Old 03-29-2007, 08:23 AM   #1
350 cu in P30 Chassis Headers Inquiry
Has anyone have installed headers on a Argosy Motorhome with a 350 engine? If so, how did it go and what brand and model was used? Thanks
911rs is offline   Reply With Quote
Old 04-01-2007, 05:36 AM   #2
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
911rs, I can't speak to the 350 but I did put Headman Headers on my 454. I also put on Flowmaster 70's for mufflers.
I had lots of room and did not replace the AIR tubes from the pump.
Check out the folks at Summit Racing - High Performance Car and Truck Parts | 800-230-3030 and give them a call. They know their stuff and the prices are great.
Go ceramic coating too.
BTW you've got a rare bird there. Most of the coaches had 454 but the very few as you've found out.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-02-2007, 09:33 AM   #3
Thank you. I did research over the weekend and agree with your comments. I am zeroing in on the Hedman brand with ceramic coating to reduce engine bay temp. Flowmaster told me the same on mufflers as you have, use the 70 series. Adding an Edelbrock Air Gap intake manifold and carburator with stock air cleaner housing with a K&N filter and lenghtening the duct work for the air cleaner housing for cool clean air. Also rebuilding the HEI with MSD components. Saving up for next year to add a gear vendor overdrive. Thank you
Old 04-02-2007, 10:11 AM   #4
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Sounds like you're on the right track to make that shorty a real sleeper.
Take a look at my photos for an easy to build custom air cleaner housing that takes the K&N out front.
I'd like a GV unit but find I'm in between ranges for RPM and would have to change my rear end ratio at the same time.... 3:73's.
Old 04-03-2007, 01:14 PM   #5
1975 20' Argosy 20
Fredericksburg , Texas
Yes I did
I called or emailed Headman hearders and installed a pair on my 350 the fit perfect.
Matt
fullmoon is offline   Reply With Quote
Old 04-06-2007, 07:21 PM   #6
Glen and Matt thank you for the great insite for the header application. This is a great site for research and development.
1975 P30 wiring diagram (as promised) ... Hayseed Airstream Motorhome Forums 1 11-22-2012 02:28 PM
P30 VIN location dienst1 Airstream Motorhome Forums 5 01-14-2003 03:11 PM
Spacer on exhaust manifold needs replacing. rdm Mechanics Corner - Engines, Transmission & More... 30 11-19-2002 03:14 PM
chassis paint john hd Off Topic Forum 2 10-30-2002 03:36 PM
Headers, Exhst, Axle Changes? Sav'h Steve On The Road... 8 08-22-2002 07:14 PM
