flying also lists a bunch of threads about it here.
I dunno what you had in mind, but you won't be alone, lots of folks have had the bad luck with the door. Good luck!
Old 02-01-2011, 02:29 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you want to tackle repairing the door yourself. It may be possible. The door on my Argosy was not setting in the opening correctly. So I decided to see if I could fix it myself. And was successful. I didn't take the hinges off of the trailer, I took the inside panel of the door off, which gave me access to the hinge mounting. Here is a photo of what they look like. You could remove the door and see of you can re arc it to fit the opening.
Name:	Top Door Hinge.jpg
TG Twinkie is online now   Reply With Quote
Old 02-01-2011, 07:18 PM   #7
Camp's Avatar
Some of the salvage yards were probably closed today due to the midwest storm. I didn't get through to colaws. Based on the cost of a new door however, a used one will likely be out of my budget also. I'll read some threads, pull the door skin off and assess the damage. I don't think I can make it any worse. Thx for the info.
'77 Argosy 26
2000 Excursion 6.8L
Old 02-02-2011, 07:37 AM   #8
Ottawa , ON
Good luck, Camp. Let us know how it works out.
sprung door, 1977 Argosy
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 21 06-08-2014 10:46 AM
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
