Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1969 Sovereign
Old 04-27-2009, 11:52 PM   #1
tdoescher's Avatar
Profile:  1969 31' Sovereign
madison , Wisconsin
Holding Tank Question - Dump Valve
I have a 69 Sovereign, which only has one holding tank. There is only one Dump Valve. Which I think is only for the toilet. When I run the the front sink or bathroom sink it just pours out of the the back Valve which is in front of the dump valve. Is this liquid from the sinks held in by the cap or am I missing something? Does the dump lever stay up or down when the camp is on???
tdoescher is offline   Reply With Quote
Old 04-27-2009, 11:55 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
The valve is for the toilet water only. Sink and bath water pour directly on the ground through the drain pipe, unless you use an auxiliary portable tank. The valve needs to be closed unless you are actually dumping the black tank at that time.
(No Longer at Inland RV)
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 07:58 PM
Holding tank valve replacement Van Waste Systems, Tanks & Totes 4 05-04-2004 01:06 AM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 09:21 PM
Holding Tank Dump Valves odfarley 1966-68 Caravel 2 08-06-2003 11:38 AM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 11-01-2002 12:11 AM
