Old 03-24-2010, 02:02 PM   #1
1980 22' Caravelle
1975 20' Argosy 20
woking , surrey
'75 Argosy 20' door lock probs
THe door lock does not lock anymore. Now I have been looking at the L-300 as a replacement, however it looks as if I will have to do some cutting as the (what is its name??!!) metal bit which comes out to lock, is not ctr of the lock but a bit lower on the L-300. Is there a better replacement?
thx
Wiebe
turfclubroad is offline   Reply With Quote
Old 03-24-2010, 02:35 PM   #2
thx
Wiebe
75 20 foot trailer or motorhome?
They use different locks.
Old 03-24-2010, 02:59 PM   #3
1980 22' Caravelle
1975 20' Argosy 20
woking , surrey
20 foot motorhome.
Wiebe
Old 03-24-2010, 04:12 PM   #4
20 foot motorhome.
Wiebe
You have to carve on the door a little, but you must also use the motorhome striker pocket, so that the striker bolt proper engages.
Old 03-24-2010, 07:23 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you say it doesn't lock any more. Do you mean it doesn't "latch" or doesn't "lock". If it is like my '74 Argosy, it is a very simple lock. I disassemble mine to solve a problem where the outer handle wouldn't open the latch, but the inside handle worked. I was able to make the necessary repairs in just a few minutes. What can you lose if you take it apart, it doesn't work now. Right?
Old 03-26-2010, 09:44 AM   #6
Dr.Theopolis's Avatar
1977 24' Argosy 24
St. Augustine , Florida
I had a problem with my lock not locking too. I just replaced the lock a couple of weeks ago. But for months before that, I came up with a temporary solution for allowing my lock to stay locked.
Mine had a little pin under the handle that slides up and down - up to lock. It wouldn't stay up - gravity kept pulling it down. So I tied a little elastic string around it and the handle to keep it up but allow it to go down when using the key to unlock it. It worked ok, but I had to put the key in the door anytime I wanted to open or shut the door - because the elastic string kept it locked at all times except when using the key.
I replaced the lock with a different style, and I had to do quite a bit of cutting to get it in. I used a jig saw to make the hole for the lock bigger, and a dremel tool with a cutting wheel in a few areas requiring more delicacy.
Dr.Theopolis is offline   Reply With Quote
Old 03-29-2010, 12:53 AM   #7
1980 22' Caravelle
1975 20' Argosy 20
woking , surrey
It is a hartmann lock, are there still cilindres for the lock? The latch from the inside does engage and it locks, the keyhole though was covered with alu tape and I did not get a key....
thx
Wiebe
Old 03-30-2010, 08:07 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It sounds like you are not able to lock the door with a key since you don't have one. A key that is. It isn't that the door won't stay closed or latched. The lock assembly on my Argosy has a total of 7 screws that hold it in the door. I had to remove the inside handle (1 screw), the inside door locking lever (1 screw), 4 screws on the inside of the door that hold the lock mechanism in place and 1 screw on the edge of the door near the bolt.
If you can remove the entire assembly you can take it to your local locksmith, he may be able to replace the cylinder with a new one that has a key set.
Good Luck
cartridge replacement probs for shower gnowlin Sinks, Showers & Toilets 0 03-05-2013 06:11 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
1999 cutter any probs Dianne&Bob Member Introductions 0 03-01-2009 05:21 PM
Electric Probs w/ Fridge, Help! silverpeanut Refrigerators 6 05-24-2007 08:19 PM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
