01-16-2017, 06:50 AM
#821
Richmond
, Kentucky
Originally Posted by martin300662
My view is, it's the same amount of trouble just squeezed into a smaller volume so everything is more difficult to get to!
YEAH, what he said....
1975 24' Argosy Motor Home
01-16-2017, 09:31 AM
#822
1982 31' Airstream 310
champaign
Now that's funny right there!
01-16-2017, 09:04 PM
#823
Dazed and Confused
Hillsburgh
, Ontario
You know better than to feed the Argosy trolls Mike!
How hard can it be to work on those Argosy rigs when they fit into everyones garage and you can work on them year round. I've only got three months, up here in the Great White North and it takes five minutes to skid along the ground until I get to the other end
I guess we were just smart to get diesels; right Mike?
Cheers
Tony
01-17-2017, 05:28 AM
#824
Richmond
, Kentucky
Think about it Tony, if you had one of these 20' beauties you too could work year round on keeping it in tip top shape and the bonus is they are so light weight you wouldn't need a diesel....
Just sayin...
01-17-2017, 06:28 AM
#825
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Still need the same 10ft wide/12ft high minimum opening, so unless you have a dedicated workshop you are still working on your back in the cold and wet.
Sounds like the solution for everyone is to move to Austin!
01-17-2017, 07:19 PM
#826
Dazed and Confused
Hillsburgh
, Ontario
I would be in, except I don't like civilians packing heat, so I'm out. Belize is my dream getaway as I know the jungle intimately and they don't allow civvies to conceal and carry.
I still want to paint my Airstream and change the name to Argosy.
Cheers
Tony
01-18-2017, 05:10 AM
#827
Richmond
, Kentucky
Cheers
Tony
Tony, I have some spare ARGOSY rivet on logos that I'd be happy to donate to the cause
01-18-2017, 05:19 AM
#828
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Cheers
Tony
Austin is not really Texas and we hardly ever leave the reservation
We need you down here and you will fit right in with your painted Airstream turbo Diesel
Keeping Austin weird
AIR #13
01-18-2017, 05:22 AM
#829
Richmond
, Kentucky
Over the past few weeks I've been tinkering with odds and ends, nothing major just little road blocks to moving on to the next phase which is installing the radiator.
One thing that was stopping me from installing the radiator was the boot that goes over the brake pedal push rod. In the first two pictures you can see what the condition of the original boot looked like and what I did to fabricate a replacement. Martin came up with the idea of using a motorcycle fork boot and it looks like it's going to work just fine. The only real issue with the fork boot is the smaller hole that is supposed to clamp to the push rod is 1.25" in diameter and the rod is .70" in diameter. I had to make up a rubber spacer to between the rod and the boot. All that's left to finish the boot installation is to install a clamp on the boot to clamp it to the rod. Next...the radiator!
Something else that is now complete is the rework of the dash. It was a real challenge but I'm very happy with how well it turned out. Now if I can get the dash top to look as good I'll be even happier!
01-18-2017, 06:48 AM
#830
champaign
Cheers
Tony
On the road in rural Kansas, 800 miles from home, I refuse to say how happy I am and how fortunate to have this Isuzu DIESEL under the hood. So few troubles and with simple love and routine maintenance she just goes and goes and goes. Plenty of power for the most part and dependable as can be. BUT, I refuse to mention these things here because I'm afraid it may jinx me.
01-18-2017, 06:51 AM
#831
champaign
Brad that dash looks absolutely awesome!! Nice work.
01-18-2017, 08:27 AM
#832
Richmond
, Kentucky
Thanks Mike! It was a challenge that I was really really worried about. A crappy looking dash makes everything look chincy
01-20-2017, 09:54 AM
#833
Geismar
, Louisiana
It came out great! Looks like you went with a brushed look in the center only? I like the contrast. That was some good practice before you start on the instrument cluster.
The boot idea was awesome! It looks like it is going to work great. Go Martin!
01-20-2017, 12:39 PM
#834
Richmond
, Kentucky
Dane, you're right I only brushed the center section. I tossed around the idea of doing it all brushed and then decided I liked the contrast.
Martin's idea of using the motorcycle boot worked out very well and hopefully will last longer than the original piece
02-18-2017, 04:46 PM
#835
Richmond
, Kentucky
Not much happening on my Argosy due to trying to get my TR6 chassis assembled into a rolling chassis ready to accept the freshly painted body.
However when Ernie stopped over this morning to start working on Peanut we spent 10 minutes setting the radiator in place
I've owned this Argosy since mid 2007 and this is the first time I've ever seen a radiator installed in the chassis! Little by little it's getting done
02-18-2017, 05:29 PM
#836
Airstream Driver
1994 30' Excella
Austin
Attachment 280054
Of course I have to ask, which way do the fans move the air??
AIR #13
02-18-2017, 05:38 PM
#837
Richmond
, Kentucky
Back when you were sorting out the direction problem with your fans I checked mine when the engine was still on the test stand. I had the running the engine for a while and then shut it down and turned the fans on. I could feel warm air being blown through the radiator towards the engine so I'm fairly certain they are blowing the right way!
02-27-2017, 07:02 AM
#838
Richmond
, Kentucky
I've had a few requests for pictures of the TR6 I'm in the process of restoring so here's a few to give you an idea of what stage the project is in.
I don't have an up to date picture of the frame. Currently the front suspension is installed along with the brake lines. I'm working on the rear suspension at the moment.
By the end of this week the body, fenders, doors, boot and bonnet will likely be color coated.
The engine and transmission are being rebuilt and I should have them back sometime in early April.
02-27-2017, 07:14 AM
#839
champaign
Geeeezzzzzzzzzzzzzz Louise Brad! You're amazing!
02-27-2017, 07:29 AM
#840
Richmond
, Kentucky
Mike, that's not my work! I don't do body work so I farmed that out to Ernie and I don't have time to do the engine or transmission so that was farmed out to some friends in Ohio.
I'm just doing the frame and bolting things back together, you know, the easy stuff
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
