Old 04-29-2016, 06:48 PM   #1
1974 24' Argosy 24
bay city , Michigan
74 argosy 24' brake questions.
Hello.
Trying to locate any diagrams of the brake system, have to replace break lines and would like to know which is front and which is rear on master cylinder, also where the connectors are, not having the best of luck finding any info on brakes for the argosy or for the GMC its built on, thanks for any help.
Trkenn is offline   Reply With Quote
Old 04-29-2016, 07:55 PM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by Trkenn View Post
Hello.
Hi Trkenn, welcome to the forum.
The complete chassis manual is available here....
http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
Section 5 has the full brake diagram.
martin300662 is offline   Reply With Quote
Old 04-29-2016, 08:04 PM   #3
Welcome to Airforums
You've probably already realized that getting access to the brake lines in the front is almost impossible. In the past few weeks I've been going through the brakes on a 77 20' Argosy and also have my own 20' Argosy that has all of the brake components removed. I do have a bunch of pictures that I can post to help give you an idea of how the brale lines look up front.
Tomorrow I will probably have the radiator out of the 77 and can get detailed pictures as to which brake line from the mc goes where.
Old 04-29-2016, 08:27 PM   #4
1974 24' Argosy 24
bay city , Michigan
thanks that might help. im trying to replace the front lines and i am having trouble tracing them back to the master cylinder they usually t off somewhere then back. fairly simple to replace just need to know where they all go.
Old 04-30-2016, 03:11 PM   #5
Keen amature
1975 20' Argosy 20
Chestfield , Kent
That's because they go to the proportioning (combo) valve after the MC, and the proportioning valve outlets head off to the brakes.
Old 04-30-2016, 03:20 PM   #6
Based on Martin's picture of the proportioning valve and this picture of my original brake lines it would appear the front pipe on the M/C is for the front brakes.
And speaking of proportioning valves, any idea on where to find a replacement for a 74 P30?!
Mine needs to be replaced.
Old 04-30-2016, 04:05 PM   #7
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I think they are fairly standard for 1 ton JB8 brake setups (JB8 is the hydroboost, front disc, rear drums vs JB9 for discs all around).
I was told the JB9 has a different spring due to a different brake bias between front and back and the proportioning valve needs to be changed if you ever have to upgrade to rear discs.
Dan the mechanic who repaired my brakes sourced one direct from his normal parts place.
Old 04-30-2016, 05:07 PM   #8
Looking through my 73-87 GM parts books I found two different numbers that seem to correspond to my chassis. Looks like about $80 or so plus shipping.
Guess I better get one on order.
Thanks.
Old 04-30-2016, 06:45 PM   #9
1974 24' Argosy 24
bay city , Michigan
thanks everyone
Turns out everything that was sent was a big help. Happend to be a new to me type of system, never seen one that ran through the power steering before, nice to know something old can show you something new.
Old 05-02-2016, 06:47 AM   #10
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I can confirm that the line further forward on the MC is for the front. It should be coming out of the bigger reservoir (open the cover to check which is bigger) because it goes to calipers VS the drum brakes.
I just went through my brake system because I had to replace the hydraboost unit and master cylinder. Those front lines are a bit of a pain to get at but it can be done!
mprokop87 is offline   Reply With Quote
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
BRAKE-RITE II SD or BRAKE-RITE EHB Dwight Brakes & Brake Controllers 8 01-30-2012 06:06 PM
Ford or Chevy OEM Brake Controllers with Elec-Hyd brake equipped Airstreams? JFScheck Tow Vehicles 30 11-10-2011 11:29 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
