Old 10-26-2012, 04:57 PM   #1
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
'76 Argosy 24' Wiring
Does anyone have a wiring diagram for a 1976 Argosy 24 motorhome? I am trying to get mine to start and I cant seem to get it to crank or any power at the dash. If I connect to the solenoid with the battery cable and I get no power on the dash. If I connect to the diode that separates the start battery with the cabin battery then I can get dash power. If I had a schematic of how this thing is wired then I think it would be a lot easier for me.
Matt
mprokop87 is offline   Reply With Quote
Old 10-26-2012, 06:28 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
afaik, this is close as you'll come, unless someone else has it in an original manual - http://www.airforums.com/forums/f310...tml#post827192
thank Brad K for his post....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is online now   Reply With Quote
Old 10-26-2012, 07:46 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Matt I can't speak directly about your Argosy but I have chased more than a couple of demons in my '82 280 Airstream. The frustrating thing is Airstream puts out a fairly decent wiring diagram for the coach and GM puts out good diagrams for the chassis but nobody has anything to say about where the two systems connect. On my 280 there is a wire bundle under the drivers seat to the left of the engine. The fusible link between the battery lead on the starter and the amp meter on the dash lives in this bundle. The ignition and all power to the dash goes through this link.
I would start at the battery terminal on the starter and try to follow that to the amp meter If you can get 12 volts to the amp meter the rest should come fairly easy.
Good luck, Dan
Old 10-29-2012, 04:52 AM   #4
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
Thanks everyone for your replies. JM2's link to the color coded schematic has helped a lot, although I have not found the issue yet. There is some corrosion in there that I think has caused the main power wire to the fuse block to become bad. I am going to try to go through it more this week.
Matt
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
Argosy Wiring problem Glang227 Electrical - Systems, Generators, Batteries & Solar 7 08-21-2011 04:57 PM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
