Old 09-12-2016, 10:13 AM   #687
Originally Posted by martin300662 View Post
I guess there is still the option of the Bronco hose Greg found in this thread?
http://www.airforums.com/forums/f311...mh-110442.html
I'll probably order one of these as well. Once the radiator is installed I can check the fit of both the upper and lower hoses. It would be nice to find molded hoses that work rather than the generic replacements.
Old 09-12-2016, 10:24 AM   #688
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Not sure if they are available in the US, but in the UK there is quite a selection of companies making performance silicone hoses (for example http://www.viperperformance.co.uk/).
There is a cost to get the initial mandrel made but after that the actual cost of a 'perfect fit' high performance hose isn't too made.
martin300662 is offline   Reply With Quote
Old 09-13-2016, 02:03 PM   #689
I think I looked into something similar several years ago when I was trying to find a replacement lower hose. The place I ended up talking to required too large of a run to make it worth while.
It would be interesting to know if volume requirements would be less in the UK?
Old 09-27-2016, 05:19 AM   #690
Just a quick update. I haven't really made any progress on the Argosy for the past couple of months for a variety of reasons and it looks to be another few weeks before I really start into it again. One thing I needed to get done was the final prep of my TR6 so it could be taken to the body and paint shop.
The last thing I had to do was to hot pressure wash the whole tub and chassis to get rid of grease and grime. I'm happy to say the car is now at the body shop having the various small dings and dents removed and is being prepped for paint
I had hoped to have the drive line on the Argosy completed by Thanksgiving. That still might happen but that also means I would actually have to get busy again! We'll see if that happens
Old 09-27-2016, 06:25 PM   #691
Keen amature
1975 20' Argosy 20
Chestfield , Kent
The 6 looks great Brad.
British Racing Green?
Old 09-27-2016, 06:26 PM   #692
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Forgot to add, the shop that installed my electric fuel pump had a silver 7, convertible, sitting for sale....I was tempted until I read the note on the dash that said 'DON'T USE THE BRAKES!'
Old 09-27-2016, 06:52 PM   #693
Damson, which is the original color. The PO painted it gray and regretted it afterwards. I really like the Damson and decided to go through the effort to put it back to the original color.
Old 09-27-2016, 06:54 PM   #694
Brakes are easy and cheap to fix There is a large contingent of Triumph owners in that part of the country as well.
Old 10-23-2016, 11:39 AM   #695
I finally took some time this weekend to tackle a task that I've been dreading for months now Removing the differential and leaf springs so I can paint the rear third of the chassis and replace the leaf springs with new ones.
Overall the removal process went surprisingly well. First thing I did was set up a support structure under the frame near the front shackle holders. That got the wheels off the ground so I could remove them. With the wheels off I set a furniture dolly under the diff and use it to cradle the differential while I used a cutting torch to clip the top leaf near each of the shackle bolts.
ID:	274022Click image for larger version
Name:	74-argosy-torched leaf-spring-ends.jpg
With the diff out front under the chassis I can hot pressure wash it, paint it and replace the pinion seal.
ID:	274018Click image for larger version
The only hitch during the whole process was the right rear shackle bolt. It was rusted solid to the steel sleeve inside the rubber bushing.
I tried using a sawazll but the steel bushing is so hard it just dulled the blades in no time. I had to resort to using a cutting torch and just basically started burning and cutting until I was able to pull the pieces out. I did have to use the fire extinguisher once because the rubber wouldn't stop burning. Last thing I wanted to do is burn up my Argosy and the shop
Old 10-23-2016, 05:01 PM   #696
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Good work,
I wouldn't have enjoyed that job either, you'll feel relieved when it's done.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 10-23-2016, 05:22 PM   #697
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A doctor on SSI when I was growing up had a 7 and eventually traded it for the 8. The 8 was a very nice car...........when it worked.
For some reason I've always been partial to the 4/5; that and Jaguars.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 10-23-2016, 07:15 PM   #698
Originally Posted by AldeanFan View Post
Good work,
Yeah, there are some jobs that I just dread tackling and that was one of them
Old 10-29-2016, 06:19 AM   #699
Here's another issue I noticed a long time ago but avoided looking at closer for fear of what I might find.
ID:	274441Click image for larger version
ID:	274442Click image for larger version
ID:	274443Click image for larger version
ID:	274444Click image for larger version
This is the hitch frame assembly that is welded to the bottom of the truck chassis. By design it's actually a fairly stout frame. Unfortunately the way Airstream made the frame they left the ends of the tubes open which allowed road debris to get packed into the exposed insides of the tubes. 42 years of having that crap packed inside the tubing allowed it to rust away from the inside
Simple welded on end caps would have prevented this mess. As it is I'll have to cut the whole assembly off, fabricate a new one and weld it back in place.
Oh well, I guess it gives me something to do for the next few weeks
Old 10-29-2016, 04:20 PM   #700
Well the worst of the rusted hitch frame removal is done. Three+ hours with a cutoff wheel on a grinder and an oxy/acetylene cutting torch did the job. I've still got several hours of cleanup to do with the cutoff wheel and grinder but with luck I won't have to use the torch again.
ID:	274480Click image for larger version
ID:	274481Click image for larger version
ID:	274478Click image for larger version
ID:	274479Click image for larger version
ID:	274482Click image for larger version
Something I hadn't noticed before is the fact that the GM chassis has been extended 10" by adding a U channel to the end of the existing channel. Now I need to look at Peanut to see if he has the same extension
« Peanut lives on! | Top | - »
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
