Old 06-17-2016, 12:27 PM   #631
Another milestone day today
I finished up the TBI test stand installation and was able to get in several test runs while logging data.
Here's the first run. I didn't set the initial or base timing for this run because I forgot too so this run was set with fairly advanced base timing.
https://youtu.be/jsx9tBB4vYs
Here's the 2nd run. I did the timing by ear and it helped a good bit, especially for starting.
https://youtu.be/n7N7YPPZCV8
And here's the last run that I made. This time I had set the base timing to 6 btdc. I wasn't to far off from where I set it by ear but it's nice to know it's where it supposed to be now.
https://youtu.be/481oyU3EYhk
I'm definitely impressed with the TBI setup. At the moment while trying to start the engine on the first rotation it acts somewhat like it is to far advanced but it starts up almost immediately after that first hesitation. The idle his bouncing slightly and I'm not sure if that's the RV cam doing that or the TBI not having been tuned yet. At just about any speed the rpms seem to hunt a little bit and again my guess is that will go away once it's tuned.
Engine temperature seemed to maintain itself better and I never saw the logged temperature go above 199.6. The mechanical temperature gauge located in the left head shows temperatures very similar to the sensor used by the TBI although it does go a few degrees higher after a prolonged idle.
It would appear the guy I'm using for tuning knows his stuff. The code he sent seems to be working really well. I should be getting an updated version tonight or tomorrow.
With luck I'll be able to wrap up this portion of the TBI project and start tearing down the test stand next week. I'd really like to have the 454 mounted in the chassis by the end of the 4th of July weekend!
Old 06-17-2016, 02:07 PM   #632
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Looks good, Brad. I assume you have to revisit the fine tuning once you put the engine under load. At least I concluded that the AF at idle is one thing, but the real test comes at different RPM's under load. I was very pleased to see ~14.5-15.0 at 50-60 mph.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-17-2016, 03:54 PM   #633
My guess is I'll have to revisit the tuning 3 or 4 more times at least. I expect the next program he sends will smooth things out for how it sits on the test stand.
After that he will send me another program that has the 4L80e enabled. I won't be able to test that program until I get the engine and transmission installed, drive shaft shortened, gas tank installed and the rear suspension reworked. At that point I should be able to go for a test drive! I'm hoping to reach that goal by Thanksgiving.
That goal also means I've got a lot of chassis wiring to do along with installing the new instrument cluster!
Old 06-17-2016, 11:46 PM   #634
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Brad that's good music to my ears to hear that engine as it works
Congratulations
Herman
german6563 is offline   Reply With Quote
Old 06-18-2016, 05:58 AM   #635
Congratulations
Herman
Thanks Herman!
I could be wrong but it seems to sound a little different running with a TBI system than it did with a carburetor. I know it definitely starts faster.
Old 06-18-2016, 07:58 AM   #636
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Outstanding! You are really making great progress Brad. I think you are working on the most practical drive line upgrades possible. I am anxious to see your performance and mileage numbers when you get everything dialed in. I think you are blazing the trail for many others to follow. I think few would argue that the Cummins swap is the ultimate upgrade but, what you are doing can be done for a fraction of the cost.
Gregsch is offline   Reply With Quote
Old 06-18-2016, 09:37 AM   #637
Thanks Greg!
I thought about the Cummins conversion and realized I didn't have the deep pocket book needed for that sort of job
I really like the fact that just about all of this is bolt on. I've had to fabricate a few things like the throttle body adapter and various brackets but overall just about everything else is off the shelf.
I'm really looking forward to being able to drive the Argosy for the first time. Time will tell if I can make my Thanksgiving dead line
Old 06-22-2016, 06:54 AM   #638
I've been playing with various tunes provided by my tuner. We're having an odd problem that neither he or I can explain. At first I just assumed the problem was in the tuning and would be resolved as he worked through the tuning process. However I went back and reviewed all of my log files and found the same situation occurring above idle and below roughly 2000 rpm.
