Old 07-18-2016, 04:01 PM   #673
Gunter, here's a picture showing how the AC mount is attached to the front of the block.
Old 07-19-2016, 07:02 AM   #674
Gunter, I neglected mention there is also one bolt on the ac mount that is behind the power steering pump. The bolt screws into the cylinder head and I think it can be removed without disturbing the ps pump. Worst case is you can loosen the ps pump and rotate it out of the way to remove the bolt.
Old 07-19-2016, 08:47 AM   #675
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Thanks for the detail information and pictures.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 07-19-2016, 11:20 AM   #676
I've been trying to get as many detailed pictures as I can of the front area of the engine so I have some reference material. Once the radiator is in place you have to work blind after that!
Old 09-08-2016, 12:38 PM   #677
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Talking of installing the radiator. I found a reference showing that GM 343414 (the lower radiator house which hasn't been available for some time) is actually the same as a Drayco E70735, a top hose used in other applications and available from AutoZone. From the pictures it does look similar but is always shown as used for the upper application and looks upside down. Certainly worth investigating.
martin300662 is offline   Reply With Quote
Old 09-08-2016, 01:28 PM   #678
What's odd is when I searched for Dayco E70735 in Google, the first item Google returned was a listing for Autozone and the listing title was "Search Results
Dayco/Hose (Lower) E70735- ReadReviews onDayco #E70735"
but when you open the link Autozine says its an Upper hose.
I'm going to pick one up in the morning and see if it will work. I don't like the generic one that is the suggested replacement. It fit's but I don't like the fit at all. I'll let you know what I find out.
Old 09-08-2016, 08:08 PM   #679
1974 25' Tradewind
Calgary , Alberta
The lower (water pump inlet) hose usually needs a large spring inside it to keep it from collapsing due to the pump suction. If you're getting a new hose and it's not marked as being intended for a lower hose application, then make sure you get a hose spring separately, to put inside there.
Alumineer is offline   Reply With Quote
Old 09-08-2016, 09:37 PM   #680
1977 20' Argosy 20
Arlington , Texas
I purchased Gates replacement hoses form the local O'Reilly' store. The upper is a molded hose for the 454. By cutting a little off at thermostat housing it fit as well as the OEM Chevy Hose. The lower hose is no longer available. I have one that is over 20 years old and don't trust it. (I keep it as a guide for replacements). The Gates lower universal fit hose has the spring molded into it and with a little twist and a plastic tie wrap fits quite well.
Gregg
GWallace is offline   Reply With Quote
Old 09-08-2016, 09:46 PM   #681
1977 20' Argosy 20
Arlington , Texas
Gates Hose P/N's for 1977 model: Probably the same for previous years.
Upper Molded Hose Gates 20868
Lower Flex Hose Gates 26612
Gregg
Old 09-09-2016, 11:04 AM   #682
Well to put it bluntly, the E70735 hose will not work as a lower radiator hose for the vertical radiator rigs. Not even close
ID:	271306Click image for larger version
ID:	271307Click image for larger version
However, I'm fairly certain it will work as the upper hose which is how Autozone advertises it. I couldn't quite get it next to the hose that is installed on Peanut but after looking it over I think it will work. I should be installing my radiator in a few months at which time I'll give it a try. Due to the various curves it may have trouble with some engine configurations.
Not sure why the Winnebago crowd lists this as fitting a Winnebago unless there is something radically different about them compared to the P30 chassis Airstreams and Argosies.
Old 09-09-2016, 11:07 AM   #683
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Sorry for the bad steer Brad, but I think it was worth a try.
Old 09-09-2016, 11:08 AM   #684
The hoses that I installed on Peanut are 25808 and 26612.
Old 09-09-2016, 11:33 AM   #685
No bit deal. If it works as an upper hose I'll be happy. If not I can return it as long as its never been installed.
It's always worth while checking out leads for replacement parts!
Old 09-11-2016, 04:02 AM   #686
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I guess there is still the option of the Bronco hose Greg found in this thread?
http://www.airforums.com/forums/f311...mh-110442.html
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 09:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 10:00 PM
