Old 06-30-2015, 10:30 AM   #253
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
What fun!!
mayco is offline   Reply With Quote
Old 07-04-2015, 03:28 PM   #254
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Brad, Not sure how much you have actually driven your MH but it is worth noting that the gauge layout on the AS MH is almost worthless as far as reading the gauges while you are driving. There is not a gauge on the the dash that I can read from a normal driving position. I would suggest that you mach it up to be sure the gauges are not obscured by the steering wheel.
Gregsch is offline   Reply With Quote
Old 07-04-2015, 03:54 PM   #255
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Have you given any though to a wind speed gauge? Doing the math will tell you your headwinds.
Old 07-04-2015, 05:12 PM   #256
Greg, I've not driven the Argosy at all but I have a lot of hours behind the wheel of a 1984 310. On the 310 you couldn't see the gauges for crap either and I'm betting the Argosy won't be any better in that regard.
The way I figure it is I'd rather have the gauges there so even if I have to move around a little to see them that should be better than not having any gauges at all.
Old 07-04-2015, 05:22 PM   #257
Actually I have but I haven't spent any time looking for one as yet. I guess I'm not even sure where to look for one
Old 07-04-2015, 07:12 PM   #258
Aerowood's Avatar
Arvada , Colorado
Look for airspeed indicator on eBay, with aircraft going digital the old surplus analog units are getting cheap
Old 07-04-2015, 08:00 PM   #259
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Brad,
What's the progress on getting it inside your shop?
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 07-05-2015, 06:48 AM   #260
Originally Posted by ViewRVs View Post
Brad,
Pretty good actually. I've already made enough room now for it to fit easily inside. However I pulled my tractor inside to mount a backhoe that I bought for it. That should be done sometime this week and then I'll do a little more organizing and the shop will be ready. Say, sometime in August.
Later this month I hope to pull the Argosy away from the side of the shop so I can hot pressure wash it to remove all of the moss that's growing on it
Once that's done there should be nothing from keeping me from moving it inside.
It will definitely be inside for the winter and now that the shop is heated I should be able to work comfortably on it without freezing my **** off
Old 07-05-2015, 06:50 AM   #261
Pricey little buggers aren't they!
I think I need to learn a little more about them before making any buying decisions.
Thanks!
Old 07-21-2015, 01:40 PM   #262
As I get closer to moving my Argosy into the shop so I can start working on it again I'm considering my options for replacing the ABS plastic tailing housing assembly with a couple of different Airstream trailer choices.
Here's a picture of my current tail light housing. It's unique to I think 73-74 Argosy motorhomes and trailers. Lenses are no longer available. It's big, bulky and prone to cracking.
I have a set of each of the assemblies in this picture. The bottom assembly is from a 74 Excella 500 trailer and the top assembly if from an earlier Airstream trailer.
Not sure where I stole this picture from but you can see what the earlier trailer tail lights look like on an Argosy motorhome (note the painted endcap). The later Classic motorhomes used a similar style only with square lenses and the early trailer assembly is cast aluminum where the Classic motorhomes used a cheap plastic housing. At least the 310 I owned used a cheap plastic housing
This is a variation of the Argosy lights used on I think 75 and 76 Argosy motorhomes.
I have all the parts necessary to install any of the above, I just need to figure out which to use.
Thoughts anyone?!
Old 07-21-2015, 01:57 PM   #263
mayco's Avatar
Cant go wrong with cast aluminum.......in my humble opinion
Old 07-21-2015, 02:00 PM   #264
1978 28' Argosy 28
Brad, no question in my mind. If you've got a metal piece it needs to go on. I'm with mayco.
bpg_austin is offline   Reply With Quote
Old 07-21-2015, 02:04 PM   #265
I agree with both of you. However both of the tail light assemblies in the picture below are cast aluminum. Personally I'm leaning towards the bottom one from the 74 Excella trailer. More lights means more visibility
Oh yeah, the top one is missing a reflector that I would likely change to some sort of LED light if I decide to use the top one.
Old 07-21-2015, 02:08 PM   #266
1978 28' Argosy 28
No ones going to miss your Argosy on the road, even in the dark. I think its all about style Brad, and the rounds in post #262 on the polished unit are unbelievable. But.. I do get the practicality of more lights..
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
