Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1969 Sovereign
Old 08-06-2007, 03:09 PM   #15
badelson
badelson's Avatar
Profile:  1969 31' Sovereign
Dover , New Hampshire
OK, I think I know what I have to do as far as windows go. The Frames are all in good condition, so buying new windows with frames may not be necessary, I hope. I was quoted near or over $400 to replace each window(Not installed). $1000 is far to much considering the other work that needs to be done. 1/8" Lexan is about $7 a squart foot at the local glass place. No more than $50 a window and they will cut to fit frame. Now, if I can find the proper seals for the frame, this should allow me to put $$ into other areas, like safety stuff(brakes, etc.)
If anyone can see error in my thinking, please let me know.
Thanks again everyone,
Ira
**Just cause I'm drive'in through life doesn't mean everyone else is a passenger.
4 Blogs for you to view
http://www.badelson.blogspot.com
badelson is offline   Reply With Quote
Old 08-06-2007, 03:46 PM   #16
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Grab a tube of Vulkem, and seal away. It's about $7 a tube. One tube should do 2-4 windows, depending on size.
Change is inevitable, except from a vending machine
AIR#2611
Old 08-06-2007, 04:44 PM   #17
badelson
badelson's Avatar
Thank you!
I will assume that vulcam sticks well to lexan.
Thanks again Overlander63 for all your help.
Ira
Old 08-06-2007, 04:47 PM   #18
overlander63
Images: 58
Thank you!
I have found Vulkem sticks to just about anything it comes into contact with, and have the ruined clothes to prove it...
AIR#2611
Old 08-06-2007, 05:46 PM   #19
takenitez
Profile:  1993 30' Excella
1969 18' Caravel
Lovettsville , Virginia
Wing window part #
Ira
The part # for the framed streetside wing window is #680190, which was given to me when I called the AS factory parts dept. Then I called an AS dealer who ordered this part for me.
My window seal was in bad shape which is why I didn't attempt an "on the trailer" window replacement.
Good luck with your window replacements and I wish you "leak free" fixes...
takenitez is offline   Reply With Quote
Old 08-06-2007, 06:44 PM   #20
badelson
badelson's Avatar
Bob, thanks for the part no.
On a different thread, I was told that lexan and plexi flex and that you can have issues with the seal. You would think that you could lay a bead of some kind of sealant to eliminate this problem. I wonder if the people that have used lexan have gone with a full 1/8" or something thinner. 1/8 inch lexan should be reasonably rigid.
Hey, what is the thickness of the original glass anyway? If you are not going to use the original rubber seal, why couldn't you go with a thicker piece of lexan?...Say 3/16", that should help with the flex issue and maybe still leave room for the previously recommended vulkam sealant. When I pulled the old rubber seals out of the frames yesterday, I could have sworn that between the glass and the seal there was at least a quarter inch to work with in the frame.
Any thoughts?
Ira
Old 08-06-2007, 06:57 PM   #21
overlander63
Images: 58
Any thoughts?
That's because the original window was double pane. I currently have an aquarium between two panes of one of our wing windows.
AIR#2611
Old 08-06-2007, 07:19 PM   #22
badelson
badelson's Avatar
An aquarium?! If only you had some really skinny fish to boot.
Double pane? When I pulled the old seal out of the frame and cleaned out the glass, there only seemed to be 1/8" thick glass...one pane. Please elaborate on the double pane thing. Did the double pane total out at 1/8" or were there 2 x 1/8" thick panes sandwiched.
Ira
Old 08-06-2007, 07:24 PM   #23
overlander63
Images: 58
That may be one of the differences in the windows. Ours has a rounded edge top and bottom yours has a straight edge on the bottom, and rounded on top. 1969 is the only year with that configuration. It may also only be single pane glass. ours is double pane, both a little over over 1/16" thick.
AIR#2611
Old 08-07-2007, 03:32 PM   #24
badelson
badelson's Avatar
Placed order from Vintage Trailer
Howdy everybody!
This afternoon I sat down and ordered a whole bunch of stuff from Vintage Trailer Supply. I bought a few bags of rivots, new amber/red markers, vulcam, drillbits, lenses and more. Pricing was quite reasonable.
I noticed the shaving tool for the rivots, but passed on it because of the price. I am wondering, does it really do the trick and is it worth the couple hundred?
While on the Vintage Trailer website, I noticed replacement windows for some of the 60's trailers. The windows only go up to '68. Are any of the 1968 windows compatable with the '69? Just wondering if anyone has researched this course.
Thanks again everyone for all the great info!
Ira
Old 08-07-2007, 04:49 PM   #25
overlander63
Images: 58
1968 was a different body style, 1969 models were predominately about 6" wider, with a different type of window.
AIR#2611
Old 08-07-2007, 05:06 PM   #26
badelson
badelson's Avatar
I kinda figured as much, about the windows. I guess it doesn't matter anyway, I am excited to try the lexan route and hope that the experience will serve me right in the future.
One thing that I found interesting, none of the distributers that I called had "complete" brake and backup light kits, just the lenses. The other day when I was inspecting brake/turn/reverse lights I noticed that all of the bulbs were coroded to the sockets. I wanted to replace the steel back box and the lens with brand new, but I guess that I'll have to try and rebuild the back boxes and bulb sockets.
Ira
