Old 07-01-2019, 11:01 AM   #1
jdallgor's Avatar
1975 24' Argosy 24
Boise , Idaho
75 Argosy 454 Engine AC
Can anyone post pictures of the AC mounts for the A6 compressor used on the Argosy with 454 engine. The previous owner removed and discarded them. Looking for GM part numbers to replace. We have 24" twin.
John
jdallgor is offline   Reply With Quote
Old 07-01-2019, 02:30 PM   #2
John,
Welcome to Airforums!
The original brackets for 75 were made of cast iron. Below are pictures from Yuki's 77 and Martin's 75.
I'm pretty sure I have a complete set in a box somewhere in my shop. The trick is finding it. I also have a 75 24' Argosy parked behind my shop that has a set that might be available as well.
Old 07-01-2019, 04:43 PM   #3
jdallgor's Avatar
1975 24' Argosy 24
Boise , Idaho
Thanks Brad,
I would certainly be interested in getting the parts necessary to reinstall the AC. The only thing he did not remove was the under dash evaporated and such. I am in need of everything else and have been having a heck off a time. Found this forum and glad I did.
ID:	345104   Click image for larger version
Old 07-01-2019, 06:51 PM   #4
GREEN ARGOSY's Avatar
1977 20' Argosy 20
Matsubushi , Saitama
Name:	Air compressor brackets.JPG
Here is an illustration of the air compressor which described in 1974 Chevy Light Truck Service Manual. 1977 service manual has shown same one as well.
However it doesn't say those parts number..
I use those brackets and an A6 compressor on my 1977 Argosy 20.
Yuki
GREEN ARGOSY is offline   Reply With Quote
Old 07-02-2019, 07:28 AM   #5
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
If you can't find the brackets, you can go aftermarket , with a sanden ac setup. I think jets or summit has it. Now it'll be for something like a 70 chevelle, but the 454 was the same. The belts would also be the same. No serpentine belts at that time. You get in the kit, the ac compressed, the mounts. I don't know if you get the hoses and that stuff. It's an option. DJ
davejay is offline   Reply With Quote
Old 07-02-2019, 08:22 AM   #6
1977 24' Argosy 24
Space Coast , Florida
Thanks Brad, I was just coming back with pictures to share that were not nearly as good as yours
mikeajana is offline   Reply With Quote
Old 07-02-2019, 09:15 AM   #7
My biggest problem with pictures is I have so darn many of them they are getting hard to find when I need look at one!
I remembered where the box of brackets is, up in the barn loft. I'm going to crawl up there this afternoon to dig them out.
Old 07-02-2019, 11:35 AM   #8
Here's what I've got for brackets. Looks like the complete set minutes bolts.
ID:	345184Click image for larger version
Old 07-02-2019, 01:03 PM   #9
jdallgor's Avatar
1975 24' Argosy 24
Boise , Idaho
Brad,
I am interested in the brackets I live in Boise Idaho, figure out what you have to have for them and give me a call 412-225-6645 and we can work something out.
Regards,
John
If I can't fix it it isn't broke it is junk.
Old 07-12-2019, 02:29 PM   #10
jdallgor's Avatar
1975 24' Argosy 24
Boise , Idaho
Thanks Brad,
Received the brackets going to get them cleaned up and installed then work on getting the rest of what is missing.
John
Old 07-12-2019, 04:56 PM   #11
Super. I'm glad they are going to be put to good use
Old 08-07-2019, 05:51 PM   #12
jdallgor's Avatar
1975 24' Argosy 24
Boise , Idaho
Brackets
I just have to say what a pain in the ........... Installed the engine brackets for the AC. Pam and I are making progress, really sucky issue with new Dometic 5 cubic ft fridge all installed and doesn't flipping work. Dometic is sending us to factory authorized warranty repair place here in Boise. Have heater, water heater and the majority of the plumbing up and running. Need to replace both of the Thetford valves old cracked and broken. Special thanks to you, I have ordered an received most all of the parts to complete the AC installation. I am sure there are more trials and tribulations to come in our quest. Retirement is only days away 2 months and 10 days to be exact.
Regards,
John
Old 08-07-2019, 06:04 PM   #13
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
When you get a minute or two John, post up some pictures of your rig.....we love pictures
mayco is offline   Reply With Quote
Old 08-08-2019, 09:28 AM   #14
Regards,
John
John, with the engine sitting in place that certainly would be a pain!
Like Mike suggested, post some pictures of your doings.....
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 05:59 AM
454 engine in Argosy MH RoadRoman Mechanics Corner - Engines, Transmission & More... 37 08-28-2016 10:21 AM
Question on 454 MH Engine RonJudi Mechanics Corner - Engines, Transmission & More... 7 01-20-2004 10:54 AM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Argosy 454 engine repair in Amarillo TX saxonsraven General Motorhome Topics 5 08-01-2003 05:08 PM
