Old 10-31-2016, 03:59 PM   #701
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I'm pretty sure Bella has the same extensions to the main chassis Brad. It also seems to be shown in the 1977-78 manual cut away.
martin300662 is online now   Reply With Quote
Old 10-31-2016, 04:38 PM   #702
I just looked at the rear of Peanut's frame. It's similar in construction but different in some aspects. The hitch frame on mine was fabricated out of 2"x5" tubing. The hitch frame on Peanut was fabricated from custom bent 2"x5" channel. At least that saved Peanut from rusting away like mine did.
ID:	274619Click image for larger version
Also the GM frame on Peanut is one piece where mine has a 10" section of U channel welded onto the end of the truck chassis. You can see in the picture there is no seam in the truck chassis frame.
After thinking about hitches for a while I think I've decided not to build the same type of hitch receiver arrangement that mine came with. I think I'll either build or buy something similar to this Reese Multi-Fit Receiver.
I think this style of receiver would be a reasonable way to fit a new receiver to Peanut. Some of the propane system piping would have to be tweaked a little and there might need to be some rework on the holding tank drain piping but I think it would be doable and plenty strong for towing.
Old 11-02-2016, 05:14 PM   #703
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Attachment 274619Attachment 274620
Attachment 274618
Attachment 274622
I think you have the right idea Brad. Unless you how some special circumstance that forces you to custom fabricate something the pre-manufactured hitch should be faster and easier. I have started out building something like a simple hitch and 10 hours later thought , why am I doing this? Sometimes simple things get involved fast. You certainly have other tasks to challenge yourself with.
Gregsch is offline   Reply With Quote
Old 11-03-2016, 05:20 AM   #704
Yeah, it's easy to get caught up in the idea that "I can build it cheaper than what I can buy it for"
Been there, done that way to many times! I'd like to buy a hitch that is a straight bolt on for the frame width instead of an one size fits all but it seems hitches are listed by vehicle make/model rather than size. No one lists a hitch for a P30 chassis so I'll likely have to call and ask for measurements before I buy one. If need be I'll buy one of the one size fits all and live with it.
Old 11-03-2016, 06:07 AM   #705
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Nice getting a piece of cancerous rusty metal like that removed.
I would think a well fitting prefabed hitch setup would be the way to go if it doesn't reduce your clearance at the back.
Frame extensions, you should see the multipul extensions on the 345s
There is one added mid frame between the wheels, and a couple at the rear.
Can't really place Jack much behind the rear axels with out tweaking the shell when the extensions flex. Flexie flyers. They are.
Cheers Richard
tevake is offline   Reply With Quote
Old 11-03-2016, 10:43 AM   #706
Clearance issues is one of the reasons I'm hoping to find dimensions of a hitch before I buy it. It will probably take a few calls to the manufacturer to find out for sure.
Cheers Richard
Actually I've seen the frame extensions on a 345, I dismantled one for scrap 3 or 4 years ago. Definitely an interesting way to manufacture something!
Old 11-12-2016, 04:50 PM   #707
Made some decent progress in rebuilding the generator compartment the last couple of days. The original generator was inserted from below and then the frame work was welded into place. That to me was a really stupid way of installing a generator
So I've opted to install the generator on a sliding drawer similar to how I did my old 310 generator. The early front bath Argosy has the generator compartment in the rear. Instead of orienting the generator side ways as is typically done Airstream inserted the generator length wise in the compartment. I had originally planned on using an Onan 4.0 but found that it was to large for the compartment. As it turns out the Onan 6.5 from the 345 is physically smaller than the 4.0.
The last two days were spent fabricating brackets, etc. for the tray slides. The hard work is pretty much done, now I just need to drill a lot more holes for various bolts and cut a piece of metal here and there and then take it all back apart so I can paint everything.
Anyway, here's some pictures of what it looks like at the moment.
ID:	275312Click image for larger version
ID:	275313Click image for larger version
ID:	275314Click image for larger version
Old 11-12-2016, 09:03 PM   #708
Geismar , Louisiana
Looking pretty good sir. Those drawers can support the weight of the generator easily? They look pretty beefy.
Dane
Danec020 is offline   Reply With Quote
Old 11-12-2016, 11:49 PM   #709
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Big improvement on the original Brad!
Old 11-13-2016, 05:17 AM   #710
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You da man Brad!
Curious, when the generator is on the slide, do you disconnect the exhaust and electrical feed when sliding it out for maintenance? I suppose you could use a plug of some sort for the electric. As you know, on my 310, I cant access anything on the back of the generator as it is. I was surprised I could even change out the points. Great work Brad, you must be getting pretty good at this mod!
mayco is offline   Reply With Quote
Old 11-13-2016, 05:32 AM   #711
Dane
Dane,
The drawer slides are rated at 500 lbs for stationary equipment and 300 lbs for mobile equipment. The Onan 6.5 weighs in around 260 or so. When the drawer is in the "in" position I will be clamping it in place so the slides won't have to deal with road impacts or the suspension trying to bounce it around.
I think the slides cost around $150 for the pair. They are considered full extension slides but even when fully extended the generator will still have about 2" inside the compartment.
Considering the location and the orientation of the generator it still won't be the easiest to work on but it will be a darn sight better than if it was welded in place!
Old 11-13-2016, 05:46 AM   #712
Originally Posted by mayco View Post
You da man Brad!
Mike,
Yes, the exhaust pipe does get disconnected. Fortunately this generator doesn't use exhaust pipe clamps to connect the exhaust pipe to the generator manifold. It uses a flange at the exit of the exhaust manifold. You just have to bolt the external exhaust pipe to the flange. Much easier than trying to pry apart two pipes that have been clamped together.
Your access problems with the generator are the same reasons I put my old 310 generator on drawer slides. Several years ago while diagnosing a starting problem on the 310 generator I had the drawer slides extended and was able to work on the generator even without the exhaust pipe being connected. It was a little loud but sure made working on it a lot easier
I will be using two pairs of male/female 30 amp connectors to connect the generator to the coach. Basically to slide the generator out the exhaust pipe has to be disconnected and that's it. The two electrical connectors only need to be unplugged if you're removing the generator from the drawer.
Needless to say I'm sorta hoping this is the last set of generator drawer slides I install
Old 11-13-2016, 05:47 AM   #713
The phrase night and day comes to mind
Old 11-14-2016, 08:31 AM   #714
One thing I was faced with was having to fabricate a bottom plate for the drawer I was making. after thinking about it for a while I decided to go the cheap route and cut the bottom out of the original generator tray I salvaged from the 345. A 4-1/2" cutoff wheel on a little hand grinder made fast work of it.
ID:	275448Click image for larger version
ID:	275449Click image for larger version
All that's left to finish up the siding tray installation is to drill 6 more holes, finish welding four brackets together and then paint everything.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
