Old 09-09-2018, 10:00 AM   #141
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by martin300662 View Post
OK Tony, you cannot post cryptic messages about Minuet axles on another part of the form!
Spill the beans, is your new toad actually an additional trailer?
The thought is this........buy an Argosy trailer 22', (the Minuet is just a single axle), keep the rear toilet, but extend the shower facilities, keep the front gaucho that can turn into a bed, but get rid of the kitchen and turn the rest into basically a large dressing room.
This would allow us to pack more stuff, but hook up the trailer permenantly on a building site in Belize and take bigger baths or longer showers, leaving the Argosy as more of a weekend special camper that it was meant to be. We want a larger bed in the back and that will end up meaning we possible loose the shower or go to the same wet bathroom you have in your 20'.
All I know, is that I just purchased a 1993 36' Fleetwood Bounder diesel pusher 5.9 Cummins/Allison that the guy wanted $11,500.00, for $1,500.00.
Yes, the wife is looking at me and putting it down to Chemo brain.
I may even buy this beast. It has the same Cummins/Allison, but with only 56,000 miles. That should get me committed.
https://www.kijiji.ca/v-rv-motorhome...ationFlag=true
Cheers
Sidekick Tony
PS There is method behind my madness.
Old 09-09-2018, 11:39 AM   #142
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Not mad at all....well I have to say that because I am considering something similar!
Just keep in mind the Minuet is aluminum floor but did come in 6.3, 6.7 and 7m lengths and I think the longer one is a twin axle. They are also 6" narrower than a standard trailer (the center window is 6" less wide). There are a few single axle 20ft Argosy's around but they are being snapped up by the 'Bambi brigade'.
I was thinking of going slightly further and having one changed into a bike hauler (hatch installed like a Pendelton), but other wise the same....if Peanut's layout changed to this when he arrives back in the UK.
Name:	1977 20ft rear bed floor plan_b.jpg
We will see...they are like gold dust so have to find one first!
martin300662 is online now   Reply With Quote
Old 09-09-2018, 04:00 PM   #143
Dazed and Confused
Isuzusweet's Avatar
Attachment 321979
From what I've read, all 6.3" came with aluminum honeycomb flooring, some 6.7's did , but not all, and the twin axle 7M's were all plywood. I have a line on a nice exterior gutted 7M in Deluth Minnesota for $3,500 in the air classifieds right now, but still torn on a double axle and the length; not that my Cummins would even feel it back there, but the hitch may have to be beefed up.
I would just think it'd be a cool rig, both painted the same colours. Sort of like one of the Russian Siberian monster caterpillar machines.
Cheers
Sidekick Tony
Old 09-09-2018, 06:40 PM   #144
Keen amature
1975 20' Argosy 20
Chestfield , Kent
There is Russ Bateman's rig that set the trend (Russ's Bodyworks Utah)
Name:	Russ Bateman 3.jpg
but also Rick Foley, pulled a trailer with his 20ft - I had some photos but blowed if I can find them now!
Old 09-09-2018, 06:48 PM   #145
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Found one at least
Name:	Phippens towing Bridges Argosy, a.JPG
Old 09-09-2018, 06:48 PM   #146
Dazed and Confused
Isuzusweet's Avatar
Never seen that set up before, but yeah, something like that. I just like the flexibility it gives us with a home base that provides shower/ bathroom and bed should I take the Argosy somewhere else.
Should look pretty cool. I plan on getting them painted either in Belize or Mexico.
Gab's big on sky blue for some reason.........
Cheers
Sidekick Tony
Old 09-09-2018, 08:27 PM   #147
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Its interesting you say the small Minuet had a honeycomb aluminium floor (I had assumed it was just sheet) as I have friend who works for a company fitting out aircraft interiors and have been told the honeycomb sheet they use is suitable to replace trailer/motorhome floors at a fraction of the weight of timber sheet.
Old 09-22-2018, 02:05 PM   #148
Keen amature
1975 20' Argosy 20
Chestfield , Kent
If you are looking for something even more extreme Tony....
You could drop your body on one of these.
https://www.ebay.co.uk/itm/EX-MOD-LE...QAAOSwSzpbQMgf
It has your preferred 6BT, plus 4x4 and definitely capable.
Old 09-23-2018, 09:20 AM   #149
split window's Avatar
1992 25' Airstream 250
at Home , Niedersachsen
like this one..??? !!!
ex Airstream 250....
Peter
split window is offline   Reply With Quote
Old 09-23-2018, 03:59 PM   #150
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Peter
Maybe not Peter, but to explain here is my logic. Tony's engine of choice is the Cummins 6BT. In Europe these are widely used in the DAF 45 trucks and readily available as running units (still in the chassis rails).
