Old 08-12-2013, 03:16 PM   #183
Originally Posted by Overlander & Sea View Post
Brad, I asked some of the guys at work and we believe this is the neutral safety swith, since your '74 Argosy MH has an automatic transmission.
....and we believe this photo from Rockauto.com is for a clutch safety switch, or to put it another way, a neutral safety switch for a manual transmission.
Rick
Rick,
What you describe makes sense. I'm mainly curious about one thing which is why did my my original Argosy steering column not have the screw holes for mounting the switch? The rectangular notch is present in the column but there was no way to mount it.
Also I looked the wiring over last night and couldn't locate any wiring that might have been part of the neutral safety switch circuit. Fortunately the 1986 345 steering column that I installed has the mounting holes and I have no problem modifying the wiring to accommodate the switch.
I'm wondering if at some point prior to the chassis being shipped to Airstream, GM might have had the chassis ear marked for a manual transmission. That would explain why the manual transmission safety switch is installed. I vaguely remember seeing that switch under the dash. I'll check again this evening.
I do know my Argosy is one of the first ones made by Airstream so who knows what GM shipped!
Thanks for the info!
Old 08-12-2013, 03:35 PM   #184
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Originally Posted by bkahler View Post
Rick,
Brad,
Did the switch in your photo come off of your '74 Argosy? There's a good possibility that on the Chevrolet '74 P-30 chassis the neutral safety switch for an automatic is mounted on the transmission. I think that in later years (77and up?) GM moved them to the sterring column. I think that same swithc is also the backup light switch. Even our GM parts information does not list the '74 P-30 neutral safety switch any more. I have to talk the "old guys" (ha, my age!) here ar work that remember!
Rick
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 08-12-2013, 06:26 PM   #185
Rick,
The switch in the photo is from the 1986 345. When I got the Argosy the original 454 engine and transmission had been pulled by some long forgotten PO to use in a stock car
The person I bought it from had installed a 350 with TH400 transmission (but he never got it running). When I got it I yanked the 350 and am building a 454 to go back in with the TH400. I was told the 350 and the TH400 were from a 1-ton dually pickup.
I checked out the wiring in the engine compartment area and didn't see anything that looked like it would go to the transmission. I'm fairly certain the existing transmission doesn't have any connection points other than for the kick-down switch. Which means I'm going to have sort through the wiring and try to match it to the switch that I'll put on the steering column. Since I'm going through all of the wiring anyway it really shouldn't pose a problem.
In the housing that holds the throttle pedal I found the following which I assume is the kickdown switch for the transmission.
ID:	193055Click image for larger version
I did find this connector which is part of the engine compartment wiring harness. It has two heavy gauge blue wires and two lighter gauge green wires. Any ideas as to what it is supposed to plug into?!
Also, I didn't see anything that looked like the manual transmission clutch safety switch so we can rule out my one theory mentioned previously
Thanks!
Old 08-13-2013, 06:08 AM   #186
Rick,
I believe the unknown connector I posted a picture of is for the transmission mounted neutral safety switch. I found the following pictures on the Jalopy Journal website.
ID:	193080Click image for larger version
According to the article GM made a special bracket for mounting the switch to the transmission. Since I have a steering column that accepts the later style of switch I'll just rewire as necessary to make things work.
Thanks for the help!
Old 08-13-2013, 07:49 AM   #187
Images: 30
Brad,
You're welcome. I see that Rockauto does list a column mount switch for a 1977 P-30 Chevrolet. Here's the link.
http://www.rockauto.com/catalog/x,carcode,1058903,parttype,4584
Rick
Old 08-13-2013, 07:09 PM   #188
Brad,
Rick
Rick,
That switch looks identical to the one that was on the 345 column.
I took a closer look at the wire colors on the connector that I thought was for the neutral safety switch and where I thought the two large wires were blue they are actually purple which is what the wiring diagrams says they should be. Now that I'm certain that section of harness is for the neutral safety switch it should be a piece of cake to modify to suit the new column location.
Now if I could just find time...
Old 08-14-2013, 10:28 PM   #189
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
neutral switch
I have a 76 Argosy/454. The neutral safety switch is in the Turbo 400 transmission. The wiring from the key goes all the way back there and then to the starter. I have an issue with finding neutral before it will start.. Tweak issue on my part as there is some play in my lever.
There is no switch on or around the steering column on the 76.
J
Rick,
MrJ is offline   Reply With Quote
Old 08-15-2013, 08:26 PM   #190
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Rick,
Thanks!
Yes that is the kick down switch. I replaced mine because the trans never seems to downshift by pedal position. Still doesn't work so I manually downshift when going up hills.
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Old 08-16-2013, 01:04 AM   #191
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
The turbo 400 on my 76 doesn't shift up to the top gear on the highway. Anyone have an idea why? Change filter/oil?
Old 08-16-2013, 05:12 AM   #192
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Make sure you are in drive. You may laugh at this suggestion, but the linkage on one of my Moho's was so worn out that I had to make sure every time that I was in D and not in 2
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-16-2013, 09:23 AM   #193
Peter,
I thought it was just because you liked to take it slow and easy...
Old 08-16-2013, 09:26 AM   #194
J
J,
Is that IN the transmission or ON the transmission? Everything I've found so far indicates it should be a bracket with switch somewhere on the side of the transmission.
My transmission is a transplant from a later 1-ton truck and the switch is not present down by the transmission. I'm glad I decided to replace the Argosy steering column with the one from the 1986 345. Now that I have the switch on the column my problem is solved.
Old 08-16-2013, 09:29 AM   #195
Have you verified that you have voltage at the solenoid when you push the pedal to the floor? If I understand things correctly when you step on the gas pedal the switch energizes a solenoid inside the transmission which causes it to downshift. You could have a bad connection in the firewall connector, or at the connector on the transmission. You might also check for voltage at the switch itself to make sure the problem isn't between the fuse block and the kickdown switch.
Old 08-16-2013, 09:30 AM   #196
Like Peter said, definitely sounds like a linkage problem.
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-08-2013 11:16 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
If you're looking for an Argosy Motorhome.... crazeevw Argosy Motorhomes 3 10-23-2011 08:09 AM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
