Old 01-16-2013, 09:57 AM   #43
Originally Posted by shepherd57 View Post
Hi Brad
Where did you get your brake parts from and were they expensive.Is Your 20ft on a P30 chassis would my 26 rear end be the same as yours.I checked here last fall and the rear shoes were quite expensive.
The weather is a little warmer today I will try to get those parts together. The widow latches will be different than the ones on your 20 ft. I have the same latch pins that you have. The 77 has the latches in the center of the slider.
John
John,
As far as I know all of the Argosies where built on the P30 chassis.
I got my brake parts from RockAuto.com for $56 for the set of shoes which covered both sides. On sale from a manufacturers close-out. They are Wagner heavy duty shoes.
I took a quick glance for a 75 chassis and the price varies depending on whether you have 13" x 3-1/2" or 15" x 4" brakes. The close-out price is still available for the 13" shoes, 15" shoes are around $133 to $150.
The rear wheel cylinders I got from Napa (37337 for 13" x 3-1/2" brakes) were $20 for the pair.
I don't mind switching to the later style of latches. All I would have to do is remove the flat latch plate on the back edge of the window and the pin becomes a non-issue.
When you say warmer today do you mean above 0 (degrees F) or above freezing (32-degrees F) ?!
Thanks!
Old 01-16-2013, 01:18 PM   #44
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
No 21 degrees F
I think you would have to replace the complete window and frame because the latch is completely different. I got everything together and took pics I will send as soon as I get them off the camera.
John
shepherd57 is offline   Reply With Quote
Old 01-16-2013, 05:27 PM   #45
No 21 degrees F
To cold for me!
John
Got the pictures thanks.
From what I have seen comparing our 310 to the Argosy the glass itself is the same, the difference is in the latch mechanisms. I believe the 77 glass can be used in the 74 frame. At the moment my major concern is the fixed pane which as you say the entire frame has to come out so the easiest would be to just swap entire frames.
Now to wait for warmer weather.
Old 01-16-2013, 05:53 PM   #46
Great Link Brad!
That link is identical to the C/K series rear drums I think.
Our '73 Blazer just never stopped well and I ended up putting it in Non-Op and storage because it worried me... I bled and bled, and inspected the drums and discs, replaced the master cyl and booster, but never spotted leaks anything wrong.
A closer examination last year, and some storage driving and braking showed me that it would pull to the right but still the stopping was way below acceptable. I quick test with a non contact IR Thermometer showed little heating of the LH rear drum.
I pulled it apart and inspected it carefully and discovered that the PO had miss-assembled the little T pieces(he calls them push-rods) that goes between brake cylinder and the forward brake shoe... when the brakes were applied it was sliding behind the shoe...
I reassembled it correctly, and it now stops on a dime!
The point I am trying to make is that the rear brakes on these somehow dictate how effective the whole system is... and it needs to be right.
I was shocked to realize that a lack of braking on one rear drum degraded the whole braking system to maybe 20%... it was barely possible to lock the wheels on gravel before I fixed the problem.
Old 01-16-2013, 06:42 PM   #47
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Key,
Can you put a pick up of what you are talking about? I would like to add that to my "need to check" list. Thanks!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 01-16-2013, 06:48 PM   #48
Steve, you are correct those are CK brakes in pictures. What's interesting is even though they aren't Bendix brakes which is what is on my Argosy, they still look virtually identical to the Bendix brakes. Following the picture sequence it was a breeze to assemble the Bendix brakes.
There is one reason I may have to take them back apart and that is because I may not be able to snake the parking brake cable in through the back plate to where it hooks on the lever. I'm keeping my fingers crossed. I felt it was worth the chance and even if I have to dismantle them and start over, at least this way I've done it once on the work bench and hopefully that will help if I have to redo them.
In searching for information on how to assemble them I ran across a lot of posts form people describing how theirs had been mis-assembled by previous owners and the associated problems that occurred from those mistakes. So you're not alone there!