Name:	DAF 45 150 6BT.jpg
However these engines weigh a lot more than 474 so will require the front end to be reworked. If this is the case then maybe a better approach is a body swap. The DAF 45 150 4x2 is very similar in length, wheel base and width. Is a dually chassis like the P30 and already has the suspension/steering/brakes to suit the engine.
Name:	DAF 45 150 4x2.jpg
But if going that route then the 4x4 version of the chassis has the same wheel base, width, although shorter (at 20ft) but could be lengthen.
Name:	DAF 45 150 4x4.jpg
Old 09-23-2018, 04:16 PM   #151
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
Originally Posted by SteveNdebbie View Post
Thanks for the heads-up Tony. We had looked at and almost purchased a new 23 foot Serenity but noticed some quality issues. The factory was having trouble keeping up with the demand. Our older model was well taken care of by the previous owner and the fit and finish seemed better, but I did wonder what problems may arise. I’ll keep an eye out for leaks.
Steve
good luck towing with that.........
AFTER TAXES is offline   Reply With Quote
Old 09-27-2018, 11:28 PM   #152
SteveNdebbie's Avatar
Dalton , Ohio
Currently on our way back to Ohio from the Redwood National Park. Overnight at the Royal Peacock Opal Mine in Nevada last night. I-80 to KOA Salt Lake City. Cruised about 75 mph in 4th gear @4100 rpm. MDX towing great!
SteveNdebbie is offline   Reply With Quote
Old 09-28-2018, 09:15 PM   #153
Dalton , Ohio
And today between Salt Lake City and Cheyenne ran 80 mph in 5th gear at 3100 rpm and got 11 mpg - 1 mpg improvement
Old 09-29-2018, 08:33 AM   #154
1977 24' Argosy 24
Space Coast , Florida
Attachment 323470
WOW.
Don't mean to hijack.
But WOW.
I love our 24 Argosy, but not the (our) P30 chassis and 454.
My engine of choice, also, is the Cummins 6BT.
Your post has me excited,I've been searching for an E450 ford chassis with the 7.3 or anything close with a Cummins.
4x4 was a pipe dream.
I'd love to discuss this, get your advice, or start a new thread.
And a manual tranny!
I've been out of work for about a year with an eye injury (I'm functional, just not for my job, for a while).
We've taken this opportunity to do missionary work in the Ukraine and have helped with some vehicles. My mind has been constant on a justification to get get our Argosy to Poland for an affordable rework. This may be it.
PM on the way.
mikeajana is offline   Reply With Quote
Old 09-29-2018, 11:26 AM   #155
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by mikeajana View Post
WOW.
But WOW.
PM on the way.
Lets start a new thread about possibilities for body swaps....of course any work you had done in Poland (and many car restorations in Europe are now carried out over there because of the local skill sets) would have to include the $3K each way ferry ride.
Old 04-12-2019, 05:52 PM   #156
Dazed and Confused
Isuzusweet's Avatar
New axle hopefully arrives today and then I will wait until after Easter to pick her up as South Dakota is still digging out of 10-20" of snow in the past couple of days.
Just to prove I did get a 6.7M Minuet with an 8-track stereo and hammock.....
Cheers
Sidekick Tony
PS If it looks like I lost half of me in the past year; almost; down to 195lbs, from 275lbs.
Old 04-12-2019, 07:37 PM   #157
Dalton , Ohio
Welcome back Tony! We were just thinking about you and wondering how you were getting along. What more could a person want if they have an 8 track stereo and a hammock? I still have my Loverboy Get Lucky 8 track tape. I’ll keep it safe for you here in Ohio until you stop by and pick up in the Argosy - Minuet mobile [emoji16]
Steve
Old 04-13-2019, 12:34 AM   #158
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Cheers
Sidekick Tony
Both you and the Minuet are looking good Tony!
Old 04-13-2019, 05:56 AM   #159
Cheers
Sidekick Tony
Without pictures of the 8-track and hammock....it didn't happen
I think you better update your drivers license picture or you could get in trouble one of these days!
You're looking good Tony.
1975 24' Argosy Motor Home
1975 Argosy value alhamilton Argosy Motorhomes 12 03-18-2017 02:30 PM
Argosy 1975 28' value Eric J Wolf Trailer Values 0 10-21-2016 09:11 AM
1975 Airstream Argosy Value? firsttimer Argosy Motorhomes 1 05-22-2011 11:39 PM
Value of 1975 30' airstream Sovereign freyza Dollars & Cents 6 08-18-2010 10:29 PM
