09-08-2016, 08:46 PM
#681
1977 20' Argosy 20
Arlington
Gates Hose P/N's for 1977 model: Probably the same for previous years.
Upper Molded Hose Gates 20868
Lower Flex Hose Gates 26612
Gregg
09-09-2016, 10:04 AM
#682
Richmond
, Kentucky
Well to put it bluntly, the E70735 hose will not work as a lower radiator hose for the vertical radiator rigs. Not even close
However, I'm fairly certain it will work as the upper hose which is how Autozone advertises it. I couldn't quite get it next to the hose that is installed on Peanut but after looking it over I think it will work. I should be installing my radiator in a few months at which time I'll give it a try. Due to the various curves it may have trouble with some engine configurations.
Not sure why the Winnebago crowd lists this as fitting a Winnebago unless there is something radically different about them compared to the P30 chassis Airstreams and Argosies.
1975 24' Argosy Motor Home
09-09-2016, 10:07 AM
#683
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Sorry for the bad steer Brad, but I think it was worth a try.
09-09-2016, 10:08 AM
#684
Richmond
, Kentucky
The hoses that I installed on Peanut are 25808 and 26612.
09-09-2016, 10:33 AM
#685
Richmond
, Kentucky
No bit deal. If it works as an upper hose I'll be happy. If not I can return it as long as its never been installed.
It's always worth while checking out leads for replacement parts!
09-12-2016, 10:13 AM
#687
Richmond
, Kentucky
I'll probably order one of these as well. Once the radiator is installed I can check the fit of both the upper and lower hoses. It would be nice to find molded hoses that work rather than the generic replacements.
09-12-2016, 10:24 AM
#688
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Not sure if they are available in the US, but in the UK there is quite a selection of companies making performance silicone hoses (for example http://www.viperperformance.co.uk/).
There is a cost to get the initial mandrel made but after that the actual cost of a 'perfect fit' high performance hose isn't too made.
09-13-2016, 02:03 PM
#689
Richmond
, Kentucky
I think I looked into something similar several years ago when I was trying to find a replacement lower hose. The place I ended up talking to required too large of a run to make it worth while.
It would be interesting to know if volume requirements would be less in the UK?
09-27-2016, 05:19 AM
#690
Richmond
, Kentucky
Just a quick update. I haven't really made any progress on the Argosy for the past couple of months for a variety of reasons and it looks to be another few weeks before I really start into it again. One thing I needed to get done was the final prep of my TR6 so it could be taken to the body and paint shop.
The last thing I had to do was to hot pressure wash the whole tub and chassis to get rid of grease and grime. I'm happy to say the car is now at the body shop having the various small dings and dents removed and is being prepped for paint
I had hoped to have the drive line on the Argosy completed by Thanksgiving. That still might happen but that also means I would actually have to get busy again! We'll see if that happens
09-27-2016, 06:25 PM
#691
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The 6 looks great Brad.
British Racing Green?
09-27-2016, 06:26 PM
#692
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Forgot to add, the shop that installed my electric fuel pump had a silver 7, convertible, sitting for sale....I was tempted until I read the note on the dash that said 'DON'T USE THE BRAKES!'
09-27-2016, 06:52 PM
#693
Richmond
, Kentucky
Damson, which is the original color. The PO painted it gray and regretted it afterwards. I really like the Damson and decided to go through the effort to put it back to the original color.
09-27-2016, 06:54 PM
#694
Richmond
, Kentucky
Brakes are easy and cheap to fix There is a large contingent of Triumph owners in that part of the country as well.
10-23-2016, 11:39 AM
#695
Richmond
, Kentucky
I finally took some time this weekend to tackle a task that I've been dreading for months now Removing the differential and leaf springs so I can paint the rear third of the chassis and replace the leaf springs with new ones.
Overall the removal process went surprisingly well. First thing I did was set up a support structure under the frame near the front shackle holders. That got the wheels off the ground so I could remove them. With the wheels off I set a furniture dolly under the diff and use it to cradle the differential while I used a cutting torch to clip the top leaf near each of the shackle bolts.
With the diff out front under the chassis I can hot pressure wash it, paint it and replace the pinion seal.
The only hitch during the whole process was the right rear shackle bolt. It was rusted solid to the steel sleeve inside the rubber bushing.
I tried using a sawazll but the steel bushing is so hard it just dulled the blades in no time. I had to resort to using a cutting torch and just basically started burning and cutting until I was able to pull the pieces out. I did have to use the fire extinguisher once because the rubber wouldn't stop burning. Last thing I wanted to do is burn up my Argosy and the shop
10-23-2016, 05:01 PM
#696
1977 23' Safari
Niagara on the Lake
, Ontario
Good work,
I wouldn't have enjoyed that job either, you'll feel relieved when it's done.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
10-23-2016, 05:22 PM
#697
Dazed and Confused
Hillsburgh
, Ontario
A doctor on SSI when I was growing up had a 7 and eventually traded it for the 8. The 8 was a very nice car...........when it worked.
For some reason I've always been partial to the 4/5; that and Jaguars.
Cheers
Tony
10-23-2016, 07:15 PM
#698
Richmond
, Kentucky
Originally Posted by AldeanFan
Good work,
Yeah, there are some jobs that I just dread tackling and that was one of them
10-29-2016, 06:19 AM
#699
Richmond
, Kentucky
Here's another issue I noticed a long time ago but avoided looking at closer for fear of what I might find.
This is the hitch frame assembly that is welded to the bottom of the truck chassis. By design it's actually a fairly stout frame. Unfortunately the way Airstream made the frame they left the ends of the tubes open which allowed road debris to get packed into the exposed insides of the tubes. 42 years of having that crap packed inside the tubing allowed it to rust away from the inside
Simple welded on end caps would have prevented this mess. As it is I'll have to cut the whole assembly off, fabricate a new one and weld it back in place.
Oh well, I guess it gives me something to do for the next few weeks
10-29-2016, 04:20 PM
#700
Richmond
, Kentucky
