Old 09-26-2012, 05:51 PM   #1
'74 Argosy MH potable water door key
After checking all of the keys that came with my Argosy I find that I do not have a potable water door key. Any suggestions on where to locate a key that might work?
Thanks!
Old 09-26-2012, 05:56 PM   #2
1982 28' Airstream 280
Redwood City , California
We can all send you a copy of ours!
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-26-2012, 06:15 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It looks like the same one for my '75 Argosy trailer. Out Of Doors Mart sells them for $6.95, that may be cheaper than someone having a copy made and sent to you, because it's a hard-to-find key blank, at least for locksmiths around here. And I went to old-school serious locksmiths, not the con artists who unlock car doors.
OMDRV Water fill key listing
David
Old 09-26-2012, 06:21 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
The oldest locksmith who looked at mine called it a "Double-sided Illinois" key, and indeed the blank is an ilco IL-1
David
Old 09-26-2012, 08:51 PM   #5
Wow! I didn't think I'd get help this quick
Dean, I appreciate the offer but I took DKB_SATX advice and just ordered one from Out of Doors Mart. I needed a few other things so I managed to place large order
If the key doesn't fit I'll take you up on your offer to see if yours would work. I'll keep you posted.
DKB_SATX, thanks for the lead on where to find the key. Much apprecited!
One other question, is there supposed to be something plugging the fill pipe to keep dirt and crap out? Mine doesn't have anything to protect the opening but the door itself. I didn't see anything from OODM that might do it.
Thanks!
Old 09-26-2012, 09:02 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Thanks!
Chlorinated water and a good pump filter are your friends.
Mine's on the front panel about waist high, so the truck probably kicks up dust for it too. I generally carry gallon jugs of drinking water for taste reasons, but I wouldn't be afraid to drink out of the fresh tank as long as I fill with chlorinated city water or dose with a little bleach if it's clean-but-untreated water going in.
If you want extra protection I guess you could put a cork in the fill and overflow openings, but don't jam it in there too tightly and don't forget to pull them both before trying to fill.
David
Old 09-26-2012, 09:18 PM   #7
Oh wow! Nothing to cover the hole, that's amazing.
I think I'll find something to stuff in there if nothing else to keep bugs out. I plan on pulling out the fresh water tank while I do some refurbishment work inside so I guess I'll get a first hand look of might might have made it's way into the tank.
Thanks for the info!
Old 09-26-2012, 09:49 PM   #8
Damn, no one ever gets my jokes!
Old 09-27-2012, 06:39 AM   #9
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Thanks!
Brad,
Is there a number on the lock itself? It might be hidden under the paint. That would indicate the key code.
-Fred
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 09-27-2012, 06:59 AM   #10
Oh...
I just noticed the "all" in your post above. My excuse is I've been distracted lately and that's my story and I'm sticking to it
Old 09-27-2012, 07:00 AM   #11
Originally Posted by 1985air345 View Post
Brad,
-Fred
Fred,
I'll try scraping some of the paint off tonight or tomorrow to see if it has any markings. I did order a key from OODM and I'm betting it fits.
Old 09-27-2012, 07:43 AM   #12
Well that bites
I just went out to look for a key number on the lock (this time with my glasses on) and not only did I not find a key number I found that the reason the door was open but still locked is because someone pried the thing open with a screw driver. It cracked the upper housing when it gave way.
Fortunately not all is lost. We have an old 1974 Excella 500 trailer that has been gutted and we use it for storage plus we've used it in two moves, one from Texas to Arkansas and then from Arkansas to Kentucky. I checked and the Excella has the same Thetford assembly
So one of my primary tasks this weekend will be to remove the one from the Excella trailer.
Sometimes things work out ok in the end. Oh, and I do still need the key I ordered since we never had one for the Excella
Old 09-27-2012, 08:13 AM   #13
DKB_SATX's Avatar
1976 Argosy 28
Back when I was searching for that key, at least one person advised me to just pry it open. Several suggested I just jam a screwdriver in the key hole and break that part of the lock. I'm pretty happy with having the right key, personally.
David
Old 09-28-2012, 09:49 AM   #14
Prying it open is definitely not the way to go. I took a quick peak down the fill pipe last night and there are all kinds of bug debris and dirt. If I had any doubts about removing the fresh water tank before I don't have any now.
Thanks for all our help
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 03:39 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 05:49 AM
May day! May day! I have a leaking Argosy bpappas Argosy Motorhomes 6 08-08-2011 10:00 PM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 08:02 PM
Grey water...where does it go? KyMoonshine Plumbing - Systems & Fixtures 10 03-21-2011 05:12 PM
