Old 01-17-2016, 06:40 PM   #477
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Brad ,
I got the replacement headlight buckets for my Classic MoHo from ClassicParts.com. Look at their part #48-375, it might work for your Argosy.
Also, I stumbled on this pic of my steering stabilizer with the bumper removed. Thought it might be helpful.
Gregsch is offline   Reply With Quote
Old 01-17-2016, 07:58 PM   #478
Gregsch's Avatar
Tipp City , Ohio
Found a few more pics that might help. Do you think this is a super steer? Do you think it was an aftermarket part installed by a previous owner?
ID:	255908   Click image for larger version
Old 01-18-2016, 07:00 AM   #479
Originally Posted by Gregsch View Post
Brad ,
Thanks for the link. I'll see if they have something like what's on my Argosy.
That access opening looks to be the same as on my old 84 310. Of course I couldn't see the one on my 310 since the valance was in the way but by feel that seems about right
Old 01-24-2016, 11:52 AM   #480
Haven't spent much time working on the Argosy lately. Friday morning we were hit with a nice snow storm and by Saturday morning there was around 14-16" of snow on the ground.
I'm not much into scooping snow so I used my little Kubota tractor to back drag the driveway to clear a path. Worked pretty good until the Kubota decided to stop running! Took me several hours to replace the filter, bleed the injectors and get it running again.
This morning I finally ventured out in my 4x4 Ford ranger and made it to the top of the driveway From the road to my garage is about 1200'.
At least I can make it to work in the morning.
Old 01-25-2016, 07:01 AM   #481
1978 28' Argosy 28
Beautiful picture Brad. Man, I miss snow.. Sorry about the Kubota! Snow/cold is gorgeous to view, but not so much fun to work in!
bpg_austin is offline   Reply With Quote
Old 01-25-2016, 07:29 AM   #482
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I was wondering how you were getting along, it looked like Kentucky got hit pretty hard.
mayco is offline   Reply With Quote
Old 01-25-2016, 07:32 AM   #483
We only get snow a few times a year and normally it's only a few inches at a time. Last year and this year though have seen huge snow storms. Fortunately the snow will likely be gone by the end of the week as we're supposed to get rain and warmer temperatures starting today.
My fault on the Kubota. I had the filter and just never took time to replace it. I'll try and be more consistent on it's maintenance from now on!
Old 01-25-2016, 07:45 AM   #484
It started snowing Friday morning and kept it up through Saturday morning. The Kubota front bucket makes just a wide enough path that my little Ranger 4x4 has a path to drive through. I think the biggest worry is going to be flooding due the warm temperatures and rain expected starting today.
Old 01-25-2016, 08:44 AM   #485
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Bkahler you sure do live in a beautiful spot. That's a very nice tree lined driveway.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-25-2016, 09:34 AM   #486
Thanks! Other than all the mowing during the spring, summer and fall it's great
Old 01-29-2016, 03:13 PM   #487
mayco's Avatar
Brad, I have a question for you if youre willing. Ive been thinking about the chassis battery during the cold winter months where there are long periods between engine runs. I keep the 310 plugged into shore power just about 100% of the time while stored next to the house. I have an upgraded 3 stage converter that I installed a couple years ago. I check the fluid in my batteries a few times throughout the year. I have cured all parasitic drains on the chassis battery, at least for now. My question is, do you foresee any problem with running a jumper cable from my coach batteries to the chassis battery during these stretches of low use and cold temps in order to keep the chassis battery at full charge along with the coach batteries through the 3 stage converter? I think I would only need to connect the positive posts since they share the same ground. The chassis battery is not draining all the way or anything but over time it will drop to 12.4 during the winter.
Would you mind sharing your thoughts on this?
Thanks as always,
Mike
Old 01-29-2016, 06:35 PM   #488
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Brad, I have a question for you if youre willing......
Thanks as always,
Mike
Mike, I know I am not Brad (), but if you promised not to show this picture to anyone, I will share it with you... (Its clipped to 1 post for demonstration purposes only, normally its tugged away elsewhere doing non use)
No comment, no encouragement, no justification, nada
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-29-2016, 08:11 PM   #489
mayco's Avatar
Ahhhhhhhhhhhhhhhh, I get you. Clever and easier to get to. Thank you. I give you my absolute word of honor that this picture shall not be shared beyond this point! In fact, Peter who????? (but really good idea)
Salutations
Old 01-29-2016, 09:30 PM   #490
The only comment I have on tieing all the batteries together for long durations on the coach charger is I believe the coach charger is expecting the batteries to be all the same type, size, etc. A weak battery could cause the charger to over charge the other batteries.
A weak battery would pull the buss voltage down causing the charger to raise the charge voltage which I believe could cause over charging.
I'm not a battery expert but I think this what would happen.
I used to use a solar charger that plugged into the cigarette lighter and it kept the engine battery topped off. When my Argosy is done I am going to set up a trickle chager that I will plug in when I'm on shore power to keep the engine battery charged.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 09:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 10:00 PM