Old 01-16-2013, 06:51 PM   #49
Originally Posted by wxbuoy View Post
Key,
Dave, you're lucky, you don't have drum brakes on your coach. Airstream switched to disc brakes on the rear I believe when the Classic series came out.
I wish I had disc brakes all around but unfortunately I don't
Old 01-16-2013, 07:21 PM   #50
wxbuoy's Avatar
Brad,
Thanks! Haven't had a chance to look at anything with the weather here lately! Yuk, it is either raining, sleeting, or just plain miserable!!
Dave and Felicia
Old 01-16-2013, 07:36 PM   #51
Brad,
You won't get wet if you're under the motorhome checking this stuff out
Fortunately (or unfortunately depending on your perspective) I have enough work inside and out so depending on the weather I can still find something to do.
This weekend we're supposed to have sunshine and temps in the 40s so I'm hoping to get a bunch of outside work done. That's the hope anyway!
Old 01-18-2013, 04:56 PM   #52
I made some progress on the rear brakes today. Got the left side backing plate bolted in place and the parking brake connected. Also managed to get the right side backing plate off, sand blasted and painted. Should be ready to assemble sometime this weekend.
After making progress on the brakes I decided it was time to pull the inside a/c shroud to see if I could see where the persistent drip was coming from. What I found was a real mess
Whoever installed the a/c unit just removed a ceiling vent and slapped the a/c unit on the roof. There was no structural support so when they tightened down the three long bolts they just crushed the ceiling and roof together
ID:	176959 Click image for larger version
Worse, there is NO drain tube And there doesn't appear to be one installed. I did find a 1/2" plastic tube hanging down in the left side near the wheel well that I'm assuming is a drain tube that goes to the rear roof vent area.
So, tomorrow I'll be pulling the roof top unit off and see what I can do about adding in a couple of rib sections salvaged from the 345.
As far as the drain tube goes, if there is one at the rear vent area I'll try snaking a section of hose from the a/c pan across the ceiling down to the rear vent area and connect the two together.
Needless to say the day sort of ended on on a down note
Old 01-18-2013, 05:39 PM   #53
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Brad,
My Argosy 20 does have a drain tube. My AC does NOT have a drain pan so I am not using it. I built a frame from 2x2 lumber and shims. I assembled the frame in the cut-out. The AC unit then tightened down around the wood frame and did not compress the two aluminum skins. The only improvement would have been to run the east-west 2x2 all the way to the frame for better support. Right now it sits on the roof and ceiling sheets. Not perfect but effective. No leaks. Of course filling the other 56 rivet holes left open helped that also!
ID:	176965   Click image for larger version
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 01-18-2013, 07:36 PM   #54
Fred, what brand/model A/C unit do you have? I just assumed they all used a drain tube. I'm not overly excited about replacing the A/C with a new one at this time but when I do eventually replace it it's nice to know there are models out there that don't need the drain tube.
Assuming I do have a drain tube by the rear vent and since I will need to pull the vent housing in order to get access to the tube this might be the perfect time to replace the old vent with a Fantastic fan
Maybe every cloud does have a silver lining
Old 01-18-2013, 08:02 PM   #55
ViewRVs's Avatar
1977 20' Argosy 20
I have a Duo-Therm Brisk Air. It may be overkill for such a small unit. I am not aware of a drip pan for an Airstream/Argosy for the Duo Therm model.
Look into the Carrier Air-V. I think they are less expensive.
Fred H.
Old 01-18-2013, 08:12 PM   #56
Fred, Carrier apparently is out of the RV air conditioner business. It looks like for about $550 delivered I could get a Duo-Therm Brisk Air 13.5k unit. I wonder if replacing the A/C unit with a new Duo-Therm right now would be a smarter thing to do than buying the Fantastic vent now and keeping the older Coleman unit (which I don't know if it even works). I think one of the things I'll do tomorrow is power up the Coleman unit and see if it actually works. If it does it could be saved as a spare for the 310 since it has two of the Coleman's installed.
Decisions decisions
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 09:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 10:00 PM
