01-27-2018, 05:04 PM
#1161
Richmond
, Kentucky
Spent a little time yesterday and more today working on the rear storage compartments and the steel wheel well and generator covers. The rear compartments are a pain to work on. Lots of cutting and fitting to get everything in place. I've got about 7 hours so far rebuilding the two compartments and I probably have about 7 more to go.
The original generator cover was steel but it was light gauge and the flanges were rusted badly in places. The new generator cover is definitely an upgrade.
The new steel wheel well covers are replacing the cracked ABS original plastic pieces. The new ones are definitely stouter than the originals
Tomorrow I would definitely like to finish up at least one of the storage compartments. We'll see how it goes.....
1975 24' Argosy Motor Home
01-28-2018, 07:46 AM
#1162
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
It maybe taking some time Brad, but the results look great!
01-28-2018, 07:58 AM
#1163
Dazed and Confused
Hillsburgh
, Ontario
You are keeping track of your labour hours, right?
I can't wait until you give us your feedback on the use of Coosa board.
Cheers
Sidekick Tony
01-28-2018, 09:44 AM
#1164
Richmond
, Kentucky
Martin, the shiny new steel does a good job of hiding the ugly stuff!
Tony, yep I'm keeping track of my hours and the numbers are getting scary
I'd really like to have the Coosa board installed before the end of February but I'm not holding my breath. Unfortunately I've missed way to many target dates as it is.
01-28-2018, 12:29 PM
#1165
2007 22' International CCD
Corona
Deadlines makes such a nice ‘wooshing’ noise as they go by.
01-28-2018, 03:57 PM
#1166
Richmond
, Kentucky
Yep! And sometimes they are at hurricane force
01-28-2018, 04:14 PM
#1167
1982 31' Airstream 310
champaign
Deadlines! We dont need no stinkin deadlines!
01-29-2018, 04:28 AM
#1168
Richmond
, Kentucky
For those of us who are NOT retired (yet!) deadlines are an unfortunate part of life
I've tried to set deadlines for getting the Argosy done because I'd like to have it completed before I die.....
01-29-2018, 06:16 AM
#1169
Corona
'74 Argosy 20' Motorhome restoration/rebuild
Sometimes deadlines are a part of life for semi-retired folks like me. I just try to avoid having too many of them. Last week had one that fought me tooth and nail getting the stuff done before Friday. Beat it to submission by noon. 2 1/2 day weekend as a reward! I ❤️ my job...
Spent the weekend in the garden. Unusually warm weather in some parts of SoCal...now if we could have fewer airplanes landing on freeways, it would be perfect. Nicely done power-out landing that involved going under an overpass. No damage, no injuries. Great landing...I’m sure a ‘laundry problem’ was involved, however[emoji3]
01-29-2018, 09:45 AM
#1170
1982 28' Airstream 280
Port Angeles
Brad I have been told that I am not allowed to die until all my projects are done.
Cheers, Dan
~ Margaret Thatcher ~
01-29-2018, 10:09 AM
#1171
Richmond
, Kentucky
When I pull the plug on working I don't plan on being semi-retired. Whole hog or nothing for me!
Video of that landing would be something to see that's for sure!
01-29-2018, 10:19 AM
#1172
Richmond
, Kentucky
By that definition then I should be d@mn near immortal
01-29-2018, 10:35 PM
#1173
Corona
Ditto on that one....DW just keeps coming up with more projects
02-13-2018, 03:30 PM
#1174
Richmond
, Kentucky
Spent a little bit of time Sunday working on the rear compartments. I'm getting closer to being able to call them complete. I probably need another 6 to 10 hours and they will be done.
I took a short break from working on the compartments and was looking at how to deal with the opening in the wall from the old auxiliary fuel tank filler neck that I scrapped when I when to a larger main tank. The opening is none to pretty to say the least.
Other than just covering the opening with a section of aluminum sheet I been toying with the idea of installing the exterior electrical box that I salvaged from the 345. Unfortunately the opening is oriented vertically instead of horizontally.
The one option that will work is to rotate the electrical box 90 degrees so the lid opens from the side like kitchen cupboards. So, does this look wrong and/or out of place?
Any thoughts or suggestions?
Thanks!
02-13-2018, 05:45 PM
#1175
champaign
It looks just fine. With the lid closed it could be a number of things, looks factory installed.
02-13-2018, 05:49 PM
#1176
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Looks fine to me as well!
02-13-2018, 07:29 PM
#1177
Dazed and Confused
Hillsburgh
, Ontario
If it works, use it. I'm all for repurpose and reuse.
Cheers
Sidekick Tony
02-14-2018, 04:32 AM
#1178
Richmond
, Kentucky
Cool, thanks for the feedback!
Using the outlet box in the vertical orientation definitely saves me a bunch of time and labor.
Thanks again
02-14-2018, 05:01 AM
#1179
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Thanks again
Looks good and probably much easier to reach the plug than on the flip UP outlets. One little concern would be the rain water flow. Both the lid and the weatherproof outlet lids flip up. But Shepherd57 would say, you worry and think to much, Peter...
AIR #13
02-14-2018, 05:44 AM
#1180
Richmond
, Kentucky
Peter,
My assumption is just because a socket lid flips up doesn't mean that water doesn't get inside the outlet. As we've seen on these rigs water seems to find a way into even the smallest of pin holes, gaps, etc. from just about any angle. I guess as often as I plan on using an extension cord I should be ok!
Besides, I'm considering moving to the South West one of these days so rain may not be an issue