A quick spike is occurring in the RPM input signal which in turn seems to cause a spike in the Spark Advance to the distributor. I've attached some data log graphs showing the RPM spikes and the Spark Advance spikes. I really don't see how this could be related to tuning since the RPM input comes from the distributor. Revving from idle to above 2000 rpm is somewhat of a struggle as the engine wants to bog down somewhat. But once you're above 2000 it wants to rev like crazy!
ID:	264933Click image for larger version
ID:	264934Click image for larger version
ID:	264935Click image for larger version
I have a spare PCM, memcal, and distributor ICM module so I will probably try substituting components to see if the spike goes away.
Any thoughts or suggestions?
Old 06-22-2016, 06:59 AM   #639
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Attachment 264933Attachment 264934Attachment 264935Attachment 264936
Sounds like something is causing debounce Brad, and the signal averaging period isn't long enough (ie the signal to advance the distributor is being made before the debounce has been averaged out). If it is you have two choices....chase the source of the debounce or increase the averaging period on the decision to advance. The first option would be the purist view, because the second will slow responsiveness slightly - but are you going to be street racing this thing!!!!!
martin300662 is offline   Reply With Quote
Old 06-22-2016, 07:21 AM   #640
I need to ask the tuner if the program uses different averaging periods for different RPM ranges. I wouldn't be surprised if that was the case. Also thinking along those lines I wonder if it's possible the number for the averaging period may have been entered incorrectly or inadvertently altered. I'll query him about this idea. However that idea might not be the answer because I do know we've tried memcals from two different vehicles and both are exhibiting the same exact behavior. The first one we tried was from a very similar engine configuration that is in use and running on the street right now. The second is from a 1994 454 P30 motorhome.
The only thing that is the same is I haven't as yet substituted any of the electronics hardware.
Hmm, define street racing.....
Old 06-22-2016, 07:34 AM   #641
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Its interesting because I can imagine the biggest change required in the timing is when the engine is still spinning quite slowly, and so there is less data points on which to make the decision. So any 'invalid' data point (say from debounce) has a more significant impact (so needs a bigger averaging 'number').....the phrase between a rock and a hard place comes to mind, you need more data to make a decision, when you have less data on which to make a decision!
I would check if the averaging is on number of data points vs time as well - number of data points will give you a different averaging period (faster = shorter). But faster may need 'more' data if you see what I mean.
Old 06-22-2016, 09:34 AM   #642
I think the real problem is the spikes shouldn't be there and the fact they are is causing the averaging routine to produce erroneous data.
Here are three graphs illustrating how fast the spikes are. At sample one everything is fine, sample two the peak is shown and by sample 3 the spike is gone. There are 6 seconds from the first sample to the 3rd sample. So sometime within that 6 second period the spike came and went.
ID:	264941Click image for larger version
ID:	264942Click image for larger version
Weather permitting tonight I will replace the Ignition Control Module inside the distributor and see if it makes a difference.
Old 06-22-2016, 09:37 AM   #643
I'll ask him how many samples get averaged. I'm sure with good data (i.e. no spikes!) the spark advance would remain stable throughout.
Old 06-22-2016, 09:53 AM   #644
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Attachment 264941Attachment 264942Attachment 264943
Brad is the rpm value shown in image 2 real or is it simply a case that the data included in that displayed point includes a spike that is making it look high? If it is just the spike maybe the control script can be written to ignore any 'implausible' data point (for example have a threshold that any raw rpm value above 6000rpm is invalid and can't be included?).
There are a lot of similarities between the powder feeder controllers (I use at work) and these set ups, where you have a system trying to maintain set point, but then a system trying to change set point dependent on the change in state of the process, and the biggest 'control' issue is identifying the difference but valid and invalid achieved data (in my case could simply be an operator walking past a powder feeder effecting the powder feeder balance) and using implausibility limits to reject bad data is a good first step.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
