Old 10-24-2017, 06:45 PM   #1
1977 28' Argosy 28
Bloomington , IL
77 Argosy 28 insulation question
I'm considering an Argosy 28 and I just had a quick question. I promise I did search a bit but I thought it might just be easy to ask quickly. Are the tanks inside the insulated envelope of the motorhome or outside?
Scottorious is offline   Reply With Quote
Old 10-24-2017, 08:27 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I can't speak for sure on your Argosy but on my 82 Airstream 280 with a rear bath the tanks are under the floor just ahead of the rear bumper... not insulated. I suspect yours is the same unless you have a center bath.
Cheers, Dan
~ Margaret Thatcher ~
Old 10-25-2017, 02:07 AM   #3
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
If yours is like my 20 and 24 footer, the fresh water tank was inside under a seat and the gray & black tanks are below the floor, in the bathroom area. There was a shroud under them but no insulation. Also the dump valves will be uninsulated.
WayneG is offline   Reply With Quote
Old 11-02-2017, 04:08 PM   #4
1977 28' Argosy 28
Bloomington , IL
Thanks for the response. I'm trying to workout how to make this old gal more liveable in the winter months. I appreciate the responses!
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Wheel well crack and insulation question vhord Wheel Wells 14 05-21-2009 04:16 AM
Question about insulation netlace Exterior Storage Compartments & Access Doors 7 11-25-2008 11:49 AM
Spray Foam Insulation Question Gkiesel General Repair Forum 3 04-08-2008 01:08 PM
