Hi j c c--Inside looks clean and neat. We have the same interior layout in our 1973 27' Overlander, which we find very versatile, as you have all of your interior space for use during the day, with no full time bedroom. Couch/beds are a little narrow. If we have an over flow guest, we use an air mat and sleeping bag on the floor. Works for us.
From the picks looks like no A/C. If this is the case price should probably be a little lower. If current owner is putting in a new RV fridge, with electric/propane his cost will probably be $1K to $1.4K, so he probably will not want to move much on price.
If it has spent most of it's life in an RV park, and also because of it's age, you may need new axles (see axle threads), which would cost about $1.5K, if you expect to do much over the road travel.
Check the floor yourself with an icepick around the edges. You're looking for soft spots, damaged by water, resulting from leaks. From the looks of the inside, your floor may be OK.
If I wanted another A/S, and it was located within a couple of hundred miles, I would consider buying it for $6.5K if all systems were OK, as you indicated. Good luck in your A/S quest.--Frank S
