Old 12-25-2015, 06:46 AM   #1
1977 24' Argosy 24
SW Florida , Florida
Images: 8
24' MH Fuel Filter Replacement - Where to Buy?
Ah, the motorhome is running beautifully after much tweaking, BUT we want to replace the fuel filter. Here are photos of what was there, on the frame. This is a 1977 P30 454 Chevy engine, 24 foot Argosy.
I have searched online at RockAuto, SummitRacing, etc., and I cannot find one for the year, make and model in this same size - 2 1/16" by 3 9/16".
Feel free to email me direct, as we want to go away for New Year's! vxn@comcast.net
HAPPY HOLIDAYS to all!
Elisa
Name:	fuel filter 1.jpg
ID:	254578   Click image for larger version
Name:	fuel filter 2.jpg
Elisa is offline   Reply With Quote
Old 12-25-2015, 07:57 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Any numbers on the filter or filter housing/assy?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-25-2015, 08:12 AM   #3
1977 24' Argosy 24
Images: 8
No, that's why we are going nuckin' futs! Can't find any identifying marks of any kind.
Old 12-25-2015, 08:22 AM   #4
GCinSC2's Avatar
I found this number 1-800-526-4250 for Purolator. Try calling them next week. If that doesn't work consider changing the housing to a commercial external filter of your choice.
Or as a temp, just remove the old housing and install a hose clamp inline style, might have to adapt a fitting or two.
Or even run what you have if its not damaged until you can research this one fully.
S/OS #001
Old 12-25-2015, 10:52 AM   #5
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
you could take the old filter to a NAPA auto parts and they normally can find a replacement, in the picture the color of the filter actually looks pretty good unless it has water in it
PeterKV is offline   Reply With Quote
Old 12-25-2015, 11:27 AM   #6
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
Try Diesel filTers on line. I have found they have good prices on OEM filter and service all makes.
https://www.dieselfiltersonline.com/
helwigc is offline   Reply With Quote
Old 12-25-2015, 11:29 AM   #7
1977 24' Argosy 24
Images: 8
Yes, the filter itself looks good, but the rubber is shot. This MH sat in a warehouse for a long time and wasn't ever used much. It had less than 9,000 miles on it. NAPA is open tomorrow, and my mechanical darling will see what they have.
In the meantime, I am finishing my new front curtains today! I do the inside stuff; he does all mechanical. I replaced the wooden venetian blinds with new drapes that are tasteful and simple and easy to slide open and shut. Finally got all the windows to slide by repeated brushing and vacuuming of the trays they slide in, then used Murphy Oil soap as a lubricant. They slide easily!
Old 12-25-2015, 08:02 PM   #8
1977 31' Sovereign
Lynnwood , Washington
This is your garden variety General Motors (long) paper fuel filter that fit all Qudra-Jet carbs. They've been around forever. You can get these at any auto parts store or Chevy parts dept. They've even got 'em at Wal Mart.
Tom
TomKirk is offline   Reply With Quote
Old 12-25-2015, 08:30 PM   #9
Tom, I think Elisa mentioned the filter was mounted to the frame rail not in the carburetor. Sounds like its some sort of inline canister filter.
Old 12-28-2015, 05:30 PM   #10
GCinSC2's Avatar
Did you find a filter?
S/OS #001
Old 12-29-2015, 08:15 AM   #11
1977 24' Argosy 24
Images: 8
My treasure, T.O.M. (the old man) who is in charge of all things mechanical, found something very similar, although with a perforated metal jacket around it, at NAPA. Now he wants to put on something that keeps the fuel up in the line, as the engine SHOULD start immediately, given the other work he has done on it. But it still starts a little rough, like the fuel is being brought from a far away tank. Once she goes, she purrs like a cream-fed cat, thanks to T.O.M. Whoever had done previous work on this engine should get another hobby.
Thanks to all for your help and suggestions and moral support!
Old 12-29-2015, 08:42 AM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
That filter looks like what ford used in the 60,s thru the 70's mounted either remotely or on the fuel pump, it is a good filter...
tjdonahoe is online now   Reply With Quote
Old 02-08-2016, 08:08 PM   #13
1977 20' Argosy 20
Arlington , Texas
That fuel filter in the picture appears to be one out of the filter assembly mounted to the frame in the front passenger wheel well. The filter assembly is an AC Type GF-62-C with a replaceable element AC GF-157.
Here is a photo from my 1977 Argosy.
Google AC GF-157 and you will find more information and locations to purchase.
Cross Reference to
FRAM CG 20
Wix 33271
I am sure there must be others.
Gregg W
GWallace is offline   Reply With Quote
Where to buy replacement water filter plug 2008 23fb bonginator Fresh Water Systems 0 10-23-2011 08:37 AM
fuel filter Orland Dewey Airstream Motorhome Forums 11 11-13-2003 07:32 PM
Kohler generator fuel filter ViewRVs Mechanics Corner - Engines, Transmission & More... 3 08-23-2003 06:17 AM
Trip report (fuel filter issues) PeterH-Airstreamer Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Fuel Filter Replacement ViewRVs Mechanics Corner - Engines, Transmission & More... 8 03-06-2003 06:05 AM
