Old 01-13-2016, 08:51 AM   #463
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
That would work Brad!!!!
martin300662 is online now   Reply With Quote
Old 01-13-2016, 10:40 AM   #464
Not sure I want to go through this again!
Name:	Arogsy trip 4.JPG
I have a turbo diesel now which would help but I just don't think I could justify the trip
Old 01-13-2016, 11:09 AM   #465
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Ya gotta do what ya gotta do Brad, haul it on up!!
mayco is offline   Reply With Quote
Old 01-13-2016, 11:23 AM   #466
At first it sounded tempting but then I realized just how much beer and wine was going to be flowing and realized that I need to keep the Argosy as far away as I can from all of you
Old 01-13-2016, 11:33 AM   #467
mayco's Avatar
Ill be pounding back some iced tea, we'll share with ya
Old 01-13-2016, 02:53 PM   #468
Make it ice water and you're on
Old 01-16-2016, 12:44 PM   #469
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by martin300662 View Post
No Brad other than the shop reporting 'there was nothing to bolt it to (which could mean either the arm or the hole). I'am not going to order new ones until I pick Bella up and look for myself.
As expected Bella doesn't have a V crank arm on the passenger side
But the cross member appears to have already been drilled to take the thread top of the damper (the circled, 1/2" whole appears new), although that area of the cross member resembles Swiss cheese due to the number of holes!
And the guy in the repair shop is confident he can get access to the top nut from below (there are a couple of openings to the box section). So I left Bella at the shop and he will try and get a V type crank arm on Monday.
Old 01-16-2016, 01:21 PM   #470
Martin, I have a new in the box passenger side GM bell crank with the arm for the steering damper.
Send me a PM or email if you're interested.
Old 01-16-2016, 06:18 PM   #471
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
Will all of that being said this picture shows where the hole needs to be drilled for the shaft of the stabilizer. Pretty straight forward and easy to do.
Attachment 255256
Hi Brad, I have been studying this photo and it looks like your position is slightly different from the location of the hole I have (mine looks to be about an inch lower).
I remember one of the other guys (maybe Mike?) posted measurements of the location, but I can't find them anymore - do you remember them?
- Martin
Old 01-16-2016, 07:25 PM   #472
mayco's Avatar
Here is the post about the measurements
Ok,
1. From center of mounting hole on bell crank to attachment on front cross member 19 5/8"
2. From frame rail to center of stabilizer is 6 1/8". As you can see in the pic, the frame rail attaches to the cross member with a curved plate so impossible to get measurement from the frame rail to the mounting hole. So I came back a few inches to clear the curved joint plate and took measurement to center of stabilizer.
3. Measurement from outside end of cross member to center of mounting hole for stabilizer 13"
4. Measurement from bottom of cross member to center of mounting hole for stabilizer is 1 3/4"
All measurements to mounting holes were taken to center of hole
Old 01-16-2016, 07:55 PM   #473
- Martin
Martin, no guarantees that where I marked the hold is correct. I used the eyeball method of making sure the cylinder was parallel and level and then marked the front frame member.
Old 01-16-2016, 07:56 PM   #474
Ok,
Thanks Mike! That takes all the guess work out of it
Old 01-16-2016, 08:05 PM   #475
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks Mike!
Old 01-17-2016, 10:11 AM   #476
This morning I decided it was time to look over the headlight buckets to make sure my LED conversion parts will fit.
Unfortunately all the bits are to rusty to dismantle I might try dunking the whole thing in my electrolysis tank but that will have to wait until the tank unfreezes. We have a cold spell here and if I don't have something cooking in the tank it freezes.
On the assumption that I will likely have to replace the buckets I started googling to see what I could find. The only thing I could find that seemed to be a match was the headlight buckets from a 1957 Chevy truck! I won't know for sure until I can get the head light bucket dismantled but they sure do seem to match.
ID:	255860Click image for larger version
Another thing I found disappointing is the "trim" ring is made of ABS plastic. That was disappointing to me as well. I'll have to see if I can find a nice chrome trim ring to fit. Who knows, maybe one from my Triumph TR4 will work
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
