Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1970 - 1973 Overlander
Old 01-19-2010, 07:35 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Starting Repairs
I am in the process of repaining my 71 Overlander. Luckly the floor repairs seem minor. I have attached a photo of the floor in the rear of the TT. An area (2 foot wide and 1 foot deep) right in front of the rear access has rotted where a leak fron the rear sink drain was left unrepaired. My question - should I go ahead and replace all of the rear floor from the bathroom doorway to the rear or just that small section.
Next I have to remove the 2 front side windows (the PO installed them with no gaskets). I think I have to remove the front interior cap but I am unsure how to do this.
I also need the rear lights (photo attached)
I also have some interior separation - what could cause this? (photos atached)
Name:	Bathroom Floor.jpg
ID:	94337   Click image for larger version
Name:	Rear Lights.jpg
ID:	94339   Click image for larger version
ID:	94341   Click image for larger version
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 01-19-2010, 07:47 AM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Another Question - where can I find a bath/shower for my TT? The one I have has a big hole knocked in it.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 01-19-2010, 08:29 AM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
If you are talking about the upper cabinets separating as shown in the last picture it is probaaly caused by a rough ride due to bad axles. I would suggest that you sart on the running gear repairs first, axles, tires, wheels, brakes and lights first. Once these items are in good working order then proceed with the other repairs.
Don
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 01-19-2010, 08:32 AM   #4
Ottawa , ON
If you haven't already done so, I would take all the carpet out anywhere near where the leak was to make certain that you have found all the rot...
In other words, be sure you look at the bare wood subfloor in all of the bathroom, and keep going if you see any signs of staining or rot.
Old 01-19-2010, 09:09 AM   #5
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
That interior separation could also be caused by rear end separation.
http://www.airforums.com/forums/f36/...rse-60246.html
SilverHoot is offline   Reply With Quote
Old 01-19-2010, 11:29 AM   #6
The Polishing Guru
zinbar's Avatar
Riverside , California
If you're talking about the wing windows on either side of the front window, you can remove the interior closeouts by drilling out the rivets that hold them in place and removing them by themselves. You really don't even have to do that, unless they are damaged. You can drill out the rivets that hold the wing windows in place from the outside, and pull them out to reseal them. The windows come out with the frame.
If the windows themselves are missing the gaskets, it will be a bit of a chore to seal them, involving dismantling the frames, adding gaketing, and reassembling.
Riverside, CA
zinbar is offline   Reply With Quote
Old 01-20-2010, 04:04 AM   #7
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I am going to replace the axles, wheels and tires but I want to fix the inside first. I am in the process of removing the carpet and replace it with cork flooring. So far, I see no rear sag or separation. I have found a little staining on the floor up front but the floor seems solid. I think I am going to replace the rear section of the floor from the bathroom doors to the rear of the trailer. I will see how that goes.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 01-20-2010, 07:38 AM   #8
The hole can easily be repaired, and then the tub can be refinished. New parts don't exist.
The wing windows can easily be sealed from the outside, with Vulkem sealer.
No need to take anything apart or to drill out any rivets.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-20-2010, 08:15 AM   #9
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
I may have some parts you could use. Lights, bath
Let me know
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 01-21-2010, 07:51 AM   #10
bedfords's Avatar
1975 29' Ambassador
Items of Repair
MWells does your Lights and Bath look like these? Maybe a little cleaner.
ID:	94472   Click image for larger version
Old 01-21-2010, 09:14 AM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
First remove the lens covers. If your canisters aren't too badly rusted you can simply clean them up and repaint them. Otherwise, you can buy new LED lights. I went the half-way route. I cleanup up the brake/turn signal lights in order to retain the Fiber Optic display feature, and replaced the white backup lights with LEDs (see my blog for details and pics).
Mike
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 01-21-2010, 11:43 AM   #12
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
The light look right but the bath is a shower bath with the drain in the center
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 01-21-2010, 11:47 AM   #13
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Does anyone have the instructions on removing this toilet?
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 07-30-2010, 10:55 AM   #14
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Did you ever find out how to remove your toilet -- we have the same year/trim level and I'm going to need to do the same thing for our floor update?
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): https://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: https://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 07-31-2010, 10:49 AM   #15
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
No no one ever told me how to remove the toilet but I did figure it out myself - you will need a wrench - I think it was 9/16 but the nuts are easy to get to. At the bottom of the toilet is openings for you to get to the nuts. Then you just remove. The water was not hooked up to my toilet - just the sprayer - so I cannot tell you about the water plumbing. But that should be easy also. Good Luck
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Starting Suburban NT35K repairs catson4 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-08-2009 11:01 PM
Just Starting To Look SnowGypsy Full-Timing 4 02-12-2008 12:42 PM
Just Starting rick zigler Member Introductions 12 12-29-2006 06:08 AM
Starting over? propstrike Airstream Motorhome Forums 29 08-06-2006 06:14 PM
Just starting to look! Fogducker Our Community 4 01-25-2004 11:52 AM
