Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1970 Overlander
Old 08-11-2009, 12:44 PM   #29
MJMarkhams70's Avatar
Profile:  1970 27' Overlander
Katy , Texas
I have to agree about the satisfaction of seeing results from your work. I just got back from a lunch run to Fastenal to pick up the elevator bolts/nyloc nuts/washers. I went ahead an ordered 150 witch should take care of the floor. It should also give me some extra to add more piece of mind to bolting down the c-channel. I also picked up a roll of putty tape that I will sandwich between the fenders and the frame before bolting it all together. Fun times...
MJMarkhams70 is offline   Reply With Quote
Old 08-13-2009, 07:46 PM   #30
Katy , Texas
Ok, I have made a choice on an alteration to the project. Most likely the first of many.
First off, I would like to give many thanks to 87MH (Dennis) for the generosity and friendship that he has show to a newcomer to the AS life... thanks in addition for some well placed guidance.
With that I have decided to add a gray water tank to my system and I would prefer to set it up like this
which I believe is from a '78 Excella. I need information on the two tanks. I hope that they were supplied by INCA, as it seems that most of their tanks are available. I hope that someone has the numbers on the tanks...then I can fit the same configuration in my unit before I button up the belly... Any info is greatly appreciated...
Old 08-16-2009, 04:44 PM   #31
Katy , Texas
anotherr weekend down and more progress made.
I picked up the plywood on Friday during a long lunch (and boy was it long. but that's another thread all together). Made the trip out to the shop and decided to coat the bottom sides of all the decking with water sealer for a little extra protection.
Saturday morning we started by cutting the 1/2" filler strips that reinforce the seams of the plywood and screwed them to the cross supports. After I dry fitted the sheets. I also picked up a sheet of 1/4" to scribe templates from the shell. that took longer than I was hoping, but I wanted them to be correct. for the most part got about half of the new sub-floor bolted down by 5:00 pm. Today I finished up the floor and cut a few hole for plumbing...
Old 08-16-2009, 06:01 PM   #32
Profile:  1985 31' Excella
battle ground, , Washington
progress is amazing!
well, the dog looks as if he/she has worked hard! you certainly have had experience doing resto. Your work and progress speed is really great. Keep us posted. it's a beaut so far!
ol' bill the newbie-with his eye on a 74 for a rebuild....
wmarsha is offline   Reply With Quote
Old 08-17-2009, 04:47 PM   #33
Profile:  1967 24' Tradewind
Redding , California
Really nice work! Did you get any info on those tanks? What size is the space that you have for them? I'm looking myself right now.
SilverHoot is offline   Reply With Quote
Old 08-18-2009, 06:57 PM   #34
Katy , Texas
I am working on a plan adding the dual tank setup under the rear floor. I would guess that as long as I dont do a lot of driving with full tanks, that the additional weight is not going to make a great deal of difference. I am in the process of doing measured drawings in order to get some quotes on making a custom setup. I will post up what I come up with so that I can get some feedback before I make the leap.
I do have a question. Can I flush the gray water tank through the black water tank to purge instead of just wasting that water?
Old 08-19-2009, 07:27 AM   #35
Looking for John Galt
Dumpster's Avatar
Billings , Montana
For what it is worth.......
First off, congrats. I will be following your thread very closely, as I just brought home a '70 Overlander yesterday. What you have done already is beyond impressive.
Do you plan on boondocking at all? The only reason that I, as a totally green AS'er chose to try and answer your question is the current lack of a grey water tank in mine is going to hit home right away, and hard. We boondock almost exclusively. We also go through lots and lots of grey water. Having the seperate tank made it possible for me to empty the gray tank using a bucket. But now having them combined in one tank, I will have no choice but to do the nasty.
So if you only plan on camping with full hookups, your plan to use the grey to help flush the black is excellent. But if you ever plan on boondocking, having seperate valves on each tank is in my opinion, the only way to go.
Best of luck on your project. Although it appears luck has nothing to do with it.
Best,
Wuttevr
Dumpster is offline   Reply With Quote
Old 08-19-2009, 08:43 PM   #36
Katy , Texas
I appreciate all the supportive comments... I did some thinking on my tank setup today.
this is what I came up with:
a two tank setup that allows for gray water to be directly purged through the rear gate, or to be purged through the black water tank to assist in cleaning that out. it would also give me some backup tank if I need to hold more gray water before dumping. from my calculations, the gray would be roughly 34 gal. and the black about 22 gal. for a combined of roughly 56 gal.
Thoughts?
Old 08-19-2009, 08:59 PM   #37
Jimandrod's Avatar
Profile:  2008 28' Safari SE
Placitas , New Mexico
All I can say is.... AMAZING!
Jim & Rod
Two Burmese cats with attitude
Philip and Gus
Air 10899 since 1/06
WBCCI 2484
Jimandrod is offline   Reply With Quote
Old 08-19-2009, 09:59 PM   #38
tinman54's Avatar
Profile:  1954 25' Cruiser
1957 26' Overlander
roberts , Wisconsin
Great looking work and I also like the BIG MAN garage/shop!!
It's not worth doing if your not having fun. http://tinman54.blogspot.com/
tinman54 is offline   Reply With Quote
Old 08-20-2009, 06:45 AM   #39
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Double that from me -
Just one suggestion - while you are plumbing on the curb side, add a 1" inlet with a valve on the curb side of both the black and the gray tanks.
A direct connection to a hose on the "back" side of the tanks would be the most efficient "power wash" I could think of. The pressurized fresh water would wash straight across the entire length of the tanks to the drain outlets. Maybe put a "quick connect" on the hose fittings?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 08-23-2009, 09:09 PM   #40
Katy , Texas
no pictures, sorry. Got the fresh water tank installed and the black/gray water frame modifications done. I believe that it will work out nicely. I will shoot some pics next time I go out.
I am going to pick up some 2" foam insulation panels this next week so that I can get closer to putting the belly pan back on...
I will put this in the classifieds as well, but if any of you have upgraded to a fantastic and still have the aluminum vent cover lying around, I would be interested in seeing if I might acquire it...
Old 08-29-2009, 10:14 PM   #41
Katy , Texas
taking this weekend off from working on the AS proper, but we are still trying to move forward. Going tomorrow to look at a 31' Sovereign for parts... I think it will supply all the windows that we need as well as many other parts. Possibly it may be able to help some other AS with donor parts... We shall see...
Old 08-30-2009, 10:57 AM   #42
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Great work man...Love the VW too
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Process has begun... augier Interior Restoration Forum 3 01-05-2009 08:08 PM
It has begun... grakkin 1976 Sovereign 18 05-09-2008 02:10 PM
My countdown has begun... Wegotone Member Introductions 1 04-27-2008 09:39 PM
The Fun has Just Begun! Bambi_Bandit International CCD all lengths 21 06-28-2005 09:26 PM
