Old 10-07-2010, 02:02 PM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Where can I buy replacements for these?
I would like these in something besides plastic. Is it possible?
Do the make a precut piece of aluminum for this?
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 10-07-2010, 02:07 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The round pin plugs are available in metal at auto parts houses and truck stops, probably not at RV stores.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 10-07-2010, 02:23 PM   #3
The water fill will be difficult to find.
The 7 way plugs and sockets are made by Pollack.
The bath exhaust fan assembly has a solar gray cover.
Both of these are available from some dealers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-07-2010, 02:30 PM   #4
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Andy,
I have the exterior gray cover for the vent. I removed the vent a hood in the galley and was wondering if I could close the exterior and interior holes. Any Ideas?
THANKS, Cynthia
Old 10-07-2010, 02:36 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I really like the Pollak umbilical plugs. I have one installed on both my Airstreams (6-wire on the '58 and 7-wire on the '72).
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 10-07-2010, 02:38 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Look for the water fill replacement in the Boat parts on EBAY. The aluminum vent cover is easily made by any sheet metal shop...just give them the diameter. Be sure to use 2024 alum if you plan to polish.
Old 10-07-2010, 02:39 PM   #7
Andy,
THANKS, Cynthia
Cynthia.
You can plate the exterior hole using Olympic rivets and some Vulkem sealer.
Unfortunately, the interior is "vinyl clad aluminum". That style has been obsolete for about 30 plus years. The only color Airstream has is gray.
Maybe you could find a section of it from a salvage yard someplace.
Or, after you plate the exterior, fill the hole with fiberglass insulation, and the use the same kind of plate in the interior.
Hide that interior plate with a painting or a photo of something you cherish.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-07-2010, 03:09 PM   #8
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
For the Pollock plug,I think it and cable are for sale on Ebay under airstream,or vintage trailer. Dave
easyride is offline   Reply With Quote
Old 10-07-2010, 03:21 PM   #9
Ottawa , ON
Check dis out: (kinda pricey...)
Temro 15A Inlet
They have a potable water outside filler too, but it's plastic.
[edit: oops wrong electrical plug!)
Wait, I think I found the correct one: http://odmrv.com/catalog/index.php?m...roducts_id=404
Old 10-08-2010, 07:07 PM   #10
The truth has no agenda
MJMarkhams70's Avatar
1970 27' Overlander
Katy , Texas
i may end up with extra pieces of the vinyl clad aluminum wall panels that will have the correct color and texture from my 70 that I could pass on if you are interested in doing that...
WANTED- 1- 22x40 Curved Glass Window and 1- 22x18.5 Curved Glass Window
MJMarkhams70 is offline   Reply With Quote
Old 10-08-2010, 10:43 PM   #11
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The metal Pollak plug - this is like the one we bought at the factory a couple years ago:
http://www.inlandrv.com/catalog/imag...tor-female.jpg
Old 10-09-2010, 07:15 PM   #12
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Thanks EVERYONE!
Found the pollack on Ebay .
Still looking for a reasonable water fill.
Old 10-09-2010, 07:18 PM   #13
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Another quick question...The hole I want to cover...I may replace the stovetop vent instead, however Id like a small one that will attach to the wall without an overhead cabinet. Does anyone have any ideas where I may find one? Thanks again!
7 pin, aluminum, water fill
Mattress replacements Airstreamdmb General Interior Topics 14 08-26-2012 09:34 PM
LED Lights replacements 2trackrr Lights - Interior & Exterior 3 11-01-2008 10:02 AM
'64-65 toilet replacements... 59er Sinks, Showers & Toilets 22 09-04-2007 11:08 AM
ST Tire Replacements LTD93 Tires 4 09-28-2005 04:15 PM
Accuslide replacements TBYRNE Airstream Motorhome Forums 3 07-12-2002 06:21 AM
