Old 09-27-2015, 05:36 PM   #295
1982 28' Airstream 280
Redwood City , California
I sure wish I had your shop Brad.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-28-2015, 07:57 AM   #296
All it takes is a credit card...
Old 09-28-2015, 05:12 PM   #297
Hittenstiehl's Avatar
1965 24' Tradewind
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Nice 20 footer, nice shop, nice drawn plans with different setups.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 09-28-2015, 06:00 PM   #298
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Originally Posted by PeterH-Airstreamer View Post
No one said anything about "help" and Dave, I think, Mossman just challenged us
I kinda got the same feeling!
Great looking vehicle all cleaned up. I love the shop. Wish I had room for one of those! That is on our list to find/rent next.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 09-28-2015, 06:35 PM   #299
My hope is the Argosy will always have that place to park when not in use. The shop is big enough for my other vehicles & projects so with luck that will be the case.
Old 09-29-2015, 03:28 PM   #300
1975 Argosy 22 Rear Door
Hampstead , North Carolina
How tall is your garage door? I am trying to figure out what size carport to buy to put ours under.
Thanks!
VintageFan is offline   Reply With Quote
Old 09-29-2015, 03:33 PM   #301
Thanks!
The trailer are shorter than the motorhomes. My garage door is 11' high and I cleared with about 8" to spare.
Seems like the trailers are close to 12" shorter than the motorhomes. I'm betting you could fit under a 10' opening.
Old 09-29-2015, 04:00 PM   #302
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I have been looking at these as a temporary shelter (either with a tarp or a roof only) just to keep the worst of the weather off.
Trouble is it will have inches to spare and I get a different height/width each time I measure mine!
https://www.versatube.com/building-k...rame-only-301?
martin300662 is offline   Reply With Quote
Old 09-29-2015, 04:12 PM   #303
If you buy one that is 10' high where the walls meet the roof you'll be just fine, assuming the peak is 2' higher than the side walls. If you don't have an A/C unit on the roof then you could subtract just about a foot from the overall height needed.
As I mentioned previously with my 11' opening I had about 8" clearance between the top of the door opening and the top of my A/C unit, and that's with no 454 to weigh the front end of the coach down. Oh yeah, my coach is totally empty inside so it sits higher than it should anyway.
Old 10-01-2015, 07:07 PM   #304
Martin is thinking about having a mold made from my front valance since his Argosy came without one so with that in mind I decided to tackle this mess and get it over with
Tonight I got around to dismounting the lower front valance for repairs. It's definitely busted and broken in quite a few places.
Bottom overall view:
Bottom view of some of the worst damage:
Another view of the worst damage:
Top view. The torn section at the top right end is where the bumper bracket broke through.
It's obviously taken some abuse from road debris over the years and some obvious mishandling. I sorta made matters worse when I was using a tow bar attached to the two front bumper mounts to push the Argosy into my shop in Arkansas. One of the front bumper mounts bent upwards and tore the valance.
Of course it didn't help matters any when Airstream neglected to weld the bottom side of the bumper mounts. While pushing it into the shop the front of the motorhome ended up being higher than the back of my truck so there were upward stresses on the bumper mount during the moving operation. Lack of weld on the bottom and upward stresses were to much for the mount
Shouldn't be to hard to get it back into correct alignment and welded. I think I'll add some gusseting to make it a little stronger as well. Who knows someday I may need to install a tow bar again.
With the valance off I now have easy access to a lot of the chassis front end for painting. I'm sure glad I'll be working in a heated shop his winter!
Old 10-01-2015, 09:05 PM   #305
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Looks complete Brad, even if a little bent and broken. Do you think the ABS will take being molded? I wasn't thinking of a creating a finished (gel coat) replicate, just something close enough that could be finished and painted.
Old 10-02-2015, 08:30 AM   #306
Thanks! That helps a lot.
Old 10-02-2015, 09:37 AM   #307
Not sure how how well the ABS handle being molded. It is fairly flimsy so a mold would have to have stiffeners inserted in various places to take away some of that flexibility.
I neglected to remove an aluminum air baffle which makes it look larger than it is. I'll try and get that done with a few more pictures to show what it looks like.
Old 10-02-2015, 11:54 AM   #308
Here's a shot with the aluminum deflector removed. I'm pretty sure the deflector was made and installed by Airstream although it's obviously a one off fabrication.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 09:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 10:00 PM
