Old 04-29-2009, 04:23 PM   #1
1972 27' Overlander
Colton , New York
tail droop in 27' models?
I am looking at a 72 overlander.
Is the tail-droop issue less of an issue with the 27' models compared to the 31' models of this era?
I am aware of some of the other gotchas like the absense of grey-water and looking for signs of leaks and rotted floors... checking applicances, and suspension/tires etc....
but the tail-droop thing kinda has me more worried when looking at airstreams...
jrousell is offline   Reply With Quote
Old 04-29-2009, 05:19 PM   #2
Have someone stand on the rear bumper.
Have them jump up and down.
Look for the frame as it enters the rear of the shell, to move downward from the shell.
If there is movement, then there is rear end separation, to some degree.
The further it moves, the greater the problem.
Old 04-29-2009, 05:25 PM   #3
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Our 27' 1969 Overlander had rear end separation
As well as a rotten rear bath floor............it also had some type of rack on the rear bumper--perhaps a tire carrier........pj
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 08-05-2011, 10:23 AM   #4
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
The floor rot and shell/frame separation kind of go hand in hand. Once you have any separation, this allows rainwater to get into the end-grain of the floor plywood, making it worse. The fix typically involves replacing the last full sheet of plywood, and then jacking up the rear end of the trailer so frame and shell are tight, then re-bolting the entire rear end through the wall bottom channel, reinforcing plates in that channel, the plywood floor, and any and all outriggers, frame members, and reinforcing plates beneath the floor. Then plenty of pop rivets through the interior wall skin that you took off, through the 'studs" and bottom channel. Then a good quality caulk all along where the shell meets the bumper storage compartment. Should last many years after this fix! Good luck!
tphan is offline   Reply With Quote
1970 27' Overlander Jay Basinger Member Introductions 2 08-23-2007 08:55 AM
Frame Droop JackMac Repairing/Replacing Floor &/or Frame 7 12-06-2006 11:26 AM
Rear Bath Floor Droop bdbluegrass All Argosy Trailers 4 05-04-2005 09:44 AM
27' Safari Steve Heywood 2002 Safari 3 11-15-2003 10:21 AM
