Old 05-01-2015, 11:43 AM   #239
Originally Posted by mprokop87 View Post
Glad you're back! Looking forward reading about your progress!
Unfortunately I'm not necessarily able to work on what I would like right now. Come h*ll or high water, this coming winter the Argosy is going to be in the shop so I can work on it
Old 05-03-2015, 06:56 PM   #240
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
While in the area, I stopped in to check on Brad's progress and remind him what a fully assembled unit looks like!
Monique and I had a great visit with Brad before heading south.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-04-2015, 06:29 AM   #241
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Thats a fine looking rig ya got there. Wish mine was that nice!
mprokop87 is offline   Reply With Quote
Old 05-04-2015, 12:27 PM   #242
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Man wish someone would do that for me! Haha
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 05-04-2015, 03:29 PM   #243
Talk about making a guy feel inadequate...
Old 06-29-2015, 11:33 AM   #244
San Diego , California
fellow 20' owner
Looking for a front passengers side windshield if you know of any!
birdsurfs is offline   Reply With Quote
Old 06-29-2015, 05:14 PM   #245
Wish I could help but other than a glass company I don't have a clue where to find one.
If you do find a source let us know about it!
Old 06-29-2015, 05:34 PM   #246
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
They are still available new via Airstream and can be ordered from just about every Airstream dealer.... about $750 plus tax each. The big parts guys like Airstream Supply and Inland RV even list them as being in stock. I have a good passenger side that I took out because the drivers side cracked in shipping the MH from Florida and the tint along the top of was blue, whereas the new ones have a tint that is grey.
Airstream order them from coachglass.com and in my case they were 'drop shipped' (not literally) from Coach to Airstream NE even they they were order via Airstream.
martin300662 is offline   Reply With Quote
Old 06-29-2015, 05:57 PM   #247
Martin, price isn't as bad as I thought.
Were you able to buy a replacement seal (glazing?) as well or did you have to reuse the original piece?
Old 06-29-2015, 06:36 PM   #248
Dash layout
One of the may tasks that needs to get done is creating a replacement dash plate for the new instruments I will be using. I have found a place online that fill fabricate instrument dash plates based on cad drawings that you send them. The 10 hole version should come in just under $200 which I feel is a decent price.
The first attachment shows the layout with holes for 2 large 3-3/8" gauges and 9 small 2" gauges.
Name:	74 argosy dash layout v2.jpg
The second attachement shows the layout with holes for 2 large 3-3/8" gauges and 10 small 2" gauges.
Name:	74 argosy dash layout v3.jpg
If you're wondering why so many small gauges, it's because I like to see what's happening with the engine and transmission. Even with the 10 2" gauges there are still a few other instruments that would be nice to have as well
The list of the first nine 2" instruments is:
Fuel
Water Temp
Engine Oil Temp
Transmission Oil Temp
Oil Pressure
Vacuum
Volt (engine)
Volt (coach)
Air Pressure (suspension, assuming I add air springs in the back)
I would also like to add a 2" LPG gauge as well which would be the 10th 2" gauge. Another possibility for the 10th gauge would be another fuel gauge. My Argosy has two fuel tanks and I do have a switching valve so the second gauge isn't really necessary but beats flipping a switch
The 3-3/8" gauges are of course the Speedometer and Tachometer.
I'm inclined to go with the 10 hole version and if I need to plug a hole ore two I can do that. By the way this dash plate is designed for the 74-76 Argosies which use the small instrument clusters as seen in Martin's Argosy rebuild.
Not shown on the drawings are the holes for some switches and the turn signal indicator lights. I'll add those once I decide whether to with 9 holes or 10.
Just thinking out loud here
Old 06-29-2015, 07:00 PM   #249
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Yes Brad.
The PO had replaced the seal (I believe he got it from Out-of-Doors Mart) and the photos I have of it when it left Florida show both screens intact in the new seal. When it arrived the drivers side was cracked but there was no sign of impact and I suspect the screen was not 'in' properly and the crack was a stress crack. When I got the donor the guys at the shop took the drivers screen and installed that (using the same seal) and it went in fine, but both the donor screens were clouding (from the usual place along the lower edges) and had a different color blue tint along the top, so I ordered the new ones and the shop removed both the donor and original and installed the new ones all using the same seal. So although the seals were new the drivers side screen has been in and out at least 3 times and the passenger side twice, so as long as you are careful they should be reusable.
Those dash inserts look great can't wait to see them installed.
Old 06-30-2015, 07:02 AM   #250
Martin, good to know the seals are still available.
There had been talk on Airforums a year or so ago (can't remember for sure just when!) that the seals were no longer available which is not a pleasant thought.
Thanks for the info!
Old 06-30-2015, 08:36 AM   #251
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
What material are you going to use for your dash plate? What are the options?
Mike
mayco is offline   Reply With Quote
Old 06-30-2015, 10:15 AM   #252
Hi Mike,
Right now I'm looking at 4mm polished aluminum plate. Once you get above 4mm they state that they can't guarantee a scratch free surface.
There are a lot of options as to thickness and type of finish. Before placing the order I'm going to look closer at the options for dash finish to see if some other finish might look better.
I'm using a company called Front Panel Designer.
They provide free design software that you use to layout your panels. The program has a built in pricing module so you know what your panel will cost as you develop it. Some of it's capabilities are limited such as the shape of the dash but I found that by designing the dash shape in Autocad I was able to export the Autocad file and import it into Front Panel Designer. From there I started the actual gauge layout.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 09:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 10:00 PM
